Ran out of two or three ink cartridges at once... replaced all... not getting correct color... seemed to be 'missing' red so suspected a faulty magenta cartridge and replaced it... still not printing color correctly
In both cases be sure using correct ink. Use of generic ink can lead to leakage of catrridge seats do to crossion from inferrior ink quality (per Cannon). Be sure ink in proper locations - see manual. Run the maintenance proceedures: cleaning then print nozzle pattern. If all colors are not proper after two or three cleanings, perform deep cleaning. Print nozzle pattern after each cleaning. This should clear up problem. If not, print head may need replacement.
I also put all new cartridges in and don't get much of any color. Mine is a Pixma iP6000.
I try to print images with red and they comeout pumpkin yellow! My cartridges all have in, there is no tape on them, they all seem to be snapped in correctly.
HELP!!
Is it difficult to replace the print head?
The Problem of Canon printer not printing in color properly or Canon printer not printing can be caused by an outdated driver, low ink cartridge, clogged print head, and many more.If you don't know how to fix it then you should either call-1-888-260-1297.
