Question about Refrigerators
Whirlpool WBM 39 Top Mount392LT. Does Not Work Since Power Failure.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Have you checked the breakers? Or tried the WBM 39 in another wall outlet or power source? Alternately, you can try unplugging the unit for to reset/revert the electronics to factory default. Should these be not corrective, then it would be needed to make use of a DVM/VOM and check for the presence/absence of supply voltage to the electronics inside. Foremost to check would be the stepdown transformer that supplies the B+ for the logic/controller boards.
Pls post back if you are considering a DIY (do-it-yourself), access/familiarity with a multitester and comfortable working with electronics/electrical devices.
Good luck and thank you for using FixYa.
Posted on Feb 09, 2009
  • 217 Answers
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Hi, I have a quite old Whirlpool refrigerator model no: WBM 377. I want to find the replacement for top door hinge (P/N: 481241719454). Can anyone direct me where to go to search for the spare part?
    Try lookingwhirlpool on the whirlpool web site or searching the web for whirlpool spare parts, Got loads come up straight away but not sure what country you are in so uk ones may not be suitable for you
    Jan 03, 2016 | Whirlpool Refrigerators
    Whirlpool wbm 48
    That is a short on gas problem but make sure that the fan is running and check the settings on the inside of the unit so that you can have a circulation around the whole unit. If all this is good then Check your warranty or get someone to check for a gas leak. Get fixed and charge it with the write amount of gas and your problem will be solved.
    Good luck
    Will
    Jul 28, 2014 | Whirlpool Refrigerators
    Refrigerator whirlpool wbm 501
    Problem is defrost thermostat, defrost heating element or defrost timer and or low gas in the system. Remove the back panel in the freezer and look to see if the evaporator coils are frozen solid with ice. If so the problem is no defrost cycle. If no ice then the unit is low on gas and it has a leak. If the refrigerator is old... recycle it and go buy a new refrigerator from Whirlpool.
    Feb 07, 2014 | Refrigerators
    Whirlpool wbm 569/1
    Did you give the Refrigerator 24 hours? Did you lay it on its side shortly before plugging it in? Does your wall outlet have power or maybe the circuit breaker is popped? Otherwise you probably need a replacement
    Oct 22, 2013 | Refrigerators
    We have a duet washer wfw9200sq00 and it won't power on - just gives 3 beeps. I did get a F71 error code
    F-71 user interface heartbeat failure, com failure between touch pad and central control.
    You ain't sitting goopy liquid detergent on top of the washer is ya? Stuff goes down into the controls and oopzy. themobilian_2505.jpg
    Service manual for duet with repair photos
    Jun 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool wbm 39 fridge freezer. Has not been opened for a day or two and now trips the power supply every time you plug it in, it does this after about 1 min
    TRY TO USE A DIFFERENT POWER SUPPLY. IF IT WORKS YOU GET AN OVERLOAD ON THE OTHER CIRCUIT.
    IF IT DID THE SAMETHING THE UNIT HAS A SHORT
    YOU NEED TO DO AN EYE AND MANUAL CHECK.
    UNPLUG IT GO TO TH MOTOR COMPARMENT TURN EVRYTHING MANUALY TO SEE IF THEY TURN NORMALY . IF ANYTHING JAMB THAT SHOULD BE THE PROBLEM
    Oct 24, 2010 | Refrigerators
    TRY TO USE A DIFFERENT POWER SUPPY. IF ITY WORKS. THERE IS AN OVERLOAD IN THAT CIRCUIT NEED TO LOOK FOR.
    IF IT DID THE SAME. THER IS A SHORT ON THE SYSTEM.
    UNPUG IT GO TO THE COMPRESSOR COMPARTEMENT
    DO AN EYES AND MANUAL CHECK. TURN EVERY SINGLE THING THAT SHOUD BE TURN FREELLY BY HAND.
    IF YOU SEE ANYONE OF THEM JAMB THAT SHOULD BE THE PROBLEM
    I have a Whirlpool Refridgerator model WBM39MS. It stopped cooling and I had it repaired. The Repairman replaced the electronic control box. Repairer claims that the compressor is working. It now seems...
    Hi Lollipop, partially working fridge? A fridge either works or not, cold air is made in freezer then distributed to fridge via a vent. In your case WBM Series fridge, top mount freezer blows air down a vent (back centre of chiller compartment). A common fault with the WBM Series is both the PCB and Interface Panel (PCB beside compressor back of fridge, Interface is display panel front of fridge).
    So if freezer is cold and fridge not, try a fan motor. If compressor doesn't work either comp is faulty or PCB has blown(has a burning smell).. Hope this helps you and maybe many other ppl.
    Jan 21, 2010 | Refrigerators
    Refrigerators Logo
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
