Question about Linksys Wireless-G WRTP54G Router
Appreciate any advice on how to set up Linksys Wireless G Router
Sorry folks, but this is the first time I am attempting to set up a wrireless network at my home. Juz bought a second hand Linksys Wireless G ADSL Home Gateway router. I already have a internet subscription at home. I would appreicate any advice on how to proceed with the set up? Thankz a lot!
  • charles_lee Feb 09, 2009
    Hi Zutil,
    The link you provided is more than sufficient for me as a novice!! Thanks mate!!
I have a new nokia 5800 but i cant connect my wlan wizard to linksys ?
Posted on Mar 14, 2009
    Problem Solver:
  • 16 Answers
Here's a basic SoHo set-up.
But if your looking for manual, please provide me your e-mail address so that i can e-mail you.
Thanks.
Posted on Feb 09, 2009
  • Noe Lana
    Noe Lana Feb 09, 2009
    no problem..
Only one device can access the wireless router.
I have the same one try IE 192.168.1.1
that's the home page for linksys
Jan 30, 2012 | Linksys Wireless-G Broadband Router
Hi, I have a problem lately where my modem was malfunction and replaced. However after replace a model and confirmed I can direct link to internet from any of my computers, I now face a problem when I...
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 23, 2010 | Linksys Wireless-G WRT54G Router
I can not connect to the internet with my wireless
With an Ethernet cable, connect your laptop to one of the LAN ports on the router.
Start Internet Explorer.
Enter: http://192.168.0.1 (or try: http://192.168.1.1)
and login to the built-in web-server inside the router, using the ID 'admin'.
Check the 'WAN' settings (from your router to your cable-modem or to your DSL-modem).
Run the "Wireless Network Setup Wizard" to reconfigure the settings for your "wireless" network.
Dec 29, 2009 | Linksys Wireless-G WRT54G Router
Cannot connect Wii to Linksys WRT160N, Test connection is successful; however getting error code 220602 when it attempts to access the internet. Tried changing channels, manually inputting codes, disabling...
1.Unplug all off your devices starting with the wii then your linksys router.
2. On the router unplug the connections on the back ports then reconnect them "port connections first then power connections second"
3. Go to the wireless connection screen and do a network test on the Wii.
4.If that doesn't work then you have to go into the router itself through its ip address and redo the settings to make sure you have the connection to the router unblocked.
I hope that helps
Rad
Dec 06, 2009 | Linksys WRT160N Wireless Router
I am attempting to replace my old router with the Linksys N ultra range plus. The router works fine with the blue cable attached to the computer, but it does not work without the blue cable (does not work...
You need to use the Wireless Setup either using Linksys or Windows. You accomplished setting up the system with the hardwire when you installed, now you need a second method setting for the computer to attach. In XP, go to Start/My Network Places/ Set Up A Wireless Connection ....
I no longer use the Linksys setup for the network setup because I have ran into many problems.
Also, you can contact the Customer service hotline that is in the Manual an in the setup window and they are very helpful and free of charge. They are in India, but I have used them 3 times and they speak fluent English and are better at the language than most Americans, just do not crack jokes or use slang because they will not understand some of it. The Customer Service Line with Linksys is awesome and I would rather you use them rather than take my word for it.
Nov 17, 2009 | Linksys Ultra RangePlus Wireless-N...
Linksys router when cabled, doesn't work wireless to laptop
can it detect the wireless signal?
did you load the drivers for wireless card in laptop?
check the device manager for any ! or ? in it those need attentio
if you can detect the wireless network then you need to set the wepkey if its enabled. if its not and you have a signal then just click on connect in the wireless network manager
Jan 22, 2009 | Linksys Wireless-G WRT54G Router
Wireless
Well once it is reset, in the configuration section of the router, for setting standard passwords, you can change the password, which is advisable.
Next, for setting up a private wire/wireless network, My way of doing it is by setting the system up to Only allow Certain Mac Address's from the computers that are allowed to access to the internet through yours
To get the MAC Address, Hit Start, Run Program, Command Prompt. Then in Command Prompt, enter this string line: ipconfig /all
From there, it will give you the MAC Address for that computer. It should be a total of 12 Alpha Numeric Digits, Spaced with dashes between every 2. With that, you go into the router and in the Mac Address section for computers allowed to connect to your network, you enter in all the MAC Addresses that are allowed to use your network. Save, then it should refresh the page once that is done. With that, it makes a very hard to break Network that actually doesnt take much time. I was quite surprised 4 years ago to find that this was the easiest way to really set up a near perfect network with no issues
Oct 29, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys Adapter and 2wire router
  1. ensure that a wireless connection is created in control panel on the pc, it may not even be attempting to connect
  2. ensure that the router wireless is turned ON, it may have been turned off as a security measure when no wireless pcs were used
  3. The security settings on the adaptor may be set to the office network and locked
    wep password at home is different or not enabled, so the secured adaptor will not connect.
make any changes from a cable connected pc (no chance of data loss)
access the routers settings page and check the settings,
then ensure the adaptor rom if present is set to the same settings
Jul 16, 2008 | 2wire 2700HG-B Router (2700HGB)
I installed my linksys g pci wireless router after uninstalling at the advice of the linksys tech. I use free wireless network. The tech installed a security enabled wireless network VU1V3 and now post...
wooooh wooooh
Marcia...............Is this a small home system here. Was this an onsite tech. ISP is Internet Service Provider and not so sure that is the issue. WOW this can get confusing. Perhaps this tech can redo his work for sake of your time. An adapter does allow the ISP to see how many PCs you are using.
Sorry Marcia .................Really would be nice if Mr. Tech could reassist you on this.
Bill
Apr 24, 2008 | Computers & Internet
Linksys Wireless-G WRTP54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
