Question about AcerPower FH - P4 631 3 GHz (S6463624) PC Desktop
I have a AcerPower FH P4 -- 100% CPU usage all the time prob...
I have a AcerPower FH P4 that is displaying 100% CPU usage all the time...It is extremely slow in spite of the fact that I have 2GB of RAM and the processor is 3.00ghz. I looked into the task manager and the memory allocation tab. It appears that Internet Explorer is using up about 35% of the CPU, even tho I don't even have it open. Can anyone help me with this problem?
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    I agree, you need to first look at scanning for malware or viruses. What anti-virus program are you running?
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Now that should not be happening. Sounds like you have a worm or virus. Have you done a full scan of your system lately?
    President:
  • 778 Answers
Boot your PC into "Safe Mode" (tapping the F8 key on boot to get to the option) and run a full/complete Virus scan with Anti Virus with up to date virus definitions and see what that yields.
Posted on Feb 09, 2009
  • Frank  Fernandez
    Frank Fernandez Feb 09, 2009
    You almost surely have an infection, as your 3GHz processor with 2GB of RAM should provide you with better than average performance unless your running Vista?
  • Frank  Fernandez
    Or your harddrive is spinning down (worn out).
AcerPower f5 4GB RAM only 3 available
in win 7 it won't shows all RAM, mostly virtual and paging file uses it,don't worry your ram is fine.when cpu require high RAM usage it uses it.
Feb 15, 2014 | Racer AcerPower F5 PC Desktop
Tip
How to Protect PC from Overheating?
Laptop over heating which is also known as Thermal Overload.This is mainly due to excess usage of CPU(More than 60%) for a long time.
To check CPU usage Right click on Task Bar>Select Start Task Manager>Performance.
or
Shortcut Ctrl+Shift+Esc
If your CPU usage is more than 50% you need to close some applications which are using 20++% CPU.
To check application which are using 20++% CPU
Right click on Task Bar>Select Start Task Manager> Processes
Search in this dialog box for programs which are using 30++% CPU
You need to close this application to prevent PC from over heating.Actually %age usage indicates load to CPU by the application.If load is to much CPU is to processes at faster speed which in turn increases temperature of CPU.
To close the program select the program,and select End Process.
If didn't found any program using 30++% CPU in this dialog box.
Select Show process from all users. and search in this dialog box and close the program.
Caution:some times your system also uses 30++% CPU inn some processes like anti virus scanning,at this if you closed the program your PC may shutdown.At this time you need to restart the PC.
This usually happens for out dated anti virus or incompatible programs.
There are some other factors like Graphics Properties and Graphic Memory,Display size, Processor type,etc.At this time its better top use a cooling pad.
Some program like camera drivers,Simulation softwares,games uses 50+% CPU.This is common these programs need to process large amount of data at short interval time which increases CPU usage but this is normal.
The processors properties are tested at 140*c so no need to worry.If the CPU exceeds the limited temperature PC will shuts down automatically,and after cooling you need to start the PC.
Thank you...:)
ANY SUGGESTIONS...?
on Feb 16, 2011 | Computers & Internet
When I turn on power long beeps no post or video. What do the long beeps indicate?
These kind of beeps usually is an identification for ram or cpu errors. I have to know your exact model of the computer and the kind of beeps (e.g. 1 short - 1 long or 2 shorts - 1 long or 1 short repeatly, don't worry there is no problem if your computer beeps for some seconds) in order to tell you if it's ram or cpu problem.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 17, 2010 | Racer AcerPower FH PC Desktop
I have an AcerPower FH pc computer and I need to open
The case may be damaged. Since you voided your warranty, you have nowhere to go. Sorry :(
May 04, 2010 | Acer Power FH PC Desktop
How to remove case on acer power fh to replace the cdrw, the tray will not open
You need to remove the front cover to get at the screws for the side panels, pull the front panel with a bit of force and it should come off allowing access to the side panel screws. Then slide the panels towards the front and they will come away.
Mar 09, 2010 | Racer AcerPower FH PC Desktop
AcerPower FH speakers won't work.
hi, we have to know if your speakers are bad or if your just lack drivers. to do this, follow the below steps.
1. get an headphone, then play a song or something to see if you can hear it. if yes, then; your speakers a bad(burnt) and needs replacement.. if no, your need to get the sound driver for your system sound-card . so pls let me know your outcome. bye
Feb 07, 2010 | Racer AcerPower FH PC Desktop
Acerpowerfh keeps turning on and off rebooting why?
it does sound like a boot virus problem. you need to boot into system restore. to boot from the restore partition you need to switch on your pc and repeatedly press either F10, F11, Alt+F10, or Alt+F11. you do this until you see the system restore starts. you will be able to fix windows, or you can do a desturctive restore and restore your pc back to factory settings, but you'll loose your photos and anything saved on the hard drive.
Apr 22, 2009 | Racer AcerPower FH PC Desktop
AcerPower FH - P4 631 3 GHz (S6463624) PC Desktop Logo
232 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
