Question about Jenn-Air Premier Line Energy Star Cabinet Depth Refrigerator - Side by Side w/ Prostyle - JCD2295KEP
Clicking sound from rear of Jenn Air Premier Line Fridge
My three year old Jenn Air refrigerator is making a clicking noise. It sounds like a solenoid or relay in the back of the unit, followed by a "electrical type sound". It is cooling and freezing fine. There is no set time for this to happen. Could it be a relay trying to turn the compressor on and it takes a few tries. Is the compressor going bad or is is just a simple relay problem. Any ideas as to what it might be and cost to fix.
    President:
  • 1,902 Answers
Simple relay replacement, if you do it yourself you are looking at about 65 dollars max, you call a repair company you are looking at 245 or more
Posted on Feb 09, 2009
Bull BC-130 compact fridge won't cool anymore
hi clicking sound is not goood.sounds like the motor is gone.but try basics first.clean condensing unit.ventilate.check refrigerant and motor relay.good luck.Ali
Jun 24, 2012 | Refrigerators
Warm fridge making clicking noises
first unplug the machine that clicking noise you hear is the start relay on the compressor you should definetly call a technician. YOU can find one by typing into google for appliance repair and the town you live in
Apr 28, 2010 | Jenn-Air JCD2389G Side by Side...
Buzzing/humming noise with jenn-air bottom freezer
i have this problem too on my GE Profile. A youtube video seems to suggest a compressor problem. Turn off the fridge for a while and let it cool down and try again? I tried but to no avail. Would someone answer this? Please :)
Mar 21, 2010 | Jenn-Air Refrigerators
Buzzing and clicking sound every few minutes
Compressor start relay - white plastic part - sitting right on the compressor, disconnect it shake it - u'll here it if it's damaged. :)
Oct 01, 2009 | Jenn-Air JCD2389G Side by Side...
Our Jenn-Air French Door bottom freezer refrigerator is making a noise like it's breathing while sleeping. Kind of a wheezing noise. Do you know what this might be and what to do about it? I think it...
This might be a normal noise. when they switched to 134a refrigerant, they had to develop a new oil. This new oil comes over or circulates more easily then the old oil. The oil and refrigerant flow through a capillary tube under 180 psi to the evaporator where it expands. the noises from this process can sound like tapping, chirping, clicking, squealing or wheezing. A hot day, a dirty condenser or when the unit comes out of defrost will make the noises more noticeable.
Aug 27, 2009 | Jenn-Air JFC2089HP Bottom Freezer French...
Clicking noise from JCD2295HES side-by-side refrigerator
sounds like a compressor relay check with maytag mightr be one of the recall ones
Mar 17, 2009 | Jenn-Air JCD2295HES Side by Side...
Freezer not working , clicking noise coming from fridge
Clicking was a relay. Replaced relatively inexpensive relay and now working fine.
Jan 17, 2009 | Jenn-Air JCD2389G Side by Side...
Maytag refrigerator clicking noise and stopped working
How long a period of time have you noticed this noise? If it just started and the refrigerator just stopped it could have entered its defrost cycle. When the defrost heaters come on you may hear the heat causing some expansion. After a few minutes(18-22) the defrost cycle ends and the refrigerator will restart.
May 30, 2008 | Jenn-Air JCD2389G Side by Side...
Ice Maker Making Noise
sounds like your icemaker is jammed.
first ofall just feel around the icemaker and see if you can find a peice of ice jamming it that you can remove. if that doesnt work heat it up with a blow dryer until any ice that is there will melt away and it will free up..
there is one other possibility: the stripper could be jammed against the side of the icemaker in which case you'll have to remove the icemaker from the refrig and unjam it..
hope that helps and good luck
Dec 15, 2007 | Jenn-Air JBL2086HES Bottom Freezer...
Refrigerators Logo
126 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
