Question about Toshiba Satellite A135-S2276 Notebook
Satelite A135 wont recognize hd
Turned off lap and when turn back on it wont boot, keeps rebooting. checked and it doesn't see hd
  • stevereeno May 11, 2010
    Have you tried the Toshiba System Setup? Usually you have to push a key during the initial boot screen to get there. If you have a manual, it should say something about how to check those settings.
    Otherwise, do you have a Windows installation CD or DVD? If so, put that in and see if the system can load it. The Windows installer will then try to locate the hard drive, and might be able to tell you if it has problems. If so, turn off the system and get it to a technician. DO NOT let Windows go on thru the installation or it might reformat the drive and you could lose all your data.
    Sergeant:
  • 366 Answers
This page solution worked for me.
Some CD burner sw is creating this issue: they monopolize the optical drive and if you remove or if they have a prioblem, CD/DVD drive is NOT released.
Posted on Feb 09, 2009
Boot failure insert system disk, but it wont load
You need to check both in BIOS by pressing F key during boot. First check to see if HD is there. If OK, then change Optical drive to first boot, save and reboot.
IF MISSING HD -
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and re-seat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Dec 07, 2012 | Computers & Internet
Satellite a135-s2386 will not boot when power is turned on black screen
Does it make a beeping sound when you turn it on? If it does try this: Turn it off and take the battery out for about 2 minutes. Put the battery back in and press the power button to turn on. Immediately tap the F8 key on your keyboard. This should bring you to the advanced boot options. Choose last known good configuration.
If that doesn't work you may also try choosing system restore in the advanced boot options and follow the instructions. Note that a system restore brings the computer setting back to a previous restore point and will removes all changes after that chosen date.
I hope this helps. Cheers,
Sep 12, 2011 | Toshiba Satellite A135-S2386 Notebook...
Wont recognize ide drive on startup
When you boot,go into the bios. In the main section see if your drive is listed.
If not, turn off machine, open unit, check power and data cables
Harddrive are blue data cables. Also check to see if HD is slave or master. Jumper switches on HD. Clse unit and boot up into bios
in the main you should see you HD
in boot sequence.. see if you c:/ is in the list
bios will tell you how to put in list if not there
close and reboot
Jul 25, 2010 | Dell Dimension 4550 PC Desktop
Unable to install XP OS to MSI lap top
Insert your installer to the lap top then try to change the boot up priority by entering the bios. Try to press del key while your lap top boot. If these deosn't wok try F1 or F2 thesame process. If you have enter the BIOS, look for the boot priority which includes the First Boot, 2nd Boot and 3rd boot. Change the 1st boot to CDROM and the 2nd boot to hardisk. Then save the changes by pressing F10. your PC will reboot and it will direct you to the OS installation.
Mar 29, 2010 | Computers & Internet
I upgraded my memory per Toshiba's website - installed the memory and the system will boot up, but then the screen goes blank - you can see the cursor, but nothing - I removed the memory and put back in...
when makes changes on memory ...always reinstall .and first go to bios and restore factory defaults ...optimal factory defaults ...
this will do to recognize the new modules ...and installing will aware the system about the changes..
Nov 13, 2009 | Toshiba Satellite A135-S2386 Notebook
How do i install my recovery disc on my toshiba satelite A135-s4527, nothing is working right on it and i dont know how to use the cd
Make sure that your first boot option is CD and second boot option is Hard Drive. You can do this by entering Setup when you boot up your computer. Computer manufacturers use different options for entering Setup, the most common being either by pressing F1 or F2 or DEL.
Once in Setup, go to the Boot tab and check the Boot Device Sequence. If Boot from CD is not first, you need to follow screen instructions to change it. Then, 'save and exit'.
While your computer is on, open the CD drive and insert your recovery disk. Then, turn off your computer.
Reboot and your recovery program should start automatically.
MAKE SURE YOU BACK UP ALL OF THE FILES YOU WANT TO KEEP BEFORE DOING ANY OF THE ABOVE STEPS!!
Oct 08, 2009 | Toshiba Satellite A135-S4527 Notebook
Satelite L505 powers up then steady beep/won't
Remove and re-seat the memory (RAM) modules.
The task is non-destructive / harmless.
Sep 28, 2009 | Toshiba Satelite A135-S2286 Notebook
My toshiba s\atelite a135-s4527 wont turn on and
Could be the "resume" battery that has died - its an internal battery shrink wrapped in bright green plastic on tosh's normally - you might be able to get to it by unplugging stuff, battery, cd rom etc etc....unplug it and plug it back in again, if it comes alive again order another. I went on a toshiba laptop maintenance course years ago with a company that i worked for and that error that youre seeing was the fix....see if that works...
Aug 07, 2009 | Computers & Internet
My toshiba L25 won't reboot
dont press any key....dude.....if your windows is still working fine...if you want to disable that booting from cd...check this out..
1. reboot laptop and press F2 to bios setup
2.select the boot settings in the bios
3. in the boot order..make the first boot device the HDD and second the cd drive and third whatever you want..
to change press F5 or F6
and save the setting you've make and reboot the laptop
Jan 04, 2009 | Toshiba Satellite A135 Notebook
TOSHIBA satelite wont turn on
If you have tried a new power supply and taking out the battery and it still won't start, then the problem is with the power management system on the motherboard. This means that the motherboard will have to be replaced. Check into your warranty, being that it's only 10 months old, it should still be under warranty. If so, then get it to them to be fixed asap, before they decide your warranty doesn't cover it.
Jun 26, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
96 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
