Question about Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum
There are no known vacum bags for a model wd06350 vac
I have 6gallon ridgid vac how do i insert a vacum bag in it to use into pick up drywall dust with it?
  • 360 Answers
Find a vacuum bag that figs over the cartridge filter, hold in place with a rubber band. There will still be some drywall dust escaping and the paper filter will need to be cleaned (brushed off) often. You can try adding some water to the canister to reduce the dust but it will make mud in the canister.
Posted on Feb 09, 2009
    Problem Solver:
  • 6 Answers
This type of vacuum does not use a bag. If you are worried about clogging the filter cartridge try using a paper filter for a shop-vac. They are relatively cheap and are available at most hardware and department stores. These are made to simply wrap around the big cartridge. A rubber band will hold it in place.
I am vacuuming spackle dust from sanding walls and my electrolux canister continues to open. What should I do?
Fine dust from sparkle will clog a bag or filter very quickly even though the bag is not full or even close to full. The air can't pass through the bag so it is popping the door open. Drywall dust can ruin a vacuum motor very quickly. I use a shop vac style vacuum with a cartridge filter that still clogged up after just a few minutes of vacuuming the dust but I can take the filter outside and hit it against something and use a small soft brush to clean it.
Jan 28, 2018 | Electrolux Vacuums
Tip
Safe way to vacuum drywall dust
SAVE THAT VAC
One of the hardest things on a shop vac is drywall dust. It is so fine that it gets through the regular filter and destroys bearings/bushings and ruins the motor. Just the other day, a friend commented that he had to get a longer hose as his vac was blowing out a lot of drywall dust because the filter was slipping down!
High performance filters are available at most hardwares and box stores. They resemble the paperbag filters in carpet vacuums and catch the drywall dust so that the bag can just be thrown away when done. The bag is U-shaped to install in the shop vac and have clearance around the regular cartridge filter. The inlet has a rubber seal that pushes around the inlet on the inside of the tank. Just run the vac normally but spare it and your lungs!!!
on Mar 02, 2010 | Vacuums
Are bags needed for a dirt devil hand held dust buster?
Dirt Devil Parts
dirtdevil.com/parts/
Dirt DevilNo promo code required. ... most popular: Bags: Belts: Filters: Cleaning Solutions: Filters, F1-F85: Filters, Adapters: Filters, ... vacuum cleaner: Attachments & Tools: Brushrolls, Hand Vacs: Brushrolls, Uprights ... Handheld Steam Cleaners.
Type G (10 Pack) - 3010348001 - Dirt Devil
dirtdevil.com/parts/details/3010348001/type-g-10-pack/
Dirt DevilGenuine Type G bags. Fits all hand vac models equipped with the paper bag adapter. Includes ... The Handheld Vacuum That Picks Up Where Others Leave Off ...
Ultra Corded Bagged Handheld Vacuum - Dirt Devil
Jan 01, 2016 | Dirt Devil Vacuums
I have the porter cable 10 gallon tool trigger drywall vac why is it that the bags keep braking. Have had it for years and it's only been about the last two years they rip open way before they are half...
Need some more information, are you vacuuming dry wall dust or wet dust or saw dust ? The reason I ask is sometime their are "upgrades" available for the newer models of vacs you may not be aware of, when I worked at the Big Box H D tool rental center the vac we rented out used a water filtration set up instead of bags U might wont to check newer model for any changes, like you ,I had Craftsman for over 15 yrs. and when it died the replacement vac had a new mod for the filter that I always thought was needed. Good luck , Bret
Sep 28, 2014 | Porter Cable 7812 Wet/Dry Vacuum
Why does my Electrolux epic 6000 sr shut off with suction?
If this Epic 6000 is shutting off when you either just turn it on or while vacuuming with it...it\'s one of several things...1. Change the bag if you\'ve been picking up a lot of "fine" dust such as drywall dust or carpet freshener powder. That\'s ******* them. 2. Being the machine is over 22 yrs. old, the suction control valve inside either needs to be replaced or just cleaned well. This is the usual cause of the vac shutting off especially if you\'ve tried the dial in several different settings. Hope that helps!
May 20, 2014 | Electrolux UltraLux 2000 Bagged Canister...
Have a 6500 epic electrolux canister vac shuts off if you restrict the hose new bag not completly
Shake the bag if you've been cleaning up "fine" carpet freshener powder, drywall dust or anything extra fine as it clogs the pours of the bag and the machine stops thinking the bag is full. If this doesn't work, you'll have to have the control valve on top cleaned or replaced to correct the issue. Hope that helps!
May 16, 2014 | Electrolux Vacuums
Can I use shop-vac without bag 5gal5.5 hp
If you are using it for wet pick up, you would not use the bag. If you are using it for dry pick up, I would recommend using the bag to keep dust from going thru the vacuum and back into the area you are trying to vacuum.
Apr 06, 2014 | Shop-Vac Corporation Shop Vac Wet & Dry...
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum Logo
628 people viewed this question
Top Ridgid Vacuums Experts
Dan
Level 1 Expert
ken skalski
Thomas Perkins
Thomas Perkins
Are you a Ridgid Vacuum Expert? Answer questions, earn points and help others
