Question about Zenith B27A11Z 27" TV
Adjust Convergence on Zenith B27A11Z
Can somoene tell me the sequence to get into the service mode to adjust the convergence on this 27" Zenith , Model B27A11Z ? Thank you,
    President:
  • 2,992 Answers
You don't adjust convergence through a service mode on one of these sets. With a conventional CRT, convergence is done by physically adjusting the convergence rings on the neck of the tube, and the position of the deflection yoke near the bell. You would also need a crosshatch generator to provide the required test pattern for adjustment.
Posted on Feb 23, 2009
I think my convergence is off. Just the green and red seem to look off. I do not know how to adjust each color. When you go into the convergence setting under the menu and it just does like an automatic...
You will need to know How to Enter the Service Menu to bring up the Convergence Pattern in order to adjust the Convergence,another thing is it depends on which chassis you have RCA had bought the right to use the name Zenith, when in fact these TVs had RCA Chassis and not Zenith Chassis
Remove the back to Tv, Make sure TV is unpluged and look to see if you have on a board Located on the right hand side
2 Big Black ICs they will have Part number on them example STK392-570 these are your convergence ICs that need to be replaced.You can exchange this board for new board at Zenith exchange moduels 1-800-632-6637
But if you have the RCA Chassis then you will have 2 bottom boards one on the Left hand side will be the Deflection board it will have the FBT flyback transfomer on it and their is 2 Ribbons that connect to the board on the right handside which is the ssb board that has your cable/AV input jacks on it.and their will be 2 boards above the 2 bottom boards if these are the boards you have then you can with Tv Off Press and Hold vol- and ch- wait untill TV comes on,release buttons and then you should be in the service menu to adjust convergence manually. R/G/B
For these chassis PTS rebuilts boards 1-800-844-7871
Jun 26, 2011 | Zenith R57W46 57" Rear Projection...
Samsung Projection TV - Yellow White Level and Auto Focus Failure
perfect focus is based on service mode convergence. FActory setting as it were. the set needs to converged in service mode then these values stored then it should work
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
How do i make all the colors sync up to get rid of yellow and blue shadowing
Go into the customer menu with the remote and select convergence; if red or blue will not adjust in some direction you have a convergence circuit problem----depending on actual model number set uses two convergence chips--they would have to be replaced.
If the convergence does adjust in the customer menu but not good enough I can give you the sequence to get into the tech menu to fine adjust-remember if if will not adjust in the customer mode, it will not adjust in the tech mode either.
See attached photo of Philips convergence problem.
If this told you something you did not know, rate this solution as I do this here for free.
REGARDS, SD TECH
Aug 13, 2010 | Philips Televison & Video
Service mode for Samsung HC-Pxx41W
with tv off,
press in sequence mute - 1 - 8 - 2 then turn on the the power
use the number keys, the direction pad, volume and channel buttons to adjust convergence
Mar 19, 2009 | Samsung HC-P4741W 47" Rear Projection...
How To Adjust Convergence - Zenth Z25X225
no you cant do that.in service mode you dont have that option for this tv.you only have this option at projection tv-s
Jan 06, 2009 | Zenith B27A11Z 27" TV
43F300 convergence
Convergence kit # X480306 for your Model #.....
Replace parts & activate auto-focus......T.
Sep 01, 2008 | Hitachi 43F300 43" Rear Projection...
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Blurry text on 27-inch Zenith "Sentry 2"
I have had this problem before and restarting the reciever fixed it. Just push the red button under the front panel of your reciever, or unplug the reciever for a minute or so.
May 13, 2008 | Zenith B27A11Z 27" TV
Adjust color convergence automaticly
I hate to tell you but if the colors are not aligning the way they used to is because the set has developed a problem know as a convergence problem,you should be able to align the colors (red,Blue)but if they are not going in is because the covergence IC's are going bad,If you are familiar with electronic service you can do some of the work yourself but sometimes still does require the help of a servicer to do the aligments from the inside,if you are not too familiar be safe and call for assistance.
Oct 20, 2006 | Zenith R56W28 56" Rear Projection...
Zenith B27A11Z 27" TV Logo
121 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
