Cars & Trucks Logo
Posted on Feb 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1989 tempo 2.3 4 cyl 5 speed, runs w/ starter fluid
The fuel injectors, fuel filter and air filter have been replaced, this car sat for 2+ years garaged not running. now it will run only if you spray starter fluid into the air intake( when you do this it,ll run great till the starter fluid can goes empty). the gas gague doesn,t work but the fuel pump was able to empty the gas tank,then i put new gas in w/ injector cleaner into tank. i have several more things to fix on this car but need to have it running first. hope someone might know what i need to do to get it running. thanks,
joe
Jim London
Level 2:
  • Expert 257 Answers
  • Posted on Feb 09, 2009
Jim London
Expert
Level 2:
Answers
257
Questions
0
Helped
273251
Points
839
Hi, The carb is gummed up from sitting. The best solution is to take it apart and clean it. The starter fluid indicates that it has clogged jets or stuck floats. The good news is that if it cranks with the starter fluid everything else is probably OK. Good Luck!
1989 Corvette Injectors No pulse
You have wasted a lot of money buying stuff that is not needed.
Check the pulses from the crank shaft sensor.
3answers
Car will start sometimes other times i will have to continue to crank the engine it cranks everytime
As it cranks, is there white or black exhaust smoke ?? If yes, the fuel injectors have solid build up on the tips. Normally, a quart bottle of injector cleaner treats 20 gallons. Pour 5 to 7 quarts of fuel injector cleaner. With cold engine (been parked for at least an hour or overnight), while cranking engine, have 2nd person spray starting fluid into air filter. DO NOT PRESS ON GAS PEDAL !!! Let the starting fluid do its job of starting the car. Starting fluid is highly combustible, so its important you don't give any gas while its cranking and 2nd person is spraying into air filter. When engine starts, stop spraying starting fluid and give a little gas. If engine begins to die, immediately spray a little starting fluid again. When engine begins to run, let it run a few minutes to let fuel injector cleaner to do its job (loosen solid carbon build up on tips of fuel injectors).
2answers
My '01 impala 3.4 v-6 flat spots when COLD, at around 20mph. the idle is ruff with random misfires. acceleration is overall poor. when HOT, most symptoms go away leaving only some slight acceleration...
depending on mileage, but possible tune-up could fix it. if already done then check ignition coil pack and ignition wires also spark plugs, check vacuum hoses for leaks or porous, last injectors clogged - use some techron fuel injector cleaner (wal-mart has them). Also get the throttle body and iac valve cleaned by throttle cleaner . Also this other possibilities are to be checked and confirmed.:---- Engine running rough or misfiring can be cause by the following:
1.Defective spark plugs
2.Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4.False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
11. Manifold absolute pressure sensor
12.Mass Airflow Sensor
13.Idle air control valve
--------- This should help.Keep updated.Thanks.Helpmech.
When cool it runs fine, but if my engine is a little warm it seems to "miss" or have choppy acceleration. I've recently replaced my plugs and wires, oil filter, fuel filter, and air filter. It is an 89'...
It may be running a little lean when warm. Try adding an injector cleaner to clean the injectors. Also check for a vacuum leak from a bad hose.
1helpful
2answers
1987 Ecoline van V-8 engine hasn't been started in about 7 years. It ran good before that. What do I have to do first to start it and get it running?
I would change all the fluids and either try dry gas or i would recommend that the gas tank be thoroughly drained and new gas put in the tank.If you have a hard time getting started try to use starter fluid in carburetor or if you have none just use gas. If the vehicle is equipped with fuel injectors locate air filter and follow air duct to engine that is where starter fluid or gasoline will have to be pored to prime the injectors.if it don't start the engine should be tuned up with a major tune up replace all filters ect even if it starts without tune up i would tune it up asap!
I have a 1989 GMC sierra 4.3 Liter, fuel pressure
u can do the check the other way around/ disconnect the fuel line that supply the injectors/ put the pipe in a small plastic container to see if fuel is being supplied by the pump and avoid fuel spill in ur engine/ crank the engine for at least 5 seconds see if the fuel squirts with pressure/ if it does then ur fuel pump is ok / blockage is somewhere down the fuel line/ u can check fuel lines by blowing it with air but u gonna need the help of an air compressor.....
3answers
Lack of power in gas pedal
Check fuel pressure and see if its around 30-35 psi while under load if not replace fuel pump, also the gas thats in the tank may be no good if it has sat for so long..
1helpful
1989 for tempo starts fine but after idling for a few minutes will quit. Will stall when you pull up to a stop sign. Have to keep the engine revved up to keep it running. The check engine light comes on...
hi,
its time for new fuel filter, new fuel injectors, spark plugs, spark plug wires, cap and rotor. the engine in the tempo is a good one and if you take care of it that car should last quite a while longer..
jm
(had a 1989 Tempo AWD)
Not running
WENT A ENGINE IS PUT TO REST FOR LONG PERIOD OF TIME (4, 5YEAR)YOU GOINg TO HAVE BUILD UP EVRY WERE INJECTORS FUEL LINES FILTER SENSORS ECT......THE BAD FUEL THAT MADE POWDER DEPOSIT ON THOSE PARTS ARE A VERRY PROBLEME TO YOUR ENGINE .IF YOU CAN AT LIST CHANGE YOUR INJECTORS ,FUEL FILTER AND THE FUEL PUMP THIS ONLY WIL SOLVE YOUR PROBLEME AT 80% .....nicolas ......
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
