Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Turning rod keeps slipping off
Older Murray riding mower won't turn because turning rod keeps slipping off. The bolt looks fine when I reconnect it but the little ball at the end keeps slipping out of the hole. Any suggestions?
  • baboosh44 May 23, 2009
    Murray older riding lawnmower. turning rod came off axle. I can see a ball joint on the end and where it goes but what type of bolt do you suggest to reattach?
  • Anonymous Mar 15, 2014
    Rod came out of ball
    President:
  • 1,902 Answers
Replace the bolt with a new bolt. Sounds like the bolt is not tighting down enough to make the joint tight like it should be
Posted on Feb 09, 2009
I am looking for a parts and repair manual for a 2004 model #385016X78A Murray ride on mower.
Murray went out of business and was bought out by new outfit. Do not know if new Murray (kept the name) manufacturer will support the older products produced previously. You can always check and cross your fingers.
Sep 29, 2016 | Murray Garden
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
My JD L130 has little power going foreard and almost none in reverse.
The forward reverse pedal linkage needs adjustment. Remove mower deck pins and slide out of the way. Pull linkage pin out then turn clockwise one full turn .move brake pedal while looking at it .You should see a small brake disc on side of rearend with a nut bolt going through the disc. Pull rod on back of mower that allows you to push mower freely.set parking brake try to move mower by pushing if it moves with break set tighten bolt that goes through brake disc til mower don't move.release parking brake try to move mower should roll easy.if not losen bolt 1/2 turn til it moves easy.reengauge rod on rear of mower to drive it test and be sure to place cable ties on any thing under mower dragging ground .If test works .reinstall mower deck.
May 18, 2014 | John Deere L100 Series
How do you remove the bolts on the mandrel cover of the mowing deck. The bolts begin to loosen but then seem to get tight again.
I would keep turning them, there may be old grass, dirt, etc. that's making them turn harder. If not look underneath deck to make sure theres no nuts on bolts.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Aug 09, 2013 | Husqvarna YTH26V54 54"" Riding Lawn Mower...
Murray 10/30 riding mower has spark but not firing, with a puffing sound out the air filter when trying to start it.
Gavin, the symptoms indicate that the intake valve is stuck open, it could be that the exhaust is also stuck, but normally when an engine sets up, only one stem corrodes and gets stuck. It matters little though which one is stuck, you will still need to have a valve job.
junkl
Feb 26, 2013 | Murray Garden
How do you replace the clutch coils on an electric PTO husquvarna riding mower
I am going to presume that this clutch actually installs on the lower end of the engine crankshaft. There should be a bolt that goes up thru the center of the clutch into the shaft. There's probably a spring or rod that will hold the outside of the clutch solid. Part of the clutch will be turning with the engine when it's running and when you throw the switch to engage the clutch, the other portion is activated by the current to connect to the turning portion.
To get the old one off, you'll need to get under the mower with a socket wrench. These can be quite stubborn to break loose, as the engine will want to turn over as you turn the bolt. If you have a gear drive machine you may be able to let the transmission help hold the engine from turning, but that, too, is run by a belt, so it may slip. Worse case is to use an air impact wrench, which will apply pressure so fast that it will make the bolt turn without turning the engine. Good Luck.
Feb 16, 2010 | Oregon Scientific Electric PTO Clutch for...
Starter keeps spinning after shutdown
Is the starter turning while the is running... sounds like the starter relay / solenoid is stuck or you may have a bad switch
Aug 23, 2009 | Briggs & Stratton Garden
Older model Ariens ride around lawn mower - drive belt slips off
it could be the belt has streched
check tensioner if has one and check all nuts and bolts tight
Jun 21, 2009 | Ariens 34 In. Zoom Series Riding Mower
Murray Lawn Mower won't go in gear
my murray riding mower wont pull when i put in gear i dont have a clue what to do,it doesnt seem like its going in gear
May 15, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
268 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
