Question about Brother LS-2125 Mechanical Sewing Machine
What foot do I use with the twin needle?
Need to know what foot to use with the twin needle, the manual doesn't specify. Also, the twin needle seems to hit the bottom plate (I don't know what it's called) when I lower the needle with the knob. How do I adjust that?
  • 69 Answers
You need to use the zig zag or satin stitch presser foot with the twin needle. You also need to make sure you have the zig zag plate on your machine. Also, remember when using the twin needle, you cannot put your stitch width beyond half way. The best thing to do is once you select the width, turn the handwheel to see where the needle is going to hit, you want to make sure it clears the plate or it will break.
Posted on Feb 09, 2009
Do I need to use a specific "foot" with twin needles? The one needle hits the foot I have
You need to use something like a zig-zag foot that has a wide opening for the needle. If the needle is still hitting the presser foot, then your machine may need adjustment or you can try a twin needle where the needles are closer together (twin needles are available with varying distances between needles).
Jul 11, 2017 | Sewing Machines
Can I use a twin needle on a Singer Trafition? It seems to only sew one line of stitches.
Probably depends on the model. Was a twin needle included with your starter kit?
This one indicates it will take a twin needle:
Your owner's manual or the product specifications are probably the best source for information.
Instruction Manuals
BTW, you are using 2 spools of thread, right? You need to thread both needles with separate spools (do not twist the threads when threading!).
Double Needle Tips Video Demos
How to Use Twin Needle on Your Sewing Machine
Be sure to verify the machine is set to straight stitch. Any zig-zag could break one or both needles!
You also will have to thread the needles manually as the needle threader will not work on twin needles.
ALWAYS RAISE the presser foot when threading the top thread!
Jun 22, 2017 | Singer Sewing Machines
I inserted the twin needle and threaded it. However, I don't know what what stitch I should use.
we have no idea here either try someplace that gives sewing classes locally
Feb 16, 2017 | Sewing Machines
I just need instructions to thread a Bernina Virtuosa 160 for pintucking
Your owner's manual should have instructions for using a twin needle.
Most machines can use a twin needle. However, some machines have two tension disks so one can separate the two threads and get equal tension. (The Bernina 930 has two tension disks, so am assuming your newer machine does also.) Look at the top of your machine where the tension mechanism resides and see if there is a right and left side. In either case, do NOT thread both threads at the same time as the threads can become twisted. When threading the machine, ALWAYS RAISE the presser foot, thread one thread completely. If threading the left side of the tension disk, also thread the left needle. Then thread the second thread, making sure to use the other side of the tension disk and needle.
Just a reminder to be careful using any zig-zag or decorative stitches since a twin needle requires a narrower stitch width to avoid broken needles.
Stitching Odyssey How to use your twin needle
How to use twin needle So Sew Easy
Bernina Instruction Manuals
Jan 13, 2017 | Bernina Sewing Machines
Can you use twin needles on bernina 1080
I have a Bernina 930 Record that will take twin (even triple) needles, so I don't know why your 1080 wouldn't. Just be sure your machine does not have the straight stitch plate on it, that your presser foot can accommodate zig-zag stitch, and that you carefully adjust any zig-zag stitch width so the needles do not hit the presser foot or stitch plate. I'd suggest installing the double needle and then carefully hand rotate the handwheel to see if the needles will hit anything. If you can make a full rotation of the handwheel without anything hitting, then slowly try it with the motor engaged.
Feb 23, 2015 | Bernina Sewing Machines
I have for gotten how to make the machine sew and im having trouble threading a bobbin for my moms machine elna 7000 i need a manual or a quick note to get started
YOu can down load a manual from here
Just remember to click the bobbin thread into the tension device correctly and hold the two threads behind the pressure foot when you start each seam - Elna top loading bobbins give great stitch quality but you just need to keep stray threads out or they'll jam up.
Also, you must use the Elna plastic bobbin that the manual specifies for this machine - the 5000, 7000 and 9000 were Elna Tavaro Switzerland's first foray into computerised machines and first released in 1986.
Also, please check the manual when you go to buy twin needles, there are two types now as computerised machines usually need the twin needles offset from the shaft position. They have red or black plastic block between the shaft and the twin needles - I think you need the red ones but just double check the manual to make sure. And you can't do all the wide stitches with a twin needle as it will strike the foot.
Hope this helps a little.
Jan 16, 2011 | Elna 2007 Mechanical Sewing Machine
Can I use a twin needle on my Janome MW3018? Doesn't mention it in my instruction manual and I don't know how to thread the machine for twin needle sewing.
Twin needles can be used on any machine. Just make sure you use the correct presser that allows both needles to work without hitting the foot. cannot zig-zag or use any other fancy stitch with a twin is strictly for straight sewing. You have to use 2 spools of thread .....thread your machine with both threads as if they were one thread but separate the threads when you get to the needle. There is no change to the bobbin. Happy sewing. I can't be bothered to go to all this trouble so I just sew 2 rows to get the same look. Ofcourse you have to be very good at sewing perfectly straight seams doing it this way. Try both methods on a scrap and see which method you prefer.
Dec 21, 2010 | Janome Sewing Machines
Brother LS-2125 Mechanical Sewing Machine Logo
682 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
