Question about Pegasus Technologies Plumbing
Umbrella drain installation leaks
I am installing an umbrella pop-up drain and can't get it to not leak. Seller says the 2 silicone gaskets included are all I should need. I believe I have to use some other sealant need to know where and what i should use. I have read plumbers putty, silicone caulk, teflon paste and the more I read the more confused I am.
    President:
  • 1,902 Answers
Use plumbers putty, that is the best stuff and is not messy and worked great for my grandmothers
Posted on Feb 09, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 09, 2009
    The top one, you place it between the washer and the sink. Roll it up in your hand into a long string, and then place it down and screw it all together. You can also put thread tape on the threads as a back up
How do i change the oil pan on a 2007 ford f150 4.2L v6?
4.2L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
    WARNING
    During engine repair procedures, cleanliness is extremely important. Any foreign material, including any material created while cleaning gasket surfaces, that enters the oil passages, coolant passages or the oil pan can cause engine failure.
  2. Raise and safely support the vehicle.
  3. Remove the starter.
  4. Drain the engine oil. Install the drain plug when finished.
  5. Remove the 4 bolts and the crossmember.
  6. Remove the 3 oil pan-to-transmission bolts.
  7. Remove the 17 bolts and the oil pan.
  8. Remove and discard the oil pan rear seal.
To install:
WARNING
Do not use metal scrapers, wire brushes, power abrasive discs or other abrasive means to clean the sealing surfaces. These tools cause scratches and gouges which make leak paths. Use silicone gasket remover and a plastic scraping tool to remove all traces of old sealant. Follow the directions on the packaging.
  1. Clean the gasket mating surfaces using silicone gasket remover, a plastic scraping tool and metal surface prep. Follow the directions on the packaging.
    NOTE
    If the oil pan is not secured within 4 minutes, the sealant must be removed and the sealing areas cleaned. To clean the sealing area, use silicone gasket remover and metal surface prep. Follow the directions on the packaging. Failure to follow this procedure can cause future oil leakage.
  2. Apply silicone gasket and sealant to the oil pan sealing areas shown and install the oil pan rear seal.
  3. Apply silicone gasket and sealant to the rear main bearing cap.
  4. Install the oil pan rear seal.
  5. Apply a bead of silicone gasket and sealant to the oil pan mating surface.
  6. Position the oil pan and install the bolts. Tighten the bolts in the sequence shown. Tighten to 10 Nm (89 inch lbs.).
  7. Install the 3 oil pan-to-transmission bolts. Tighten to 34 Nm (25 ft. lbs).
  8. Install the starter.
  9. Position the crossmember and install the 4 bolts. Tighten to 90 Nm (66 ft. lbs.).
Feb 15, 2016 | Ford Cars & Trucks
How do i change out the oil pan?
4.2L Engine
    WARNING
To install:
WARNING
    NOTE
Feb 15, 2016 | Cars & Trucks
Just got cx500 custom 1981 leaking oil when i start up from small hole on side of cylinder what do i do
If the oil leak is coming out of the spark plug drain hole , the inner valve cover seal is leaking or not installed correctly. Take out the two bolts holding on the valve cover and remove the cover. If the valve cover gasket has silicone on it , pick off all the silicone and put the gasket and cover back on. That should fix the problem. Silicone on the type of gasket can make it leak. If the gasket is hard or cracked replace the soft rubber gasket and put it on by itself with no extra sealant.
Dec 24, 2010 | 1982 Honda CX 500 B
My Danze brass pop-up drain assembly w/lift rod and overflow leaks on the threads that lead upto the flange. I have tried a small amount of putty to a large amount and still leaks after about 1 week from...
I always use white silicone - putty always cracks and leaks. Silicone makes a sort of custom rubber gaskit and never leaks. Clean off with paper towels immediately before it skins over
Dec 21, 2010 | Danze 1-1/4 '' Brass Pop-up Drain Assembly...
We are ready to install the Duracraft Plastics Schedule 40 Foot Lok style bath drain and have a question on the foot lok drain gasket. Does the gasket install on the inside or outside of the bathtub and...
The gasket is installed on the outside of the tub. Use plumbers putty under the male end on the inside of the tub as it stays permanantly flexible and will not mildew like silicone caulking can. Do not silicone or use plumbers putty on the gasket. The gasket will seal nicely under pressure from the connections.
Aug 02, 2010 | Home
Installing above counter sink and is leaking on
Sound like you have the wrong drain assy.or its installed wrongsometimes I put pipe dope on the top side of the rubber gasket and around the threads of the pop up and really tighten the nut.
May 13, 2010 | Plumbing
2004 Explorer: Rear differential cover is leaking, how do I fix i...
put flat pan under the housing remove the bolts holding the cover usually 10 or 12 (1/2 or #12 metric) bolts? allow the rear end grease to drain... then scape off the old gasket clean with brake cleaner spray install either new gasket or form one with oil resistant silicone put the cover back on , dont refill the fliud for at least 12 hours if using silicone. Also check the front driveshaft rear end yoke seal....they sometimes leak making the illusion of a rear end pan cover leak...if that is leaking you remove the shaft carefully...remove the large yoke retaining nut, replace the press in seal...be sure retaining yoke nut is properly torqued when reinstalling .
May 06, 2010 | 2004 Ford Explorer
Shower drain still leaking
Shower drains can be a real pain to install. If you have the screw in type with the rubber gasket and card then you need to take it appart again. The card usually rips and then the rubber is twisted out of place. Use clear bathroom silicone (not acrillic based) between the upper grill part and the shower base, lube the plascit nut & rubber with silicone grease (home depot) and throw the card (now crushed or soaked) in the garbage. Have someone hold the grill in place (needle nose pliers) while you put the rubber & nut on. Keep a close eye on the rubber as it can still get forced out as you tighten. Clean up the silicone before it sets. If you have the rubber wedge style then I would suggest that you buy a screw on type.
Mar 07, 2010 | Plumbing
My model GWL11 washer is leaking from the drain pump. The drain pump part number is 420325P. Is it possibe to buy a replacement seal instead of the entire $76.00 pump? The seal has the number 3C026 along...
Yes!!! The solution for your gasket is called Silicone. Fisher & Paykel builds job security for their parts department into every washer. The drain leaks and makes the $1.50 fuse on the board pop and then they sell you a board for $189 OR the grommet where that water mixes get old and leaks, the problem with that is they located the thing in the SEALED compartment for the electronics! Water & ELectronics? I think NOT! Silocone is the answer here as well. Just take the 2 screws out of the back and lift the control panel out and put clear silicone around the grommet and the sensor wire.
As for the water pump IF you caught it in time, take the thing apart and use silicone LUBRICANT (WD-40) to oil it and then use silicone on your gasket to make the seal airtight. If not, it will corrode, squeel and then pop the little 'bell fuse' on the board.
It's a great washer as far as ringing out the clothes as they are almost dry when the thing finishes spinning but I don't care for their concept of washing in hot or warm water. The thing just spritzes them in hot water for a bit and then fills up with cold water and washes.
Hope this helps!
Feb 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
Plumbing Logo
537 people viewed this question
Top Pegasus Technologies Plumbing Experts
Don Numinen
Don Numinen
jdthefixer
Andrew Bugbee
Are you a Pegasus Technologies Plumbing Expert? Answer questions, earn points and help others
