Question about Motorola Mobility H700 Wireless Headset
I can not figure out how to put in discovery mode when turning on
Lost manual! devise is charged blue light blinks. Can not get light solid for discovery mode.
  • Anonymous Feb 17, 2009
    I lost my manual and cannot set my device.
Close the mic and hold down the button until it becomes purple. Open the mic and it should stay steady lit purple. Then you can pair it with your phone. I found the manual online because I had lost mine as well. Also, make sure any old phone you were using it with is off so it does not connect with that one. Good luck!
Posted on Apr 29, 2009
  • 73 Answers
Close the boom mic and then press and hold the main button until it comes on. This is the pairing mode.
Posted on Feb 09, 2009
Unable to put phone into pair mode motorola hs810 to a i phone 3g
Most blue tooth device manufactures use the power button to set your device to discovery mode,first you must turn the power to on for your blue tooth from your phone menu,then most manufactures use the power button to put the blue toooth device into discovery mode,by holding the power button down when you turn your device on holding it for 6 to 10 seconds,usually a solid light appears on your blue tooth device,it is now in discovery mode,on your phone menu there should be an add new or search devices,once you've clicked that it should discover your blue tooth device,then you will need a pin or pairing code,Most manufactures use a factory 4 digit pin pairing code the y are as follows 0000,1234,1111,or 9999, if you have done the steps correctly the menu will say connect,press conect and you should be connected..i hope this helps
Feb 22, 2011 | Motorola Mobility HS810 Consumer Headset
How to get blue tooth
first turn your bt power to on in your phone menu then turn your bt device to discovery mode most devices you just hold the power button on for 6 to 10 seconds and a solid light appears once you have it in discovery mode you will have to search or add new devise from your phone,if you have everything right they will find each other but you will be asked for a pairing or pin pass code most blue tooth device manufactures use a 4 digit code they are as follows 0000,1234,9999 or 1111 i hope this helps
Feb 21, 2011 | Plantronics Explorer 232 Bluetooth Headset
I turned my headset on and now the blue light is on and I cannot turn it off.
your blue tooth device is in discovery mode you must pair it with your phone again,it just you held the power button down to long turning it on ,most blue tooth manufactures use the power button for the discovery mode,in case you don't have the pairing pin code again most blue toooth manufactures use a 4 digit factory code,they are as follows 0000,1234,1111 or 9999 i hope this helps.And if your blue tooth drained the battery and you need to charge it before you proceed ,to put it into discovery mode hold the power button down for 6 to 10 seconds when turning your blue tooth device on.i hope this helps
Feb 18, 2011 | LG HBM-760 Bluetooth Headset
My motorola h721 keeps blinking red.
if you didn't pair your phone up yet, that could be why. Hold all 3 buttons down for 10 sec. should go solid blue, then pair your phone cause its in discovery.
Aug 15, 2009 | Motorola Mobility H710 Bluetooth Headset
How do I put Jabra BT 135 in Discovery mode?
Turn the device on and continue holding the power on button until the light stays solid. That puts it in discovery mode.
Pair it with your device.
It will probably also ask you for the password to the bluetooth headset (mine did). The default is 0000.
Jun 30, 2009 | Jabra Bluetooth Headset with Adjustable...
I have a plantronics 520,
Start with your headset turned off. Press the talk button on the headset. Hold it until you see the light on the headset begin to rapidly blink red, blue, red, blue, red, blue, etc. Let go, the light should continue to blink red and blue. Go into your phones blue tooth menu and search for the headset. The phone will only find the headset if the headset is in pairing mode (blinking red and blue). The pass key is 0000.
Apr 10, 2009 | Plantronics Hama Voyager 520 Bluetooth...
232 Plantronics bluetooth manual
flashing purple after you hold it for 3 seconds is discovery mode. blue flashing is active on. hold for 6 seconds to turn off. hold for 2 seconds to turn on.
Jan 11, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Hey, i dont know how to turn the blue tooth on.
after it holds a steady charge, try holding the power button for a few seconds. if you get a blue light (blinking or solid) then its on, obviously. holding most power buttons on bluetooth devices will put them into pairing mode, as soon as you get a solid light, you can connect it to your phone...and if you just bought the headset, you should have an instruction manual. it will tell you in there how to make it work
Nov 04, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
275 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
