Question about Toastmaster 287 Waffle Maker
Repalcement plates for Model 270A Toastmaster Waffle Iron?
Can I purchase replacement non-stick plates for a Toastmaster Waffle Iron Model 270A? Where can I go to get them?
  • 4 Answers
Actually I have a Toastmaster 270A waffle iron. It is much better quality than the later toastmaster models, and it is basically identical to the Black & Decker model G48TD, which is still sold. You could get plates from Black & Decker. The entire iron sells for $50.
Posted on Jan 03, 2010
  • 137 Answers
There is no way you can get replacement plates for you Toastmaster cheaper than you can buy a new one, the most expensive Toastmaster waffle maker I found was $30. the cheapest was $15 shipping will be at least half of that.
Posted on Feb 15, 2009
How to use the waffler by toastmaster model# 2810R026
Directions
  1. Preheat waffle iron. Beat eggs in large bowl with hand beater until fluffy. Beat in flour, milk, vegetable oil, sugar, baking powder, salt and vanilla, just until smooth.
  2. Spray preheated waffle iron with non-stick cooking spray. Pour mix onto hot waffle iron. Waffle is usually done when it stops steaming. Cook until golden brown.
Apr 16, 2014 | Toastmaster Kitchen Appliances - Others
Need the manual and recipe
Here's a manual for my W252, which is similar to your model.
Feb 14, 2014 | Toastmaster 442A Vintage Waffle Iron
My waffe batter stuck to the waffle iron
After each time you use it, when it cools, it should be wiped clean and lightly oiled (so it's non-stick ready to use for next time).
Oct 14, 2012 | Toastmaster 287 Waffle Maker
Where do I find this perticular make and model? I need 2 or 3 of 'em
You are out of luck as this is an old problem the season is long past.
I am fairly shure that Toastmaster no longer makes this Pizzelle iron. A better solution is an American made Pizzelle Iron by C.Palmer
Built like a tank and will probably outlast you. I wouldn't buy a non stick appliance from anyone as the coating is easily damaged.
http://www.cpalmermfg.com/products/Pizzelle-Maker.html
Oct 31, 2011 | Toastmaster 208 Pizelle Maker Waffle Maker
Cleaning your waffle iron WPLT4
Let me start by telling you WHAT NOT TO DO.
  1. Never clean a waffle maker while it's still hot. Let it cool completely.
  2. Never dunk your entire waffle maker in water.
  3. Never use scouring pads, steel wool or abrasive cleansers.
  4. Never use a knife or pointed object to clean your waffle maker(I've actually seen that advised on less reputable sites).
When it comes to cleaning a waffle maker, your first source of information should always be the owner's manual. There are many different kinds of waffle makers, so your buddy Mr Breakfast will gladly defer his expertise to the company that makes your waffle maker.
What I can speak about is my own favorite waffle iron. It's a modern electric waffle iron with non-stick and non-removable baking plates. That's the same kind you have? Oh good. It looks like you came to the right guy.
Cleaning the baking plates:
  1. Remove any small puddles of oil with a dry paper towel.
  2. Brush away any crumbs with a soft-bristled kitchen brush or old toothbrush.
  3. Remove any batter stuck to the iron with a rubber spatula.
  4. To remove really-stuck-on batter, douse the baked-on batter with cooking oil. Wait 5 minutes for the batter to soften. Dab the batter off with a paper towel or cloth.
  5. To prevent staining and long-term oil build up, wipe down the baking plates with a damp cloth or paper towel.
  6. Make sure the waffle iron is completely dry before storing.
To clean the exterior, wipe down the housing and handle with a damp cloth.
Keeping it clean:
There are a couple things to remember to make sure our kind of waffle maker stays clean.
  1. Unless stated otherwise in the manufacturer's instructions, you should never coat the baking plates of a non-stick waffle iron with cooking spray. Over time that will give you a gummy build up that will turn your waffle maker to junk. Today, when a waffle maker makes the claim that it's non-stick, they really mean it. The only oil you need is the oil in the recipe. If your waffles are sticking, it's your batter that needs more oil, not your waffle maker.
  2. Unless stated otherwise in the manufacturer's instructions, don't use soap to clean your baking plates. Soap can be the enemy of a non-stick surface. Oil - on the other hand - can be a great friend. It creates a thin layer that helps maintain the non-stick surface. Soap will completely obliterate that layer of friendly oil. Harsh soaps can deteriorate the manufacturer's non-stick surface over time.
Mar 05, 2011 | Salton WM4 Waffle Maker
When using a toastmaster waffled maker do you have to use an oil or butter pan spray?
Normally you mix oil in with the batter, but this doesn't keep the waffles from sticking. Even non-stick waffle makers stick some. Use a light spray of Pam (or similar) on the bottom tray, add your batter than spray the top pan and close. This gives you your best shot at a perfect waffle!
Enjoy!
--W/D--
Jan 17, 2011 | Toastmaster 217 Cool Touch Belgian Waffle...
Why does my waffles stick?
You have to lightly coat the waffle iron with vegetable oil, and then you won't have them sticking.
Otherwise, it's a mess!
Dec 12, 2010 | Toastmaster TMWB2BELW Waffle Maker
283 S Waffle Iron.
You can try this site: http://kitchen.manualsonline.com/manuals/mfg/toastmaster/287.html
Its not the exact model but sometimes they are close. Hope this helps.
Aug 13, 2009 | Toastmaster 283S Waffle Maker
Waffles are separating when we open the plates
In my experience this is due to sticking on the plates. I spray a little cooking spray on them with each batch I make.
Maybe they arn't quite done.
Jul 12, 2009 | Waring WW150 Waffle Maker
Toastmaster 287 Waffle Maker Logo
511 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
