Question about Philips GOGEAR SA6045 MP3 Player
It froze and the reset wont work
I have a phillips gogear mp3 4gb's it froze and the repair instsructions on this site isnt workin and it wont pass the upgrading point
This is james again my email is jamesboggs18@yahoo.com mine is 8gb the name is philips it is going to a white screen it will not let me acsses the music it turns on to a white screen thanks......James Boggs
Posted on Feb 10, 2009
My philips gogear vibe 8gb is brand new. I charged it and put on music and it was fine for an hour. But now it freezes on the 99% updated screen. I reseted it and i can still usb connect it but after it...
Firstly, I'd suggest that you do a soft reset of your player. You will find the reset button next to the 'power on' button on the side of the player. Please hold the Reset button using a pen tip or other sharp object for 10 seconds. Now turn it on.
If that doesn't work, you can format the player. Provided its recognized by the computer. Contents may be removed by using this function. So make sure to back up your contents. Here is how to do this:
Connect your GoGear player to your PC. On your computer desktop, double-click "My computer". Double-click on the MP3 player's icon. Right-click on the Internal Storage icon and then select "Format". Disconnect it once the format is complete.
If that doesn't work, you can repair the player. To repair it you must have the software that came with the player or you can download it from the Philips suppot site. WWW.philips.com/support/. Players that start with SA1xxxx uses Device manager and the Players that start with SA2xxx uses Philips Songbird.
Here is how to Repair your GoGear MP3 player using Device Manager:
Launch Device Manager and click the Tool menu and select "Repair my Philips GoGear", then follow the instructions to perform the repair process.
Here is how to Repair your GoGear MP3 player using Philips Songbird:
Launch Songbird and then connect your player to your computer. Select "Repair my Philips GoGear" under the "Tools" menu. Follow the instructions given by the pop-up windows to perform the repair process.
*Contents may be removed by using repair and format functions. So make sure to back up your contents.
Hope this helps.
Cheers..
Feb 27, 2011 | Philips GoGear ViBE Digital Media Player
My 16 gb gogear froze
1 On your computer, select Start >
Programs > Philips Digital Audio Player
> Aria Device Manager > Philips Device
Manager to launch the Philips Device
Manager.
2 Turn off GoGear Aria before you
continue.
3 Press and hold the volume button
while you connect GoGear Aria to your
computer.
4 Keep holding the key until the Philips
Device Manager acknowledges GoGear
Aria and enters the recovery mode.
5 On the computer, click the Repair
button and follow the instructions of the
Philips Device Manager to complete the
recovery process.
6 When the recovery is completed,
disconnect GoGear Aria from your
computer.
7 Restart GoGear Aria.
The full manual is found here: http://www.p4c.philips.com/files/s/sa1ara16k_17/sa1ara16k_17_dfu_aen.pdf
Oct 29, 2009 | Audio Players & Recorders
Phillips Gogear SA5285/37 is frozen
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Mar 08, 2009 | Philips GoGear SA5285/37 Digital Media...
Phillips mp3 player froze up on the gogear screen.
-Tha Mp3 Doctor
Feb 26, 2009 | Philips Sport Personal CD/MP3 Player
My philips 8g mp3 player
Reset the player by inserting a paerlcip into the reset hole. If that fails, go to Philips' website and upgrade the firmware on your player to solve the freezing issue permanently.
-Tha Mp3 Doctor
Dec 31, 2008 | Philips GoGear SA5285/37 Digital Media...
Phillips go gear 8gb
Reset the player by inserting a paerlcip into the reset hole. If that fails, go to Philips' website and upgrade the firmware on your player to solve the freezing issue permanently. Actually, don't go to Philips website - run the Philips Device Manager and select Update. If the device manager won't recognize the player, unplug the GoGear, hold in either the shuffle button or volume + and reconnect it to the computer until a Found New Hardware Wizard window pops up.
-Tha Mp3 Doctor
Dec 29, 2008 | Philips GoGear SA5285/37 Digital Media...
Phillips go gear SA5125 mp3 player
Make sure you are using the original USB cable that came supplied with the GoGear, and then try the volume + method again. If the volume + method doesn't work, then there is a problem with the USB port recognziing the device being plugged in - or, the player was physically damaged.
May 29, 2008 | Philips SA5125/37 MP3 Player
Device manager wont detect my gogear HDD1630/17 even though i recently updated the software and driver, also my device is frozen on "Please connect player to pc". I can't even get it back to the menu...
I was experiencing this similar problem, and from my research so were alot of other people, what finally worked for me was this:
  • Update all the software on your computer via Phillips site
  • Open the Philips Device Manager
  • With the device connected and the 'connected to pc' screen showing on the GoGear, do a 'soft reset' by holding the Power Off + Volume Up buttons for a few seconds
  • As soon as the device restarts itself, hold the Volume Down button, the computer should now recognize the GoGear
  • Follow the onscreen directions to Repair the device
  • Thank the intarwebs.
May 21, 2008 | Philips GoGear HDD6330 MP3 Player
Phillips gogear wont let me format or repair please help
a good old smack on the desk and plugged it in a differnt usb slot a few times and it just worked. these phillips things are so dodgy!!!
WHACK IT ONE!! lol
Apr 05, 2008 | Philips SA5125/37 MP3 Player
8GB GoGear isnt working at all
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
Dec 17, 2007 | Philips GoGear HDD1830 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
247 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
