Question about Insignia NS-H2002 Theater System
No surround sound through tv
The surround sound works fine with a DVD, in but when watching tv alone no surround sound.
    Scholar:
  • 93 Answers
May be you have to set the Pro-logic option soundfield, this will matrix a 5.1 surround sound effect, unless of course you are sending a Dolby Digital 5.1 audio signal from your TV broadcast into the Home theatre system, also have to check the TV audio output to send audio output to a Home theatre system in other than 2 channel stereo.
Posted on Feb 09, 2009
My surround sound will not work through the TV, only the DVD
If your tv and surround has an optical input/output.Then you can connect with an optical lead.This will then play the sound from whatever you are watching.You normaly select dig1 or input1 on the surround system.
Nov 12, 2009 | Panasonic Televison & Video
I have a panosonic surround sound system and a toshiba 60" tv and when watching tv speakers have a humming sound , but when watching a dvd speakers are fine and no humming sound.what is the problem? Tv...
it depends on what volume level the tv is on
if the level of volume is low and making the sound then try unpluging or pluging in the sound system to the tv
Sep 13, 2009 | Televison & Video
UMC 19in TV with built-in DVD player - model L19/7TCD
Try connecting earphones or headphones to the 3.5mm Headphone socket on the TV and check this works correctly, i.e hear TV when watching TV, hear DVD when watching a DVD etc.
If all is OK, purchase a 3.5mm Jack to L/R Audio/Phono cable. Connect the 3.5mm jack in to the headphone socket on the TV and connect the red/white phone ends to the 5.1 surround system.
It should solve it. SCART out is not always live in all sources so is not a reliable way to connect.
May 22, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Surround sound ok whilst playing dvd but not working for tv
On your Sagem TV you should have two RCA ouputs (red and white connection usually marked ouput) ) Connect these to the input on the surround system using the interlink cable.
You should then be able to hear the sound from the TV by changing the SOURCE on the home cinema remote.
Better still if you have a digital out on your TV use that instead.
Nov 25, 2008 | Audio Players & Recorders
Surround on my system
Have you tried what I said and changed the settings in the DVD?
Also, is it a built in DVD player / TV combo, or a separate unit? You can try doing a hard reset..Unplug the TV from the mains, disconnect all cables from tv and wait for 1 hour. Then press the power button on TV and plug in the mains. Same if your DVD player is stand alone.
Try that and let me know..
May 10, 2008 | Koss KS3102 System
How do I get surround sound from TV?
see if ur DVD player has a TV/Audio in....you have to set it up so u watch TV threw your DVD player (if you have one of of the Surround Sound in a box systems) if you have SS w/ a receiver then you'd have to run Audio out from your TV/Cable/Satellite to the receiver for it to work
Feb 02, 2008 | Jensen JHT805 System
No sound from TV only when playing DVD
Check carefully the RCA conections or others.Sometimes this conections break inwards end cause this problems.Check also the lead and the Set up from surround sound.Verify if the TV has settings for this kind of operation. A strong hug !!!
Jan 16, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
Home theater system connections
Hi
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
Oct 15, 2007 | LG 42PC5D Television
No sound through TV
In case you connect the System to a TV set using the Scart Connector, only the video signal is terminated, Audio is actually not wired inside the SB100 Scart connector.
Sound will only be amplified through the system itself (through the satelites and Sub) it can not be utilized as a stand-alone DVD player.
So after connecting your surround speakers the problem will be solved
Apr 30, 2007 | Sony DAV-SB100 System
Insignia NS-H2002 Theater System Logo
720 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
