Question about GE Refrigerators
Water Dispenser Intermitantly Squirts Water
Water dispenser squirts approximately 3 oz of water every 2-3 hours automatically (i.e. when i'm not pressing the dispenser). Other than appearing ''possessed'', the water dispenser and ice dispenser appear to work fine.
roadbird383
  • 40 Answers
SOURCE: Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Posted on Dec 05, 2007
  • 1073 Answers
SOURCE: ice dispenser flap won't close automatically
replace the flap spring and selenoid in the despenser area
call ge at 300-851-6200 with the model number and they will send you the parts about 40.00 dollars
Posted on May 07, 2008
maklean
  • 1665 Answers
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
aborcass
  • 2651 Answers
SOURCE: water leak
as for leaking underneath sounds as if the water line if cracked, or the connectore is loose, sounds like a simple repair, as far as the water squirting from back of frig, sounds like the fill tube leading into the ice maker itself has froen and the back pressure is causing it to leak. remvove the hose again and possible fro the inside usea long thin crew driver and try to clear the ice blockage, ( some tubes are removeable in which case you can run under the sink to thaw out
Posted on Jul 09, 2008
SOURCE: water dispenser makes cluking sound
I set fire to my house and claimed the fridge on insurance.
however I was uninsured and now require financial assistance.
please send
1. $2950 so i can buy a new fridge
2. $0.05 if you are concerned about my mental health
3. an insult if i am wasting your time.
rgds..John
Posted on Jan 07, 2009
Water dispenser squirts water in different directions
Hi, Get a light and look at the water jet. You maybe able to bend it back in to place. Be very careful with plastic parts. They can break.
Good luck.
Jul 27, 2015 | Refrigerators
How can I fix the water dispenser that is not working properly?
If you can pull out the fridge and check the valve to be sure it is open all the way. Next, change the water filter if you haven't changed it in the last 2 months. The only other suggestion is to make sure the line didn't get kinked where it feeds into the door (usually right at the hinge).
May 01, 2014 | Fisher Paykel Fisher & Paykel RF195ADUX1
Ge fridge- water dispenser in door wont work yet ice maker does.
There are a few reasons for this. Most common, is the water filter. After a period of time(literage usage) the filter eventually blocks up.Flow will not continue until a new one is installed. On occasion, the water line in the freezer ices up, but doesn't often happen. If so, you will need to defrost freezer until pipe is no longer iced up(set freezer to about -20 degrees celsius).or very possible, water solenoid at the back of the fridge has gone faulty.You will need help with this check,There will be 2 valves. Very possibly it will be the RHS one at the back. Switch water supply off at the back then go to the water solenoids at the back of the fridge.and disconnect the one pipe on the solenoid that leads into the fridge. Open fridge water tap again and ask member to quickly press water dispenser lever.Note if water squirts out for that brief period.. If not, reconnect pipe again then do the same disconnection to the second solenoid. If no water comes out then,(make sure water is open), then the water valve needs to be replaced.
Oct 04, 2009 | GE Refrigerators
Water dispenser line disconnected opposite end of valve.
look behind the kick plate at teh bottom front of the unit.if you've recently moved the unit it could be trapped back up under the unit somewhere. there should be a slipp in or compression connector for the loose end to connect too..
Jan 21, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water has stopped coming out of the filtered water dispenser
I just had this same problem and finally figured it out. The water in the line was frozen because my freezer was turned to 6 (note on inside of freezer says recommended temp is 4) so I turned the freezer to 4 and the refrigerator to 3. Next day the water was flowing.
Hope this fixes yours,
Sherry in Pittsburgh
Jan 10, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water dispenser makes cluking sound
please send
rgds..John
Jan 07, 2009 | Whirlpool ED2FHEXN Side by Side...
Water Dispenser with mind of it's own
one test is too turn off your ice maker and it will stop...you have a bad diode on the water line and are getting line feed from the ice maker...
to fix it you will need a new diode
#5303918287 DIODE KIT
#5304418384 DIODE KIT
the parts store will get you the correct one with a model and serial number of the refrigerator
let me know if it helps
Nov 03, 2008 | Frigidaire Refrigerators
Water leak
Jul 09, 2008 | Refrigerators
Ice and water dispenser not working
ALWAYS MAKE SURE YOUR APPLIANCE IS UN PLUGGED BEFORE TRYING ANY PROCEEDURES !!!!!! MAKE SURE THE WATER SUPPLY VALVE (SOMETIMES 1/4" SADDLE TYPE PEIRCING VALVE) IS NOT CLOGGED WITH SEDIMENT... THEN MAKE SURE THE WATER SOLENOID IS NOT CLOGGED AS WELL ... THE WATER SUPLY SOLENOID HAS A SMALL ORFICE THAT CAN BECOME PARTIALLY CLOGGED OR DOES NOT "SEAT PROPERLY" AND CAN CAUSE INSUFFICIENT WATER SUPPLY AND THUS ERRATIC OPERATION. A LARGE PERCENTAGE OF WATER DISPENSER AND ICE MAKER PROBLEMS ARE DUE TO INADEQUATE WATER SUPPLY. IT IS THE FIRST THING THAT NEEDS TO BE CHECKED !!!
Apr 26, 2007 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
