Question about Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator
Model #10657058791 freezer and fridge not cooling
I moved my side by side to another house and now the freezer and fridge won't cool or freeze HELP
  • 3 more comments
  • panamadrid Feb 09, 2009
    just while putting it in the truck but never laid it down or on it's side
    will i need to take anything off the back to see if any wire are loose
    I went to check the back but decided to check cooling first and seems to be working I had turned up the thermostat to high to see if that works could this fix the problem?
  • nfs61488 Mar 13, 2009
    same problem here but i didnt move the the unit around or lay it on the side or any thing i jut shut it off to clean it and when i turned it back on. but after that it wont get cold in the freezer or the refredigetor. sorry for the spelling mistakes.
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    Did you lay the freezer down at all on its side or anything to be on its back or side for a extended period of time
    President:
  • 1,902 Answers
Check your connections in the back make sure no wires are lose or rattled lose off of the compressor or anything like that
Posted on Feb 09, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 09, 2009
    No you shouldnt, but while unplugged also check the wires on the compressor
Freezer works not fridge
move the temp sensor see side of inside of fridge
Jun 24, 2013 | Dometic RM2652 Refrigerator
Fridge won't cool but freezer working fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
Fridge not cooling whirlpool model gd5rhaxn000
Aug 28, 2011 | Whirlpool S20DRSS33 Side by Side...
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
My kenmore fridge model 56723 is not cooling that is the fridge side. the fan is spinning very well but the compressor is very hot. funny enough the freezer appears to be cooling okay
Jul 23, 2011 | Kenmore 56723 Side by Side Refrigerator
Fridge side not cool and freezer side cooling like a fridge
Most likely a defrost problem. Are you sure your model is the model posted above your post? RS2630SH If not please let me know the correct model number. I have most of the manuals on the Samsung..............Sea Breeze
Jun 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
Amana 'side by side not freezing slightly cool
sounds like you have a restriction in your filter drier. or you could be low on freon. both sealed system issues. you need an appliance tech to check your cooling system
Apr 12, 2009 | Amana ARS2464B Side by Side Refrigerator
Freezer not cold but fridge is cool
quickest and cheapest way is to switch the unit off overnight. possibly missed a proper defrost cycle and evap.coil is blocked. when properly defrosted,switch on and you could be back on line
Aug 09, 2008 | Whirlpool GS6NBEXR Side by Side...
Maytag fridge
Without knowing the type of fridge(side by side, freezer on top etc.) all I can offer is this: Somewhere between the freezer and the fridge there's an opening thermostatically controlled to transfer cold air from freezer to the fridge. Most have a fan to move the air. So either the fan (if so equipped) stopped, and need to replace, or opening is stuck closed, or plugged.
If freezer is working fine, this is the only problem I can think of.
Hope this helps
Dec 15, 2007 | Maytag MTB1504A Top Freezer Refrigerator
Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator Logo
198 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
