Question about Philips 42PF9631D 42 in. Plasma Television
Where are the 2 capacitor's that are damaged for this model
Model# Philips 42PF9631D/37 w/ Amber light
Can you provide me the location of the capacitor's and where on the electronic board to be soiderd and the color of the 2 capacitor's that needs to be replaced also the replacement part number for the two for this fix.
My TV blinks 7 times red then recycles on power up. I have to continue unpluging and pluging in the power cord to get my TV to come on..
wayne.sellman@ic.fbi.gov
wdsellman@verizon.net
Thanks for your support.
Regards,
WDS
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, prior to replacing any component, perform a visual inspection with the rear cover removed and the unit unplug for some time (discharged). Most electrolytic capacitors are can type with a flattened top. Obvious defect would be manifested by bulging, cracked, oozing, leaking, split casing and powdery accumulation on one of the pins coming out from the rubber bottom.
Of course, best approach would be to compare/reference the service manual or at least a schematic diagram with voltage readings.
Good luck and thank you for using FixYa.
Posted on Feb 09, 2009
  • Louie  Role
    Louie Role Feb 11, 2009
    As proposed, you would need to visually inspect the capacitors. There would be several and basing on the initially described conditions, you would be able to identify the faulty capacitor(s).
    A known common fault (which may or may not apply to your concern) would be the capacitor in the power supply section. This image would show you where. It would be the bulging top capacitor bottom center between 2 aluminum blacks/heatsinks. A resized image is shown below. Pls note the bulging tops.
    Additional insights/discussion of similar concern may be gleamed from here. Interestingly, another member of the FDixYa community gooruflash has addressed a nearly identical problem here.
    Genius:
  • 1,011 Answers
Sir,
Here is the link to solve your problem
Thanks Good Luck
  • 3,037 Answers
before attempting anything, it seems to me that since you asked about the "electronic board" that you may not be very familiar with electronics especially tvs which can be quite dangerous. There are multiple boards on this tv and in this case I would replace the power supply itself and it would be the board that would have the faulty capacitors. This board is located in the middle of the back of the tv and if you don't know how to replace a capacitor, then it would be easier to replace the board. The bad ones will be swollen at the top. Also you could test them with an appropriate capacitance meter if you had one to confirm that they are bad. The numbers will be right on the capacitors if you choose to just replace them, but again if you have no experience, then don't do it yourself.
bestdarngood
Philips model 42pf9631d/37. What is causing red light to blink 7 times?
somewhere to find a fuse resistor near the replacement capacitors?
Need a manual for it with an error search tree
Mar 30, 2016 | Televison & Video
I have phillips 42pf9631d/37 that wont turn on and blinks red seven times
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.com
Oct 25, 2011 | Philips 42PF9631D 42 in. Plasma Television
Tv wont turn on
loud noise ? ! just indicate that the main power supply capacitors are bad, or sometimes is just the ceramic filters.
undo the back and check for any blow capacitor or burned components.
the new power board cost 139.99 on ebay
http://cgi.ebay.com/Power-Supply-LJ44-00117A-PS-425-PH-Philips-42PF9631D-37-/260597950481?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item3cacd92811#ht_500wt_928
if you dont want to fix your TV, let me know cuz i will buy for parts, write me to
fosg2000@gmail.com
May 18, 2010 | Philips 42PF9631D 42 in. Plasma Television
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Apr 14, 2010 | Philips 42PF9631D 42 in. Plasma Television
Philips 42pf9631d/37 6 slow red flashes and 3 fast
6-7 blinks means there is an issue with the power supply...
I found a replacement for my 42pf9631d/37
Part # Lj44-00117A
at TSM Inc. for $110.95 with free shipping...
http://www.tristatemodule.com/p-10120-lj44-00117a-samsung-tv-module-power-supply.aspx
Jan 28, 2010 | Philips 42PF9631D 42 in. Plasma Television
PIP problems Philips model 42PF9631D/37.
if you have a cable box and run it thour the cable box it will not work. cable befor the cable box you can do it put a spirer on the line be for the box run one to cable box 2 to the tv ant1 ant2 that is the way you can do it.
Sep 09, 2009 | Philips 42PF9631D 42 in. Plasma Television
Bad power supply
Hi, 9 times out of 10 it will be the capacitors on the power supply board,easy job if your handy, dear as hell if you put it in a shop
Jul 14, 2009 | Philips 42PF9631D 42 in. Plasma Television
TV will not turn on, the light goes from green to red.
I own the same model. You have 1-2 Blown Capacitors. Take off the back cover, And look towards the center of the main power board. Look towards the center of this, and there are 2 capacitors side by side. You should see them swollen at the tops, even maybe a little black residue that has come out. I soldered on 2 new ones, and bingo! I would suggest replacing them both.
Dec 13, 2008 | Philips 42PF9631D 42 in. Plasma Television
Phillips model 42PF9631D/37 Plasma TV PIP Setup
Hello, please try this link: http://www.p4c.philips.com/na4/4/42pf9631d_37b/42pf9631d_37b_dfu_aen.pdf Best regards, Arpi
Jun 17, 2007 | Philips 42PF9631D 42 in. Plasma Television
Philips 42PF9631D 42 in. Plasma Television Logo
37 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
