Question about Denon AVR-1506 Receiver
Denon AVR 1506
I own a Denon AVR 1506, I had it blasting for extended amount of time and now my front panel looks dead but all fuses are good also there is no sounds coming out from all speakers. I was just wondering on how to reset it. Any input will be greatly appreciated.
  • Dexfeezy Feb 09, 2009
    lynchms, There is no PCM nor Auto button only LED but pressing Input mode switches to PCM, Auto or DTS. Is there any other way to reset.
    Thanks in advance!
    Scholar:
  • 93 Answers
Try this, turn off the unit and remove the AC power cord from the electrical outlet, Hold the AUTO button and PCM button and plug the unit back into the electrical outlet, if the display starts flashing with 1 second intervals then release the 2 buttons, this initialized the microprocessor
Posted on Feb 09, 2009
  • Mike Lynch
    Mike Lynch Feb 09, 2009
    Yes you can turn off the power switch, then press both A & B speaker button and keep them depressed while you turn on the units main power button, this initilized the microprocessor, theLED should flash.
Denon avr-1506 will turn on then flash red and turn off... how do i make it stop or fix it??
In most AV receivers if the standby light flashes after turning on and you don't hear the regular click of the relay engaging after 4 seconds, indicates an output short or amplifier failure. The protection circuit prevents any further damage by not turning on system.
You will need professional help to fix this problem because even to a electronic enthusiast the construction of a typical AVR is not service friendly.
Jul 01, 2011 | Denon AVR-1506 Receiver
The green light flashes when power is turned on and then flashes red and turns off. Can this be reset ?
what do i do when my DENON AVR-1506 turns on then flashes red and turns off?
Mar 08, 2011 | Denon AVR-1506 Receiver
Unable to get my sub to work with my Denon AVR 1506 Receiver
Did it ever work? Are you certain the sub is getting a signal. It has to be defined. How about the speaker levels adjustment? Did that work? Give us a clue.
Jan 28, 2010 | Denon AVR-1506 Receiver
Power wont come on at all
May be the power supply check for power to the power supply and the output voltage from it as well !! May need to be replaced ! It cost $125.00 for part and $225.00 for a new one installed !!
Jul 21, 2009 | Denon AVR-1506 Receiver
1 Solution for denon 1506
have the same deal go'ing on here, one of the cables were shorting out and never could figure it out
Apr 15, 2009 | Denon AVR-1508 Receiver
Connecting 2 sub woofers to denon 1506 receiver
Most receivers only handle one sub at a time. If you are deadset on connecting two, you might want to consider how much power your receiver will give to each if you split the signal then determine the power of each sub. If the subs aren't the same you can be sure they will sound strange.
If they are identical and your receiver has enough power to handle them both, examine the connection the subs use to connect to the receiver and split the connection by buying a splitter at a local radioshack.
You will probably be better off using the better of the two subs instead of having both connected. Your sound quality will be more balanced and clear when it comes to bass.
Mar 03, 2009 | Denon AVR-1506 Receiver
Problem with Denon AVR 1508 in DTS NEO 6 Format
WHAT TYPE OF AUDIO CONNECTION IS USED FRON THE SAT TO THE DENON? IT HAS BEEN MY EXPERIENCE THAT YOU MUST CHECK THE OUT PUT FORMAT OF THE SAT OR EVEN USE A COAXIAL OR OPTICAL CABLE AND ON THE FRONT OF THE DENON PRESS THE INPUT MODE BUTTON TO DISPLAY AUTO
Sep 24, 2008 | Denon AVR-1506 Receiver
Protection on display
disconnect everything from the unit and see if it still does it.
if it does i would check the output transistor (ic).
Jan 25, 2008 | Denon AVR-1506 Receiver
Sound Stops
Dec 29, 2007 | Denon AVR-1506 Receiver
Denon AVR-1506 Receiver Logo
532 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
