Question about Kenmore Refrigerators
Ice maker only operates on crushed ice mode
Wheater the selector switch is on on "crushed" or "cubed ice", it only produces crushed ice. I moved the selector switch back and forth on both settings got some smoke from the Control Module. Obviously, there is a short in the Control Modular.
What is the fix?
    Brigadier General:
  • 8,619 Answers
There should be a solenoid behind the ice bucket that moves an metal arm on the ice bucket to move the crush teeth away for cubes or keeps the crush teeth in place for crushed cubes. Bad solenoid, bad wire at the solenoid, broken solenoid/mechanism piece, bent arm, no power from dispenser to the solenoid are -some- possible trouble makers.
Also the solenoid that controls the crush/cube function is probably frozen. First, pull out your ice bucket. On the bottom of the bucket is a long metal rod the runs all the way to the back wall of the freezer. That rod runs into a little square hole in the back of the freezer. The hole is about 1 and half inches square. Just put your finger in there and see if the solenoid plunger moves up and down easily. If it doesn't move, then it is frozen. Just hit that area with a hair dryer and it will release. If it moves easily, then make sure that the the rod on the ice bucket is seated in there properly
Posted on Feb 09, 2009
  • Rylee Smith
    Rylee Smith Feb 09, 2009
    A Fixya rating would be appreciated .
    Thanks
    Rylee
The ice maker of our GE GSH25JSXSS is only producing crushed ice even when it's set to cubed. Is there a way to fix this issue?
Check that the shifter bar on the bottom of the ice bin is moving to shift from cubed ice to crushed. With the ice bin out you should see movement in the back wall of the freezer with the light switch button held in while changing the dispenser controls from cubed to crushed. GSH25JSXASS Parts
Ice Bin Parts
Appliance 911 Sea Breeze
Nov 03, 2015 | GE Refrigerators
GE ice maker crushed ice selector does not work. It does work for cubes and water. Pushing the door button when cubes are selected causes the assembly in the back of freezer that moves a rod to open the...
Crushed ice makers have a tendency to freeze up the mechanism. So you might want to deinstall your ice maker and let it defrost for a day or two.
That would be where I started, but if that didn't fix the problem I would move on to the electronics/
May 06, 2012 | Refrigerators
My icemaker won't deliver cubes despite switching from crushed to cubes on selector, what's a guy to do
you have to take apart the complete ice maker from inside the freezer as it has to be cleaned on a regular basis to operate properly. check with your owners manual, it tells you how to clean it.the ice cube shoot is the first to freeze up & block your flow of ice. it's not hard to do. all the best.
Dec 01, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigidaire model glrs267zcwi side by side. Crushed ice comes out when either the crushed or the cubed button is depressed. How to fix it please?
It sounds like the water line to the ice maker is partially obstructed (probably semi-frozen) and the unit is making smaller than normal ice cubes. This causes the ice ejector to "shatter" the smaller cubes, producing the appearance of crushed ice.
The easiest thing to try is make sure the water line connection inside the freeezer isn't frozen. A hair dryer can be used to thaw the inlet to the ice maker, but just be careful. Remove some of the product in the compartment so you have enough room to work.
Dec 12, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Oct 05, 2009 | Refrigerators
Dispenses crushed ice and will not dispense ice cubes
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Kitchenaid kscs25fjss01 (2002) front panel not working
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Apr 02, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker is crushing ice when cube ice button is on
We've had a similar problem, possibly the same, with our LG in-door ice maker. Whether cubed ice or crushed ice is selected, it crushes the ice.
We found that there is a little lever on the inside of the door, on the lower right behind the ice bin, which freezes in the down position. This is a literal "freeze up", as a block of ice forms in the little well under this switch and eventually freezes the switch in place. Since the switch needs to go up to provide cubed,.. we only get crushed. On 3 separate occassions we've thawed and chipped out (carefully) this little ice dam and gotten cubed ice capability back for a few weeks. At which point it freezes again. I have no idea why water collects there in the first place.
Feb 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
Refrigerators Logo
153 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
