Question about Bosch Brute Breaker Hammer 11304
Bent rod the hammer was not working and i found that it had a bent rod . what would cause this
    Problem Solver:
  • 5 Answers
If it is an air or gas hammer... probably lack of lubrication...
Posted on Oct 28, 2009
Craftsman lawn tractor
Hi, had it been sitting some time unused?
Sounds like the valves are stuck in their seats and the rods bent when the motor pushed them with the cam.
You might be lucky and the one that fell in didn't get into the works.
Make sure you fish it out before doing anything else.
I'm guessing it is the typical side valve type motor?
Remove the valve cover (I guess you have already to get the push rod out) and using some sort of lever try and move the valves up against against their springs. Don't bend them with sideways pressure though. If they're stuck some CRC / WD40/oil or similar will help to get them moving. Remove the spark plug and spray CRC etc onto the valve heads inside the cylinder.
Assuming the push rod hasn't contacted anything moving while the motor was being wound over and done more damage, you should be good to go with new push / 2nd hand push rods. Just check there is some clearance between the push rod and the valve stem when each valve is closed.
Oct 09, 2013 | Craftsman Garden
THE PUSH RODS ON A 407577-0284E1 ARE BENT WHY?
I've had the same problem with the same engine. Found that the cause was a valve guide working its way out of the head and up the valve shaft. This prevented the valve from opening completely. Something had to give and it was the push rods that lost. I've tapped the valve guide back into the head and peened the aluminum around it. So far the valve guide has stayed in place. Check both push rods in that head. Both will usually bend or break when the above occurs.
Feb 07, 2013 | Cars & Trucks
Frontend work like tired rod n idler arms repair. But your tires still wearin out. What else can cause that?
Bent spindle, bent shock/strut or a bent control arm. Did you get an alignment dont when you replace the F/end stuff?
Sep 09, 2011 | 1992 Buick Roadmaster
Rods in rear are bent causing tires to wear
do you mean the tie rods or are you just looking there and see a part that looks bent? if both tires are wearing uneven, it could be just a rear wheel alignment that you need. did you just buy this car? it's possible something under the car is bent from a previous accident, but if you had this car for awhile and this problem just began then it may be just an alignment........good luck..p.s......if both tires are wearing uneven then it's unlikely a" rod "is bent , there would have to be a " rod " bent on both sides which is too coincidental.
Feb 13, 2010 | 2004 Chevrolet Impala
Types funny symbols instead of the number I
The typewriter will print the incorrect letter, or the face of the hammer if it does not spin properly to the correct position. 1. Turn the machine offf for 15 seconds and turn ON, or Depress MODE RESET(the Q key). This will rehome the Daisywheel.I If it prints correctly for awhile then looses its' position, check for ribbon or correction tape interference with Daisywheel movement. If it does not print correctly as soon as you start typing, remove the Daisywheel and inspect the spokes to see if any are bent. Reinstall the Daisywheel and power ON. If the Daisywheel has a bent spoke or two, you can try to straighten them, howvever the cause of bent spokes is a concern. While typing, carefully watch the print hammer movement. It should always return to the same position and not move towards the paper until a letter is pressed. If it does not come to rest properly, the hammer is not in proper timing and may enter the Daisywheel while it is spinning to the character, thus causing damage to the Daisywheel or causing it to lose homing. .The hammer cams would require adjustment ore replacement. If bent spokes is a persistent problem, make sure to get the hammer problem repaired before buying a new daisywhel.
Dec 29, 2009 | Brother SX-4000 Typewriter
Last thursday my mower worked perfect, 5 days later it wont start
same here!!!...found no compression/piston movement and suspect the con rod let go...only 2yrs2mths old...assembly prob that has become my prob!
Jul 05, 2009 | Mtd 22" Yard Machine Push Mower
24 hp engine. one bent push rod, second rod missing lost some power, no other problems
This happened to me,the engine sat for some time and the valves were varnished with stale fuel,they stuck in the guides.This bent the push rod and it was only running on one cylinder.The missing push rod worked its way into the crankcase through an oil passage . I took the engine sump of and found the push-rod. I cleaned removed the head,cleaned the valves and guides replaced push rods and gasket and it ran fine after that.I use fuel stabilizer now,it keeps the varnish from forming.
Jun 23, 2009 | Briggs & Stratton Garden
Gear selection
Has the bike been dropped on the shifter side??? Has someone kick hard on the shifter leaver???There is a shifting rod the is under the side cover. If if is bent??? It will not shift like it should. You can pull this rod out when you take the side cover off, and straighten the rob back with a hammer. The rod has to be straight to shift proper.
Jan 29, 2009 | 2002 Yamaha XJR 1300
Bent connecting rod
Ive had blower with bent cranks due to blower scroll comming off and the engine over reved
Jan 18, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Bosch Brute Breaker Hammer 11304 Logo
156 people viewed this question
Top Bosch Hammering Experts
John Trevino
snowycreek
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
