Question about Dell W4200 42 in. HD-Ready Plasma Television
How to get the dell 4200 ed to pick up digital channels
I am trying to get this tv to pick up digital channels. I do not se the hook up on the back that it says in the manual.....Will I have to buy the converter box to get the digital channels or is there a way to connect it otherwise?
Allow the vizio setup wizard to help you tuneyourchannels
Posted on Mar 03, 2012
    New Friend:
  • 90 Answers
There are 2 coaxial inputs on the back of your tv. plug the antenna into the digital coax. with your remote, do a fac reset: menu, setup, fac reset, all settings, passcode 3355. after the reset, hit input, select digital tv. perfprm a chan scan: menu, setup, channel scan, antenna. this should solve the problem.
Posted on Apr 16, 2009
  • mangat71 Mar 03, 2012
    My and remot not worke
Whilst watching digital channel, tv suddenly said channel not tuned. Same problem with all channels. Now comes up channels not stored, and when trying auto start up, says no channeels found.
Ur tv,u are using and getting a over the AIR free broadcating tv channels signal wright?Ur antenna are using,have problems might not work anymore in ur area.Tries manual channels scanning ur tv should get it back or buy a better antenna deign like a Digital antenna design for a hook it up for a better signal prob and longer signal ranges tries scanning for Free over the AIR channels again should solved this problems.
Aug 27, 2011 | Sony BRAVIA KDL-46V3000 Television
Can my Panasonic TC-P42X1 receive digital channels without an antenna connected? It sounds like a stupid question considering its a high-def TV, but I'm having troubles getting the TV to pick up...
No.Tv can't pick up any reception or receive any free AIR broadcasting tv channels at all if tv have no antena hook up to a tv.Buy a better antena design to used like a Digital atenna,will solved this problems.
Aug 21, 2011 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Cant get channel 11 when i hook my converter box to this tv is there a way i can i get regular tv without it
No,if this tv is an analog tv mean tv have a big back cover and have a heavy CRT-(tv tube).Must have a good antena like a digital antena or move antena around to left or right to pick up channel 11,might lost some other channels than.This tv now can't pick up digital signal now without the tv converter box if u want to pick up free DTV air broadcasting tv signal,it all broadcasting in DTV free air in all digital now.
Apr 14, 2011 | Apex Digital AT2402 24" TV
My digital tv will only pick channel 10, abc and sbs, even though it used to pick all channels?
U trying to pick up all free AIR DTV tv stations wright?Yes.This problems u have a weak airial antena.Buy a better antena like a Digital antena or a roof antena for hook up.Tries again,will pick up all DTV free AIR tv stations.
Apr 03, 2011 | Televison & Video
My tv will scan and receive channels on a antenna but will not pick up channels on a cable scan with a good cable and a proven good cable signal
if you are not using a cable box and trying to connect cable directly to tv you will get very few channels since they are all digital now and most are scrambled
you will need to hook that cable to the input labled 'QAM' and program tv for digital channels
if you are coming out of a 'cable box' you just need to hook up video cables to an input on tv and change tv to that input - no scanning necessary
hope this helps - if not write back with more details and i will try to help more
good luck!
Mar 25, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
How can we view cable TV when the TV doesn't have a tuner?
Ur tv is a digital tv.Just buy a Digital antena or a roof antena hook it up.Go to SETUP menu go down to CH. SETUP pick AIR,not CABLE and than enter to scan.After ur tv done scanning,u will get all the free air DTV channels.
May 01, 2010 | Olevia LT37HVS 37 in. LCD HDTV
How can i hook up this tv without using cable or satllite box
Buy a digital antena.Hook it up.Take ur remote.Go in ur tv menu goto SETUP go down to CH setup.Pick AIR and scan,u will get all the free air channels.That it,u ready to go.
Apr 20, 2010 | Westinghouse W4207 42 in. HD-Ready LCD TV
Rabbit ears to digital conversion box
Your TV is old enough to have not only screw terminals for the antenna, but it sounds like it has separate UHF and VHF terminals as well. Pick up a 75-ohm to 300-ohm adapter (available at Radio Shack and probably most other places that sell TV's and antennas). This is a small cylinder-shaped part with a threaded antenna connector on one end, and a flat wire with two terminals on the other end. Connect the cable from the converter box to the round connector, hook the two terminals to the VHF antenna screws on your TV, put the TV on channel 3 and you'll be set.
You should also pick up a new antenna designed to work with digital broadcasting. If you use the old rabbit ears you were using before, you will probably not pick up all the channels available in your area.
Oct 31, 2008 | GE 35GT740 35" TV
Receive one channel with Coverter Box
Make sure those 6 channels are also being broadcast in Digital format also, otherwise your converter box won't have a digital signal to convert for your TV. The switchover date is early next year I believe.
Oct 10, 2008 | Zenith C27A24T 27" TV
Can't pick up all the signals
I always tell people to carefuly read their instruction manual and consult the product tech support before determing that there is actualy a fault with their unit.
If sounds like the tuner module or the controler board for the tuner may be failing, or there is a power supply distribution fault to the tuner section and or its controler. This has to be service by the manufacture.
One of the criteria I recommend when people buy an expensive appliance or TV is to make sure that there is local authorized service. I also recommend an extended warrany for expensive items. The warranty is like insurance. You may or may not need to collect!
Jerry G.
Apr 17, 2008 | Televison & Video
Dell W4200 42 in. HD-Ready Plasma Television Logo
337 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
gwix50
Level 1 Expert
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
