Question about Garmin nuvi 255W GPS Receiver
Black screen displaying only Garmin and a blue triangle
We got a garmin nuvi 255 2 months ago. It worked fine until today when we turned it on and all it displayed was the Garmin name and a small blue triangle. The menu screen never comes up. We tried the reset button and nothing.
  • captain bett Feb 18, 2009
    Same problem. Cannot master reset. Will not let me update software from Garmin site.(that was Garmin tech solution)
  • basket_co Feb 19, 2009
    Garmin tech told me they had never heard of this problem before.
  • 385 Answers
to soft reset & keep data....
Slide power key to on/off, hold it for 8/10 seconds
Update from Garmin, use the web-updater. keep it updated, delete old junk and POIs.
hard reset.
Hold lower corner of screen, while turning on, keep pressing, when "clear all data appears" click yes,
sould resolve the problem
Hope this helps.
Regards.
Posted on Apr 16, 2009
tbirdfan1
  • 3051 Answers
SOURCE: My Garmin Nuvi 255 died. How do I reset it?
Hello there:
If you unplug the unit and remove the battery
i would check the fuse inside the unit to be sure that it is ok if it is than
leave it unplugged and the batttery out for 30 min and if there is a reset button on this after the battery is removed hold in the reset in for 2 minutes then after the 30 min replace the battery and plug in the unit and try it again his should be enough time for the internal reset to reset it'self than just replace the battery and if this still oes not help remove the battery again and leave it sit for 1 hour to let the internal reset device reset it'self ok and you should be good to go
Hope this is very helpful
Best regards Michael
Posted on Dec 10, 2009
  • 35 Answers
SOURCE: garmin nuvi 255 won't turn on
Have you tried doing a hard reset,try using the reset button on the bottom of the gps under the serial label.Or try holding the turn off button for about 10 seconds,good luck.
Posted on Sep 05, 2009
taran_2005
  • 10515 Answers
SOURCE: how to change language on a 255?
On the very first screen after the GPS boots there will be an icon of a wrench at the bottom right of the screen. Press that Icon and scroll through the menu and you will find a language setting.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 11, 2009
Testimonial: "Thank you! Merry Christmas!"
  • 32 Answers
SOURCE: Replace Garmin nuvi 255 LCD screen
If the touch screen is working well,then you only need to buy the LCD sreen,but usually suppliers will send the LCD with touch screen as they are one whole part.you can try to contact :
kingyijin@hotmail.com for further information about it.
Posted on Jan 08, 2010
HarryHarley
  • 343 Answers
SOURCE: how do we update our garmin nuvi 255
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You can get that FREE at Garmin here:
To download the latest unit software visit Garmin website: www.garmin.com/webupdater
First you have to set up an account at Garmin using the serial number on your GPS. Once you do that you can download firmware update for free.
After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
By the way, the correct Garmin approved power OR download cables are a must!!
Does this help? Let us know. Thanks.
Posted on Feb 06, 2010
Froze on garmin screen won't give directions
Could be a battery problem not having enough charge to get past the Garmin screen you might need to replace the battery or it might need to be reset.
Not knowing which model of Garmin it is makes it hard to provide a correct solution. ?
If your Garmin Nuvi 1300 is freezing up or not working correctly, a soft reset can be performed. A soft reset unfreezes the unit and brings you back to the main menu. If a soft reset does not solve the problem, or if you are selling your unit and wish to erase all of your saved information, a hard reset can be done. A hard reset restores the original factory settings to the unit. Once the information is deleted, it can not be restored. Turn on the Garmin Nuvi 1300. Press and hold down the "Power" button. Release the button when the main menu is displayed. The unit is now ready to be used. b> Hard Reset b> Turn the Garmin Nuvi 1300 off. Press your finger against the bottom-right corner of the Garmin display screen. Leave your finger in place as you power the unit on. Release your finger when the display screen asks, "Do you want to erase all user data?" Use your finger to tap "Yes." The unit will begin to reboot. Do not use the unit until the main menu is displayed. The reset process should take about 45 seconds. Hope this helps.
http://www.youtube.com/watch?v=xjUSGY7KVAk How to Replace Your Garmin Nuvi 255 Battery
Jan 04, 2013 | GPS
How to calibrae my gps nuvi garmin 255????????????????
For the Garmin 2x5 series GPS
Calibrating the Screen:
1. Turn off the nüvi.
2. Hold the upper-left comer of the screen white turning on the nüvi
3. Release the power key when the Garmin screen appears.
4. Continue to hold the upper-left corner of the touch screen for 30 seconds until a white screen with "Press dot" appears.
Here are links to the manual for both the 255 and the 255W (wide).
I hope helped & good luck! Please rate my reply. Thank you.
Jun 30, 2011 | Garmin nuvi 255W GPS Receiver
Nuvi 255 stopped working
Same thing here. Does anybody have any answers?????
Mar 25, 2010 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 255 won't turn anymore
i had same prob about a month ago it sorted it's self out after left on charge for a week
Jan 20, 2010 | Garmin Nuvi 255 GPS Receiver
Garmin Nuvi 255 2008 screen not respnond to touch
There should be a reset on it and it should bring it back.
Dec 25, 2009 | Garmin Nuvi 255 GPS Receiver
Garmin nuvi 255 won't turn on
Aug 31, 2009 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi 255 won't charge with the car charger.
You may need to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Feb 21, 2009 | Garmin Nuvi 255 GPS Receiver
How do i charge garmin nuvi 250 on my computer
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
Nov 09, 2008 | Garmin nuvi 250 GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
995 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
