Olympus AS-2000 Dictation Kit - Foot switch doesn't work on Vista
I have the above dictation kit - worked fine when I was running Windows XP but the foot switch doesn't work on Vista. Have CD - loaded in ok and everything works except foot switch. Have searched everywhere including the Olympus web site to see if there is a driver or something to correct the problem, but no luck. Need to resolve asap because I have work piling up. Need help quick!!
Problem with Olympus AS-2400 PC Transcription Kit
I saw the AS2400 is compatible with Windows XP/2000/Vista.
You can install Windows XP in your computer (I presume you have a 4th Gen Intel processor installed in it) and run this software under Windows XP.
On the Windows 8.1 Help and Support, search: Windows XP
Mar 07, 2014 | Olympus AS-2400 PC Transcription Kit
Software not compatible with Vista
Try running in compatibility mode for the program. Go to the program thru Start menu, then right-click. There you will see the compatibility mode Tab or choose properties.
Jul 30, 2009 | Computers & Internet
RS-25 foot pedal not working
The foot pedal needs to be plugged in before the software is installed. Just uninstall the software (your files will be fine) and reinstall with foot pedal attached.
Feb 17, 2009 | Olympus RS 25 (147035)
HTML clipboard Olympus AS-2000 is not Vista compatible, you need to upgrade your software, I am not sure which version you have, but I think its version 6 ? You need to upgrade your software from version 6 to 7 (free) and then from version 7 to Standard (also free ) . check your foot pedal if it's RS-23 ( check the back of it ) then you need a new foot pedal ( RS-25 or RS-27 ) , if you have the RS-25 or RS27 you are ok .
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1219&os=w
Hope this will help
Joseph
Feb 09, 2009 | Olympus AS-2300 PC Transcription Kit
Foot pedal
Make sure you are installing the Transcription version of the software not the Dictation version (Transcription version serial number starts with RTM and dictation starts with RDM). The foot pedal will not work with the dictation version of the software.
Feb 18, 2008 | Olympus DS-4000 Digital Voice Recorder
Foot switch will not respond.
The answer is all in the serial number you use to install the DSS player!
Look carefully and you will see the recorder disk has in my case an [E] printed above the install serial number and the transcription pedal has [T]
Install the same disk with the E the driver is there, the control in Control Panel is there, but the foot switch does not work with the software. Put in the serial number with the [T] and foot switch works first time!
If you uninstall the play and then reinstall with the [T] serial number you do not need to reboot or even unplug the foot switch from the USB.
Bingo
Feb 13, 2008 | Olympus AS-2300 PC Transcription Kit
Driver Issues
My dictation pedal for the Olympus AS-4000 used to work on windows XP, but I upgraded to windows Vista and and the foot pedal no longer works. I have tried it on another XP machine and it works fine, so it can't be the foot pedal.
I have downloaded a patch from the internet, but unfortunately this does not seem to have resolved the issue.
I have contacted olympus twice and they have been very unhelpful.
Dec 07, 2006 | Olympus AS-4000 Desktop Digital Voice...
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
