Question about Mossberg Optics
Mossberg 85d won't feed shells
Magazine holds shells at the wrong angle
  • Anonymous Dec 06, 2017
    I have the exact same issue... I see nothing wrong with the gun, it just won't feed because the shell comes up at the wrong angle. I wish I could find some help.
agent91
  • 2100 Answers
SOURCE: I have a feed problem with my Remington 1100.
You have a shell stop that is either bent or worn, I think there are 2 in there, would have to look. Go to Gunparts.com for the view and order parts, might find them on ebean. Hope th is helps.
Posted on Mar 14, 2010
  • 57 Answers
SOURCE: I recently got a used remington 1100 shotgun for
Is the magazine follower still pushing the shells out of the tube? Or are they just falling out when you depress the little finger?
Posted on May 10, 2010
richroth
  • 9472 Answers
SOURCE: When I fire my mossberg
Normally that would indicate a problem with the ejector and/or extractor. You will need to remove the bolt and bolt carrier and make sure the extractor is clean and operating and make sure the ejector is not broken or jammed somehow. He may need the gun exploded drawing and parts list to determine this. Some Mossberg schematics I have seen lack sufficient detail for a novice to identify some individual parts. If you can't get the extractor out, soke the bolt in something that is made to disolve powder. The extractor is pretty easy to take out. from what i recall no pins hold it in, its all held in under small pressure spring.
Posted on Jan 23, 2011
SOURCE: how do I disassemble the bolt on a mossberg 100 ATR
Apparently the three previous folks have no idea that a Mossbergt 100 ATR is a RIFLE not a shotgun. Regretfully it is a press fit at the rear (multiple splines, pressure fitted into multiple recesses). What that means in English is that it's a factory fix. Sorry!
Posted on Nov 29, 2012
redjack33720
  • 143 Answers
SOURCE: mossberg 500,12 ga. shells will not feed
This will sound sort of stoopid but trust me, more folks do it than you would believe. First thing....push the shell all the way up into the mag tube til your thumb is up the first knuckle. If you only push the shell til you hear the first click, you're only pushing it past the first stop. With it one stop in, a pump will drop it on the floor every time. Simple way to prove that, load three shells into the tube but only load the last one til you hear the one click. Pump it. First hits the floor, rest load perfectly. See what I mean? On ALL pump shotguns, you have to hit both stops so push the shells in up to your first thumb knuckle.
Posted on Aug 05, 2016
How to Install a magazine plug on a mossberg 9200
Read the text here
mossberg manual - StevesPages.com stevespages.com/pdf/mossberg_9200.pdf
  1. Cached
  2. Similar
To install the barrel, unscrew the forend cap and remove the forend (Fig. ... MAGAZINE PLUG - You are responsible for complying with all laws regarding magazine ... Model 9200 is designed to fire 12 ga. shells ranging from 2-3/4" target and.
http://stevespages.com/pdf/mossberg_9200.pdf
There are videos on this here
Install magazine plug on mossberg 9200 Google Search
Oct 28, 2016 | Mossberg Optics
How do you load a mossberg 88 maverick 12 gauge shotgun ?
this is the same for your maverick 88.
Sep 14, 2014 | Optics
Mossberg 817 magazine
Not much can go wrong. Have you checked your extractor? If it's intact and not broken, try moving it with your thumbnail. Is it loose? That's a spring problem. If it's tight and intact, WITH THE BOLT OUT, try slipping a small diam wooden dowel down the barrel to see how hard it is to push a spent shell out. If it's tight, you've got a burr in the chamber or dirt/varnish buildup. Examine the shell for scratches. If the shell's good and no scratches, clean the chamber with a brass brush mounted in a drill.
Apr 21, 2014 | Mossberg Optics
Where can i find a magazine loading chamber for a mossberg 835 12 ga. pump? and how much?
I'm sorry but I don't quite know what you mean, sir. Can you explain a bit?
The 835 is a tube mag pump action. You load it by slipping a shell into that open area on the bottom of the gun, slip the shell forward into the tube until it's thumb knuckle into the tube. That gets it past both shell stops.
Apr 09, 2014 | Mossberg Model 835 Ulti-mag Turkey/deer...
My Mossberg 500 12 gauge shotgun double feeds cartridges and jams
There should be a catch on the magazine tube of the shotgun, is it ejecting two shells into the chamber when you try to cycle the action? If so check to see that the catch is not damaged. I have the same shotgun and I can take a look at it when I get home.
Nov 23, 2012 | Office Equipment & Supplies
How to load a mossberg model 283tb
WRONG!!! A 283TB doesn't have tube magazine, it has a box magazine that's loaded through the breach. Put on the safety, load a shell fully into the barrel. Then press the second shell into the magazine-back end first. Then press the second shell down in the magazine with the third shell, back side first again. Then press both shells in the magazine down until the bolt can be slipped back forward and close the breach.
Mar 06, 2012 | Mossberg Optics
My mossberg 500 drops a live shell without chambering it after the first couple. I have removed the plug to increase the maximum shell capacity. I have kept it full loaded in my safe for several years, and...
Tom, it's been five years on this one of yours. Do you by any chance still need it answered? Just asking because it's a sort of long answer and I'm not quite up to typing it if no one needs the info ;)
Does ANYONE need help on a dropping shell problem with a Mossy 500?
Feb 16, 2011 | Mossberg Sport & Outdoor - Others
How do you load a 12 gauge pump action Mossberg (500)? There is no magazine for it, but, is mag ready. How do you manually load?
The loading port is on the bottom of the reciever. You mention that it is "magazine ready"? Mossberg shotguns have a tublular magazine underneath the barrel, surrounded by the action bar and front grip.
Loading the magazine entails holding the shotgun in one hand, taking the shell in the other with the folded end facing the front end of the barrel. Place the shell in the magazine opening (on the bottom) and push it up with your fingers and forward with the thumb of the same hand. It will go completely forward of the silver/blue lifter and stay there when you let go. (the action must be closed to load the magazine).
Alternately, you can open the action and pop a shell into the ejection port on the right side, close it back up, and shoot!
Sep 17, 2010 | Mossberg Optics
Optics Logo
Top Mossberg Optics Experts
obsteiner
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Mossberg Optic Expert? Answer questions, earn points and help others
