Question about Sanyo AVM-3658S 36" TV
Can't Turn off Closed Captioning on Sanyo 36 in TV AVM-3658
The remote has a caption button and when I select it, it displays, OFF, Caption 1, Caption 2, QuickCap and so on. Pressing the caption button causes the selection to move to the next available selection in the list.
How do I actually select ''OFF'' and get it to work? I've tried every combonation available to no available. I even tried resetting the TV to factory specs but the closed captioning remains on.
Thanks!
  • 2 more comments
  • Anonymous Mar 28, 2009
    I have the same problem and it is REALLY frustrating!! someone help!
  • Anonymous Apr 30, 2009
    I really wish someone had an answer for us! I lost my Sanyo remote & cant even turn off trhe closed captioning with a Universal remote.
  • Aridwaters May 21, 2009
    indeed, I too have no remote and can't turn off the cc display, I have sent an Email to Sanyo customer support and will let you know the result.
  • Aridwaters May 23, 2009
    Ok folks, This is what I received form Sanyo support: "Without the original remote you willnot be able to access the closed captioning." However I will still work on this issue. I'll get back to you latter.
    Problem Solver:
  • 14 Answers
Hi Hfrohman, This may sound crazy, but, press and hold the power button on the TV while unplugging it, continue to hold power button for 60 seconds or more. Release it and plug TV back in. Sometimes that will clear the settings.
I hope that works for you.
Posted on Jun 26, 2017
SOURCE: Closed Caption won't turn off
The following should solve your problem if you have a comcast digital cable box and possibly for others.
Hey, it's worth a shot!
Turn the TV Power on and cable box power off.
Press the MENU button on the front of the cable box.
Scroll down to the caption item on the menu and toggle it to "disabled"
Press the menu button again to close.
Hope this helps!
Posted on Oct 12, 2008
techman
  • 3130 Answers
SOURCE: closed captioning
I am sorry you don't. You will need the original remote. I have enclosed a link where you can see the original remote and order one if you want to. If you see the picture, there is a caption button on the remote to turn on and off the closed captions Good Luck. Here is the link http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=DS24424&brand_pn=SANYO_DS24424&mode=large&uid=11872683567810
Posted on Aug 16, 2007
  • 3 Answers
SOURCE: can't shut off closed caption no remote
Have you tried unplugging the entire device and plug it back in 15 secs later.
Posted on May 17, 2009
  • 864 Answers
SOURCE: Can't remove the closed caption from running on my tv
Press CAPTION button on remote. Press 0 key to cycle through the caption settings including OFF
Go to: http://www.retrevo.com to download manual.
Posted on May 29, 2009
philschneide
  • 448 Answers
SOURCE: is there a way to turn off closed caption on this
Don't know on the Sanyo, but most TVs let you turn off the CC via the remote, either by a CC listing on the remote itself, or by going to the menu (menu button) which shows on the TV screen, then working your way through the menu to the closed captioning. That should let you turn it on or off.
Good luck.
Posted on Oct 05, 2009
How do I turn the closed caption off? I have a remote
      Immediately-within one second-push the MENU button on your remote. You should see a User Settings menu screen displayed. Use the arrows keys on the remote to highlight the Closed Caption option and press OK or SELECT on your remote to toggle Enable/Disable. Power on the Set-Top Box to return to watching TV.
      How do I turn Closed Captioning on or off? ' Time Warner ...
      www.timewarnercable.com/.../closedcapt/how-do-i-turn... Time Warner Cable
    Feedback
    How do I turn on/off closed captioning? - Comcast Help and Support ...
    forums.xfinity.com/t5/.../How-do-I-turn...off-closed-captioning/.../1325...
    Jun 25, 2012 - Turn STB off and leave TV on; Press Menu on STB or remote control; Using the ... If this does not activate Closed Captioning, try the following:.
Jan 24, 2016 | Televison & Video
How to get rid of closed captioning
If pressing the cc button on the Sharp remote does not turn off the closed captioning then the closed captioning is most likely coming from the cable box or whatever you have connected to this television. You can go into the cable box menu by pressing the menu button on the front when it is turned off. That's right turn off the cable box and then press menu on it to access the hidden menu that includes closed captioning. Scroll down to closed captioning and scroll over to disable. A number of other Directv receivers have the CC located on a "captioning" tab on the "display" page under setup and for dish network:
Setting Closed Captioning:
  1. Press and release the MENU button and then select "Preferences."
  2. Select "Closed Caption."
  3. Select "Caption On/Off."
  4. Select "CC is On."
  5. Select "Done."
Sep 20, 2011 | Sharp Televison & Video
How do i turn off closed caption without remote?
There is a manual button said MENU on the tv frame wright?Yes.Try push the MENU button locate functions like Close Captioning like 1,2,3... turn it all off.Also TEXT like 1,2,3... turn it all off too.Tv should have no more Closed Captioning.
Jul 31, 2011 | Sanyo DS31520 31" TV
How do I turn off the caption on this freakin Sharp Liq. Crystal T.V.? I lost the manuel! IT'S NOT A SANYO...IT'S A SHARP T.V. MODEL # LC40E77UM
hi,
For switching off the closed caption option do the following.
1. Press CC on the remote.
• This will present the Closed Caption information display.
2. Press CC while the Closed Caption information is
still on the screen.
• Press repeatedly until you select the desired closed
caption service as OFF.
ok
Feb 25, 2011 | Sanyo DS31520 31" TV
How do I get closed captioning on a Samsung TV model TXJ2754?
Hello
Your TV displays the closed captions that are broadcast with some
television shows. These captions are usually subtitles for the hearing
impaired or language translations. All VCRs record the closed caption
signal and most pre-recorded commercial video tapes provide closed
captions. Check for the closed caption symbol in your television
schedule and on the tape's packaging: .
1 Press MENU repeatedly until you see the Setup menu. Press CH
to select "Caption."
2 Press VOL+ to open the Closed Caption menu.
3 Press VOL + to turn closed captioning on.
Misspellings and odd characters can occur in captioning. Also, there may be a
captioning delay after changing channels. Neither situation is a TV malfunction.
4 Press CH to highlight "Mode." Press - VOL or VOL + to choose
"Capt." (captions) or "Text." In caption mode, captions appear and
cover a small portion of the picture. In text mode, information unrelated
to the program, such as news reports, are displayed and
often cover a large portion of the screen.
5 If you wish, use CH , CH , or VOL + to change the captioning
channel or field. Then, press DISPLAY to return to normal viewing.
 Different channels and fields display different information, such as additional
languages or supplemental information
Nov 23, 2010 | Samsung TXJ2754 27" TV
How do I enable closed captioning on my Zenith PIP System 3? Thanks.
Hello
To enable close cationing on your TV follow this:-
[1] Press "Menu" button on the remote control to appear "Setup" menu on the screen.
[2] Use "Up and Down" arrows on the remote contol to select "Captions/Text" on your screen.
[3] Press "Right or Left " arrows to select any one of the following options. Caption-1, Caption-2, Caption-3, Caption-4 Text-1, Text-2, Text-3, Text-4.
[4] Press enter to return TV viewing.
To turn the caption feature to "On" or "Off'
[1] Press menu key on the remote control to display "Setup" menu.
[2] Using "UP/DOWN" buttons to select captions on your screen.
[3] Press "Right or Left" arrow to switch the captions feature 'ON" or "OFF" or "EZ Mute"
[4] Press enter to continue.
Ok.
Oct 22, 2010 | Zenith C27A24T 27" TV
I do not know how to turn off the closed captioning on my son's orion tv set. I do not know the model type. I do know that closed captioning options are not on the menu.
If you have the original remote look for a button labeled "CC" or "Caption/Text" press this button till the screen says caption off.
Jul 06, 2009 | Televison & Video
Cant get rid of captions
look on top and behind of the monitor you will find buttons for your TV then follow this steps: The Setup menu lets you configure the TV to fit its surroundings and your preferences. To access the Setup menu, press MENU, and then select Setup from the Main Menu.closed caption options are: CC Setting Lets you choose the way closed captioning information appears on the screen. Off No captioning information displayed. On Always Captioning information shown always, when available. On When Muted Displays captioning information, when available, whenever the TV?s sound is muted by pressing the MUTE button. The captioning information is not displayed when the sound is not muted. Make sure all of the options for closed caption are off press exit and you are good to go.
Aug 23, 2007 | iLO 3200 32 in. LCD Television
Closed captioning
Aug 16, 2007 | Sanyo DS24424 24" TV
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Open Questions:
See all Sanyo AVM-3658S 36" TV Questions
Televison & Video Logo
3,773 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
