Question about Sony KP-61S65 61" Rear Projection Television
I have a sony rear projection 52 in tv i need help with...
I have a 52 in sony rear projection 52in tv that when i push the power button it sounds like it turns on and then off very quickly. there is no picture that comes on at all just the stand by light flashes quickly. the tv repair man came and said that it was the power board that needed replacing. How much does that cost? is it worth getting fixed? can I do it myself?
    Genius:
  • 2,920 Answers
You can do it yourself if you can orer the part..its about 120.00 i think for the powerboard and then th time it takes you to put it in. if a repairman does it hes charging you at least 75.00 an hour for labor.
Posted on Feb 09, 2009
Hello, I have a 52in RCA projection tv, model D52W20BYX1. It used to work fine but now whenever i try to turn it on it the power button light turns on and the tv makes a short whistle sound, this happens...
Not sure why chat got closed/ disconnected.
There is big transistor TL010 attached with heat sink near flyback transformer, this is horizontal output transistor, check it and replace if found shorted.
Thanks.
Apr 08, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 52in rca it wont power up no sound just
FBT flybck Tranfomer 239111 Call Mats 1-800-628-1118 Ck hori output Transistor in case it is shorted.
Dec 21, 2009 | RCA P52926 52" Rear Projection Television
I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
Nov 05, 2009 | RCA P52926 52" Rear Projection Television
52in dlp lg tv has no picture
i checked the power supply board but still nothing
May 19, 2009 | LG RU-52SZ30 52" Rear Projection...
Got tv from friend want come on
Its over heating I have the same problem! the quickest fix is
to find away to get cold air blowing to back of TV. also move away
from any heat.
good luck
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Is there a reset button for 52in rca hd ready rear projection tv?
Most likely there was one or more marginal connections on the main board and moving the set has completely opened those connections. If you can solder, try resoldering any connections on the boards that appear to be grainy or have rings. Update this with the results. That may resolve the problem. If not, we'll look further into the set for component failures.
Dan
May 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52 in rear projection... start up menu always on
finich seting up ...go through the setup menu. and pushing ok instead of clear. if it continue this indicate the main ac is being interupted.. do you unplug it at night? or just power it down.
Dec 15, 2007 | RCA HD52W58 52" TV
Beeping sound when tv is pluged into wall. no picture or sound
is it beeping or cherping ,cherping it the power supply trying to run.power supply poss.faulty
Jul 29, 2007 | RCA P52926 52" Rear Projection Television
Sony KP-61S65 61" Rear Projection Television Logo
131 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
