Question about 2wire Computers & Internet
Ethernet keeps connection, wireless randomly drops
I have a 2wire 2701hg-b , and basically the wireless will randomly drop in a period of 30 second to several hours. I've tried with multiple broadcasting ID's and encryption types to no avail
  • 1,226 Answers
Try resetting your wireless and then configure it in a default option.
may this help.
Posted on Feb 09, 2009
2wire 1701 hg dsl connection drops when laptop is connected via wireless
This is a known issue with this model.. The power supply is not large enough to handle the extra current that is needed when the unit broadcasts on wifi.
May 05, 2017 | 2wire Computers & Internet
My iphone keeps dropping the "password" for my 2wire router. Then anytime I do something that requires the router to do some things it shows that Im NOT connect to my Wi-Fi in my house. How...
first check for any computer that is connected to you modem.
try to access your modem gui or software
since you have a 2wire modem go to the wireless setting page
then configure your wireless settings
you can call your isp for the correct wireless setting configuration
May 27, 2011 | 2wire (2701HG-B) Wireless Router
Having problems with 2wire router that keeps dropping the internet. All light are on except ethernet, does this mean the router is no good. Recently replaced the power cord which helped for awhile.
how do you connect to your router? If there's no ethernet cable plug in on the router, the Ethernet light on your router is suppose to be off. Also try to move your router 2-3 ft. away from any electrical devices like wireless phone, printer etc. because of electromagnetic interference. It may help your wireless connection to be stable and faster.
Jan 09, 2011 | 2wire (2701HG-B) Wireless Router
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
How many computers can the router handle?
The 2701hg-b Wireless Access Point (WAP) has 4 ethernet connections, that's the physical limit, for that, unless you "cascade" a bridge or another router off of a port.
It also supports wireless. I know of no documented limit as to the number of concurrent wireless connections... there probably is one, but it isn't "published", that I know of.
The "real" limits on the wireless side are "activity" and "channel" conflicts.
The "activity" conflict factor has to do with how much somebody/anybody is using "doing" with your WAP. Sooner or later, you'll see "saturation" of the wireless bandwith.
The "channel" conflict factor usually occurs when there are two (or more) WAPs (or other wireless devices) within "range", that are using the same "wireless channel".
From the "user" perspective, the effects of "conflict" are similar to "saturation", except that you'll likely see more "dropped connections" with "conflict".
Nov 10, 2010 | 2wire (2701HG-B) Wireless Router
My 2wire router 2701 HG-B drops the wireless connection when someone calls on the home hard wired line. Is there something wrong?
Your wall filters may be plugged in wrong. Verify they are plugged in correctly. This is likely the problem.
Oct 01, 2010 | 2wire (2701HG-B) Wireless Router
I have a att 2wire wireless router and it keeps dropping the connection constantly its the model 2701hg/b Ive had the router for over a year now what is the basic lifespan of these routers Ive had a tech...
I was having the same issue. I noticed a lot of 2wire networks in range, so I thought that interference might be an issue. I went into my router wireless configuration, and changed the channel from "AUTO" to a different channel...set it to 11, I think. Since then, I have had NO issues what-so-ever. Hope this helps!
May 30, 2010 | 2wire (2701HG-B) Wireless Router
Lose connection to internet at random times
There could be several things that can cause this problem, ranging from low signal strength, electrical interference, clashes with other wireless routers in your area etc.
Please click on this link and follow my instructions for possible solutions to your problem :-
May 12, 2010 | 2wire (2701HG-B) Wireless Router
2Wire 2701hg-b dsl modem
Have you verified the unit is secured. It sounds like someone is hijacking the unit and resetting the configuration.
Please post the configuration here and I will tell you what is going on. DO NOT SEND ME YOU USERNAME OR PASSWORD, as well as any DMZ information you may have setup.
Oct 08, 2008 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
229 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
