Question about Fisher and Paykel Dryers
Dryer takes MUCH longer to dry clothes than it should
Fisher and Paykel dryer worked great for months and now seems to take way to long to dry a load. Like hours vs 45 minutes. It is blowing heat from the exhaust and when the lid is opened the clothes are still wet during the cycle. When it does finally stop the clothes are dry. What can cause it to change slowly over time as it has? The lint catch is cleaned every load and sometimes during a load..thoughts?
Thanks for the help in advance!
  • Scott Taylor Feb 09, 2009
    yes, it is a bit. but not totally closed off. Could that be the issue?
    Thanks so much for the quick solution!
    President:
  • 1,902 Answers
Is the hose crunched down at all in the back
(vent hose)
Posted on Feb 09, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 09, 2009
    YEs I would try to straighten that out, the passage way has to remain in the 3 to 4 inch diameter at all times,
  • Jeremy Reddick
    Not a problem good luck
Fisher and Paykel dryer dries clothes on medium heat but shuts off repeatedly if I set it to normal dry setting.
you probly have a venting problem disconect the vent from the dryer and try it see if it works ok if so get someone to clean vent ducking out.
Mar 26, 2014 | Fisher and Paykel DEGX1 Electric Dryer
My dryer will not shut down or advance when it is in the Automatic Perm. Press mode. Diagnosed with faulty timer, replaced yesterday for ~$300 and the dryer ran all night long. Is there a "dryness sensor"...
I have found that the permanent press cycle will continue to roll the clothes around on a rest and dry schedule until you take the clothes out and manually shut off the dryer. The idea seems to be to keep the clothes from wrinkling when sitting in a still dryer. I think that this is the way it was meant to work, but I am no expert, just another owner of a Fisher Paykel dryer.
Oct 15, 2010 | Fisher and Paykel DE06 Electric Dryer
Auto dry not cutting off when clothes are dry
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem. Your problem should either be dirty or bad connections with the contact continuity plates, the chrome things under the lint bucket or the control circuit.
Oct 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Top load Fisher Paykel dryer doesn't get real hot and therefore is very slow to dry clothes. I've checked the lint filter and the exhaust pipe is clear, so air is moving freely through. It seems it must...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Fisher and Paykel SmartLoad DG62T27G Dryer
Do the Fisher Paykel Dryers DGGX1 take twice the drying time of a normal (Kenmore) dryer to dry cloths? I put in a load of towels and after an hour and a half they still weren't dry. My other dryer would...
make sure there is no lint build up inside the round housing where your lint trap goes. the holes in the housing sometimes plug up and you can't see it. one screw at the bottom and rotae slightly to remove. also make sure vent is clear
Jun 26, 2010 | Fisher and Paykel DGGX1 Electric Dryer
No heating
Greetings,
The heating elements do not cost $200 USD buy $80 for both; available online from the most common Fisher-Paykel parts supplier.
Good luck
Apr 13, 2010 | Fisher and Paykel SMARTLOAD DE62TG1...
My Fisher Paykel dryer DEGX2 WAS TAKING LONGER AND LONGER TO DRY CLOTHES AND THEN JUST STOP DRYING-DOESN'T GET WARM. THE HEATING ELEMENT WAS REPLACED ABOUT 7 MONTHS AGO. IS THERE A RESET BUTTON IN THE...
Hi.
There is no reset circuit.
Parts that must be tested are high limit thermostat and timer board.
The timer board is replaced if it is visibly faulty, or if there is no problem elsewhere.
The high limit located near to the element is tested reading impedance with a multimeter set at Rx1. If there is no continuity , the thermostat must be replaced.
Before testing parts check the lint filter, and ensure that air ducts are clean.
Regards.
Nov 13, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Open Questions:
Dryers Logo
341 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
