Question about Kenmore 15864/15862 Top Load Washer
Kenmore washing machine - model 110.23832100
Water will not drain after rinse cycle. Will not go into spin cycle.
  • 3 Answers
Sounds like a bad lid switch.
Posted on Feb 09, 2009
My Kenmore compact washer with dryer on top, will not go from the first wash-rinse-drain-spin cycle to the second rinse-drain-spin-off cycle.
Check and make sure the door is pushed all the way down until you hear a click. If it starts with the next cycle, then your door switch may be bad. It's a pretty easy fix, but I would watch a video at least before doing it yourself.
Oct 09, 2016 | Kenmore Washing Machines
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
End of wash cycle, no draining or spinning, but can move to rinse cycle and it agitates again, no spinning after rinse either
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The drain and spin functions are started when the timer advances to the spin mode.
The motor is reversible. When agitating, the motor spins one way, when going to the drain / spin mode it reverses.
Since the machine agitates, the problem points to the timer.
Sep 04, 2009 | Kenmore Washing Machines
Kenmore washer doesn't drain
This is likely a pressure switch issue.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Mar 18, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Kenmore 15864/15862 Top Load Washer Logo
268 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
