Question about Dell 962 Photo All-In-One InkJet Printer
Showing carrier is jammed. no paper blocking it.
Showing carrier is jam. no paper blocking it. indicator says clear carrier.
Showing carrier is jammed. no paper blocking it. showing carrier is jammed. no paper blocking it. - button1-share.gif
Posted on Feb 09, 2009
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
How to clear paper jam 11 paper is cleared but still indicates that its a jam
Then properly the sensor near the jam had it accurator jammed so the copier thinks there is still a paper there. or you mite have paper dust or dust blocking the sensor. Could also be a bad sensor worst case bad main board.
Aug 14, 2014 | Konica Minolta bizhub Office Equipment &...
Dellv305 printer, clear carrier jam. My son pulled the paper out from the bottom of printer. How do i clear carrier jam?
Please perform the steps mentioned in the link below:
Paper Jam
The steps would help resolve the carriage problem as well.
Jun 17, 2010 | Dell 926 All-In-One InkJet Printer
Paper Jam
You need to try clearing the paper using a airblower if you do not have a air blower try with a vacuum cleaner, surely it cleans up. Unless until you remove the paper it shows the msg.
If you think you have no other option and you tried everything its better to call some service guy and get it done.
Regards
Oct 03, 2009 | Office Equipment & Supplies
Error message on printer: It says to clear the carrier jam; what is a carrier jam? How do I clear it?
Make sure the paper is out where it was jammed. Unplug the printer from the wall for thirty seconds and plug it back in.
Aug 30, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Not working see bottom
Check your entire feed to make sure there is NO paper jams. Sometimes even the smallest little piece of paper can get jammed up and can e hard to see.
You can also check your manual for diagnostic mode and alignment print page.
May 13, 2009 | Dell 926 All-In-One InkJet Printer
Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
Hope this helps....
Explanation of the paper jam message
A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
Clearing the jam
To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
Remove any jammed sheets of paper you find and try printing again.
Dec 12, 2008 | Lexmark T640 Laser Printer
How to clear carrier jam in Dell Photo All in One 944
simply open up your printer and see if there is any residual paper that get stuck, in some case if you can find some small miniature piece of sensor it might cause a erratic sensing that there is a presence of paper while there isnt, try to clear this or clean.
paper jamming indicator means there is some paper in the paper path, unless otherwise ou clear this up you cannnot print.
after you may need to power down or restart your printer once again
cheers
Nov 27, 2008 | Dell 924 All-in-One InkJet Printer
Paper jam
if you cleared the paper jam an your printer still shows this paper jam, you may try this:
1. after you clear the paper jam, turn off an on the printer.
2. if above advice is not working you may try to look more carefully (with a flashlight maybe) if a small piece of paper is not blocking the paper jam sensor.
3. unfortunately this is a job for a qualify serviceman.
4. in less then 2-3 % of cases is a defective sensor, and must be replace by a serviceman.
Sep 23, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Dell 962 Photo All-In-One InkJet Printer Logo
420 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
