Question about Canon i80 InkJet Printer
Canon i80 Service error 5C00
Led flashing orange 4 times
  • Anonymous Feb 10, 2009
    My printer display service error 5C00, how could i fix that error?
5 Suggested Answers
SOURCE: error 5C00 on Canon iP90
i took out both printer cartriges then put them back in. there was a window that asks if you replaced the cartriges; click yes then click on the black and color boxes indicating you replaced (re-inserted) both cartriges. for me the light stopped blinking (previously, it was blinking orange 4 times). next i tried to print but only yellow and black appeared. i then cleaned the head 2 times.
to clean:
-go to control panel
-click on printers
-click on printers and faxes
-find your printer, right click on it
-click properties
-find the maintenance tab
-click cleaning
(clean a couple of times if needed)
hopefully it works...
Posted on Jan 31, 2008
SOURCE: Canon ip5200 Service Error 6A00
This might have something to do with canon's absurd print cartridge limitation agreement.... where the print cartridge will only print for a certain limit and then locks
Posted on Jul 24, 2008
SOURCE: canon printer ix4000 service error 5C00
bagai mana caranya menanggulangi eror 5c00 Printer ix4000, mohon petunjuknya
Posted on Jun 07, 2009
  • 226 Answers
SOURCE: Service Error 5C00 - iP90v Pixma Canon Printer
Clean it out underneath the printhead & cleaning mechanism first (paper towel), then do the fix routine.
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
also there are TWO distinct steps to resetting the TWO ink counters in aan iP90. Enjoy.
3-3. Adjustment / Settings
(1) Service mode
The basic operations are the same as those of the i70 / PIXUS 50i.
In this section, destination settings, how to reset the waste ink counter, and EEPROM information
printing, which differ from those of the i70 / PIXUS 50i, are detailed.
1) Turn off a printer. While pressing the Resume/Cancel button, press the Power button.
The LED lights green to indicate that functions are selectable.
button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the
alternately lights in either orange or green, starting with orange.)
4) When the LED lights green, press the Resume/Cancel button as many times as you need, to
select the preferred function. (See the table below.) Each time the Resume/Cancel button is
pressed, the LED alternately lights in either orange or green, starting with orange.
(The color red indicates the changes from the i70 / PIXUS 50i.)
Time(s) LED Function Remarks
0 times Green Power off When the print head is not installed, the carriage
returns and locks in the home position.
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting Proceed to step 5) below. Once executing step 5), then, move on to step 6) to select the waste ink counter to be reset. (Different from the i70 /
PIXUS 50i.)
5 times Orange Destination settings Proceed to step 5) below. Once executing step 5), then, move on to step 7) to select a
destination. (Different from the i70 / PIXUS 50i.)
10 times Green Return to the menu selection
5) After the function (menu) is selected, press the Power button. The LED lights green, and the
selected function will be performed. (When the operation completes, the printer returns to the
6) Press the Resume/Cancel button the specified number of time(s), then press the Power button.
Time(s) LED Waste ink counter to be reset
0 time Green Main waste ink counter
1 times Orange Platen waste ink counter
2 times Green Main waste ink counter and platen waste ink counter (at the
same time)
Note: When the waste ink counter is reset, print the EEPROM information as shown below,
and confirm that the value of the counter is 0 %.
8
7) Press the Resume/Cancel button the specified number of time(s) according to the destination
listed in the table below, then press the Power button.
Time(s) LED Destination
1 time Orange Japan: PIXUS iP90
2 times Green Other than Japan (A4): PIXMA iP90
3 times Orange Other than Japan (LTR): PIXMA iP90 (LTR)
Note: After the specific destination is set, print the EEPROM information as shown below, and
confirm the model name.
Print sample:
1:iPXXXX 2:V1.02 3:IF(USB=1) 4:D=004.9 PD=000.0 5:ST=2005/09/27-18:30
6:ER(ER0=1000 ER1=5100) 7:LPT=2005/09/028-09:09 8:PC(M=002 R=000 T=001 D=009 C=009)
9:CLT(BK=2005/09/27-18:30 Cl=2005/09/27-18:30) 10:CH=00002 11:CT(BK=040 CL=013)
12:IS(BK=1 C=0 M=1 Y=1) 13:IC(BK=00000 C=00000 M=00000 Y=00000)
14:Power(SON=00009 SOFF=00009)
15:REG=0 16:UR(A(BKoe)=+01 B(Coe)=-01 C(Moe)=+01 D(SCoe)=-01 E(SMoe)=+01 F(BKbi)=+01
G(CLbi)=+01 H(BK-CL)=+01 I(SCLbi)=+01 J(C-SC)=+01 K(M-SM)=+01)
17:WP=0024 18:CDIN(LG=001 PB=000) 19:MSD(015)
20: PAGE(All=00083 PP=00035 HR+MP=00003 PR+SP+SG=00003 GP=00000 PC=00000 ENV=00000)
21:CDPAGE=00003 IRPAGE=00003 BTPAGE=00003 PBPAGE=00000 22:BAT PAGE=00000
23:EDGE=00083 24:L=00000 25:HEAD Temp=30.0 26:Env Temp=30.0 27:FF(3F 3F 3F)
HDEEPROM
1:V0001 2:SN=0000-3D6B 3:LN(00000 00000 000001 000003 00001 00000 00000) 4:ID=00
5:IL=(BK=000 C=+01 M=000 Y=+01 C2=+01 M2=000 Y2=+01)
Printed items:
1. Model name 2. ROM version 3. Connected I/F (USB1) 4. Main waste ink amount, Platen waste ink amount
5. Installation date 6. Operator call/service call error record 7. Last printing time 8. Purging count
(manual/deep/timer/dot count/print head installation and removal/ink tank installation and removal)
9. Cleaning time 10. Print head installation and removal (change print head) count 11. Ink tank installation and
removal (change ink tanks) count (Bk/CL) 12. Ink status (Bk/C/M/Y) 13. Total ink consumption 14. Power-on
count (soft power on/soft power off/hard power on) 15. Print head alignment implementation 16. User print head
alignment values (Bkoe/Coe/Moe/SCoe/SMoe/BKbi/CLbi/BK-CL/SCLbi/C-SC/M-SM) 17. Number of times of wiping
18. Number of times of camera port connection and removal (Legacy, PB) 19. Number of the maximum printing
intermission in days 20. Number of print pages (total/plain paper/high resolution paper + Matte Photo Paper/Photo
Paper Pro + Photo Paper Plus Glossy + Photo Paper Plus Semi-gloss/Glossy Photo Paper/Card/Envelope) 21.
Number of Camera Direct Print pages (total), number of IRDA print pages (total), number of Bluetooth print pages
(total), and number of Print Beam print pages (total) 22. Number of print pages using battery (total) 23. Number of
borderless print pages 24. Number of print page (L/4” x 6”) 25. Print head temperature 26. Inside temperature
27. Line inspection information
HDEEPROM
1. Version
2. Serial number
3. Lot number
4. Print head ID
5. Ink ejection level (Bk/C/M/Y)
Posted on Jul 23, 2009
devdeep545
  • 137 Answers
SOURCE: why flash by 5 times the orange led?
Probably your waste ink counter should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Good Luck, I hope this helps?!
Posted on Aug 12, 2009
Resolving error 5C00
If a Pixma go here
PIXMA Printer Error Codes and Error Messages
5C00 - Orange and green blinking 4 times Description:
A service error has occurred.
Resolution:
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
Sep 09, 2014 | Office Equipment & Supplies
CANON MG8100 series error 5C00
Per http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#5c00
Resolution:
  6. Close the cover.
May 27, 2014 | Canon PIXMA iP3500 Printer
What do errors messages 5100 and 5C00 indicate when offered by my Canon Pixma iP90?
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times
while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)
Note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
5.Turn off the printer.( it must be turn off) then turn it on again
Nov 19, 2010 | Canon PIXMA iP90 Mobile Printer
5C00 error on Canon iP90 printer
The alternate flashing of orange and green indicates a service call error, something that needs to be taken into a canon authorized service facility for repair. 4 alternate blinking of these lights indicates a problem with the purge unit, most likely requiring replacement.
May 21, 2009 | Canon Office Equipment & Supplies
Error code 4 flashing orange - code 5c00
Hi Chris,
Error code 5c00 (flash in orange /green 4 times) indicates that purge unit has broken so that the printhead is locked down when initializing process performed. Sorry I have to say that no first aid for this problem unless you bring it to nearest service centre for part replacement. Hope this information helpful for you.
Regards,
Source:
Canon Inkjet Forum
Dec 13, 2008 | Canon PIXMA iP90 Mobile Printer
MY PRINTER
i AM GETTING 5C00 ERROR
Aug 27, 2008 | Canon i80 InkJet Printer
Canon i560 Ink jet Error Code 5C00
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
May 05, 2008 | Canon BubbleJet i550 InkJet Printer
Service error 5C00
Service error 5C00 might indicate the purge system.
The "rattling sound " is probably coming from the (gears of-) socalled purge unit. May be one ( or both) of the ink tanks is not properly put back in again,or the printhead-lock is not locked. and the purge system is blocked.
Remove the ink tanks and remove the printhead, closw the printhead-lock, close the printhead cover, switch the printer of, switch the printer on again. If the rattling sound is still there, than you might have an expensive problem to be solved.
If the rattling sound is gone, there is probably something wrong with the printheadlock.
Mar 12, 2008 | Canon i80 InkJet Printer
Error Message 5C00
4 times is usually Automatic print head alignment
Set a sheet of plain paper (A4 or letter) in the ASF.and adjust.
Jan 14, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Canon i80 InkJet Printer Logo
403 people viewed this question
old marine
old marine
Corne Viljoen
