Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
Dishwasher fills but does not wash
We have a KitchenAid dishwasher. The water fills up but when it's time to wash, the machine makes a loud humming sound and does not begin to wash. Please provide me with all the information to fix my dishwasher. Thank you. I can be reached at mviolin@3web.net.
  • Anonymous Feb 22, 2009
    My dishwasher is a month old with the same problem. I have a service call next week.
  • julaniejae Apr 11, 2009
    I have the same problem.  Washer fills and then there's a humming sound.  Water does not squirt around.
  • 423 Answers
Is your Kitchenaid Dishwasher a model KUDI02?
If yes, you need to order item 10 on the page link below:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5137276
Good Luck!
Posted on Apr 10, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
When I start my washer it says sensing and it makes a load humming noise. It does this on every setting and I made sure that the door was shut all the way.
Love your doggie! THe loud sound sounds like the motor, but the control panel is not letting the cycle begin. Sensing means it is looking for water to begin filling the machine. If there is no water going into the machine this means that the solenoid that allows water to enter the machine is not opening the valve or maybe, YOU DIDN"T TURN ON THE WATER AT THE FAUCETS!
Dec 31, 2012 | Washing Machines
Dishwasher starts then pauses and drains.
Fixed! I had the issue where the cycle would start, the KUDS30IXBL8 would hum 4-5 times and then drain. Plastic folk pieces jammed in the disposer. These instructions took a few minutes (only 5 screws and a couple clips) to figure out how to take it apart, and it only took 60 seconds to put back together. How To Repair Dishwashers KitchenAid Repair Chopper Replacement
Apr 25, 2012 | KitchenAid Dishwashers
The dishwasher does not work at all. It just makes a slight hum.
Welcome to FixYa.
It sounds like you may have a faulty fill valve or a stuck motor impeller. I guess the first obvious question is, Does the unit fill with water ? If no and it hums, faulty fill valve or water supply is off.
If it does fill with water does the humming begin after it has filled, and if so has the unit recently been idle for a period of time...say a couple of weeks or so ? If yes, the wash impeller has become stuck and there is a simply resolution for Bosch dishwashers, it's a common occurrence.
These are relevant questions and can point directly to the problem if you want to reply I can help you move forward.
Let me know what you find and I'll try to assist you in any manner I can going forward.
Regards,
Macmarkus :)
Jan 28, 2011 | Bosch SHU9915UC Dishwasher
My dishwasher starts fills water and never starts wash cycle?
If you hear a hum when it should be washing, the motor has seized. Replace motor. If it fills with water and stops quite, run it through a test using the tech sheet under the bottom panel to access. These dishwasher have had issues with the motor.
Oct 09, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
Loud humming when the water enters the dishwasher. The copper pipe vibrates. The dishwasher is approximately 11 years old. Problem slowly getting worse over time. I tried to tie down the copper pipe in the...
the fill valve solenoid has gone bad.u need to chg the fill valve assly.it is very easy to chge ad it is mounted on lhs bottom corner of the unit behind the toe panel.
Aug 17, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Humming noise after water fill and will not wash
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
Jun 11, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
890 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
