Question about RCA Universal Remote Control
RCA RCR450 Univ Rem won't work on COBY TV, model TF-TV 2617
The RCA Universal Remote was very easy to program on other sets and DVD. I have two other sets working very good with the excellent results. I've tried the directions in the guide. It says to press on/off switch as much as 200 times, bur it kicks off after 75-80.
Also I tried the method on line (pressing PLAY), and that didn't do it.
Hope you can help me.
rmack99@att.net **** Mack, Boca Raton, Fl
  • James Chandler May 11, 2010
    if your tv is what kicks off after about 75-80 pushes then that's your code when tv shuts off
5 Suggested Answers
wyoed1
  • 211 Answers
SOURCE: Programming RCR311 universal remote to samsung tv
RCA Universal Remote Control-Programming Codes
Try chicking on the web page above and see if this helps. Good Luck.
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 26, 2008
SOURCE: codes
i need the code # for my RCA DIRE.TV #RCR160SBM1
Posted on Mar 25, 2008
SOURCE: tv code guide
http://www.flickr.com/photos/maryandgeorge/2673999399/
I just bought the remote and scanned in the code list
Posted on Jul 16, 2008
  • 17 Answers
SOURCE: lost program guide for rcr3273 rca universal remote need codestoo
Go to thompsontv.com/carc.html
Posted on Oct 30, 2008
SOURCE: programing codes
Here is the link I just found the manual on for this remote control, which I needed the codes for myself: http://safemanuals.com/brand-user-guide-instructions-owner-manual/RCA go there type in the remote model RCR450 enter, click on the link that comes up and download the Manual in PDF form.
The codes for Sanyo are 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180 depending on which model you have.
OR:
1: Turn on the device you want to program ex: the TV
2:hold the button for the device you need to program in ex:TV
while holding down TV button hold down ON/OFF at the same time for 3 secs and the light should turn on and stay on.
3:click the ON/OFF button until the TV finally turns off may take many times but as long as the light stays on when your not pushing a button you still have codes to go through.
4:press the stop button and the device is programmed into the remote.
Posted on Apr 14, 2009
I NEED THE CODES NUMBERS TO PROGRAM THIS TV WITH UNIVERSAL CONTROL
GE Universal Remote Codes ' Jasco
https://jascoproducts.com/support/ge-universal-remote-codes
Make a note of which version you have and replace the batteries and cover. A version 2 through version 4 remote will have a "V2" to "V4" after the model number. ... Programyour GE Universal Remote using the correct code list and instructions. ... Sometimes a code will allow limited function control (e.g. volume and channel ...
Universal Remote Control Codes
www.remotecodelist.com/
Codes and links for a number of universal remote controls, including Sony, RCA, ... If you have a remote for which you know the codes (or a web page that lists them) head to ... How to Program a GE Universal Remote Control .... look for your model of TV or VCR and find the online instructions that include the remote codes.
RCA Universal Remote Control- Target Programming ...
Jan 05, 2016 | Coby TF-TV3217 32 in. LCD TV
Hi i have a coby 26" LCD TV model no TFTV 2617. How Can I get all my high definition channels. I all ready auto program it & it does not work
i have a coby 26 , I know sorry about that, but if any can help I appreciate it . turned set on today and green lite only no pic/sound/snow did have a horizontal red line for a few days prior to today.
Jul 15, 2011 | Coby TF-TV2617 26 in. LCD TV
Hi I have a brand tv dvd coby tf 1973 model and I have no remote control and I have the universe but can not find codes coby brand would provide me the code for the tv to use my universal remote to my tv...
The codes that was in ur universal remote manual don't work,useally there are no more codes out there will.Try website like Remotes.com to buy an original remote.
Dec 17, 2010 | Coby TFDVD1973 LCD TV
I lost my remote and need a remote code for a universal remote
To get the codes for your TV
Please go to below website
http://remotefinder.rca.com/default.aspx?site=rca
Select the remote control model,Device and Brand,It wil give you the code.
Thanx
Jul 23, 2010 | Coby TVDVD2050 20 in. TV/DVD Combo
I cant to program my cable channels with my univ remot sony tv
do it manually, front panel controls, or buy sony brand universal at wallymart
Jan 01, 2010 | RCA Universal Remote Control
Need tv remote code for coby tv model tftv1913
alguien me puede ayudar necesito saber q modelo son los 2 trasintores q lleva la fuente del coby 52553631-0812-42ad-b1ad-50c52c1bdbe7.jpg
Aug 31, 2009 | Coby TF-TV1913 LCD TV
I need a code for a universal remote
OR:
Mar 17, 2009 | RCA RCR450 Remote Control
Remove the base for wall mount
just spoke with a Coby technician. Where the base connects to the TV you can literally just squeeze in those the plastic pieces and they come right off. After that just unscrew the screws underneath. Just did it and it was very easy.
Nov 14, 2008 | Coby TF-TV2608 26 in. LCD Television
RCA DIRECT TV UNIVERSAL REMOTE CODE FOR SONY TV
If you have the RCR450 remote, the manual is here =>
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr450-manual.zip&area=other
The codes for Sony TV are 1002, 1218 listed in the back of the manual.
Nov 08, 2008 | RCA RCR450 Remote Control
Televison & Video Logo
79 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
