Question about Panasonic KX-TG6313S 1.9 GHz Trio 1-Line Cordless Phone
BUSY SIGNAL WHEN CALL VOICE MAIL-CAN'T GET MESSAGES
I CALLED VOICE MAIL AND HAD TO LAY PHONE DOWN BEFORE FINISHING RETRIEVING MESSAGES. IT MUST OF HUNG UP PHONE.
NOW I CALL VOICE MAIL AND GET A BUSY SIGNAL AND CAN'T GET MESSAGES. HOW DO I GET THE VOICE MAIL LINE TO CUT OFF SO I CAN CALL AND GET MESSAGES.
  • jjrhayes Feb 09, 2009
    i guess patience is all it takes. about thirty minutes, i tried again and it worked.
5 Suggested Answers
  • 9 Answers
SOURCE: retrieving message
First set up a pin # or use the default which is 0000.
Then from a remote location:
  • Dial the Number
  • Press * Twice before the greeting is completed
  • Enter the Pin
  • Select * to hear all messages or Mailbox number which you are calling to check
  • Use the menu below:
5 - Play New Messages
6 - Record Message
7 - Play All Messages
8 - Play Greeting
9 - Record Greeting
0 - Turn System Off
# - Access help
Posted on Dec 26, 2008
  • 6 Answers
SOURCE: The phone said 2 new voice mail messages? how do i hear
usually if you hold 1 it will dial voicemail,
Posted on Nov 11, 2009
consultel1
  • 860 Answers
SOURCE: Answering machine and voice mail are not working.
For some reason I can't respond on the other thread that you posted.
What lights are on the voice mail card? There should be 3 on the lower edge of the card.
Posted on Jan 05, 2010
SOURCE: I need to change voice
How do I change the voice message on my panasonic digital voice mail system, mode kx-tg2000B. I lost the manuel.
Posted on Aug 07, 2010
How do I increase the number of rings before it goes to voice mail
What type of phone is this? Most home phones have a setting in them to adjust the number of rings. Retrieving voice mails requires the voice mail be set up first. To assist you further, please provide more details.
May 22, 2017 | Lands Phones
I have GE Model 28118 6.0 and the manual. However, when I am talking on this phone and someone else tries to call me, instead of them getting a busy signal, my phone goes to voice mail. How can I change...
On these types of systems, that's part of what voice mail is for...to catch your caller rather than just issue a busy signal. If you have call waiting, then your phone should give you a tone when another call comes in so you can answer it and put it on hold and return to the original call. Only if you don't respond to the call waiting tone will the phone then go to voice mail. If you don't want the voice mail to take calls when you are present, you most likely will need to turn off your voice mail when you are present. Then, if there is no voice mail to fall back to, the phone will give a busy signal.
Jan 11, 2015 | GE Lands Phones
Incoming calls does not connect to voice mail, you get a busy sign instead. What is the problem?
Call your local carrier as your voice mail feature may need to be reset. If you have any current saved messages write down the info as the reset may or may not cause them to be erased.Best of Luck.
Nov 10, 2009 | LG CE110 Cellular Phone
VOICE MAIL INACCESSABLE - PHONE JUST RINGS
Voice mail was down. Called a service tech.
May 29, 2009 | NEC DTU 8D-2 Corded Phone
Voice mail
Check your voice mail settings are enabled for no anwer/ busy.
Then check your voice mail number is entered correctly and not disbled by phoning your voicemal
May 12, 2009 | Motorola Mobility i870 Cellular Phone
Voice mail light does not come on when we have new voice mail.
Partner System doesnt have light notification feature if voicemail left on carrier site. I suggest you purchase small voicemail (4 mailboxes) for about $250 with installation and cancell your carrier voicemail service. You will be able to see new message light, also you can access your mailboxes remotely. It will pay for itself if carrier services cancelled within 7 or 8 month. If interested contact me vkagan at aaa-avad dot com. We are located in NY.
May 07, 2009 | Avaya Corded Phone avaparp18d
FWD/DND light is on and so is an extension light but the FWD/DND setting is off but when i check messages, i get a busy signal.
If the FWD/DND light is lit solid, the extension is in DND if it's programmed properly. You can test this by pressing the FWD button and reading the display. It will clear and press it again and it will set and tell you what it did. (if DND and FWD are both set it shows 3 states).
At the phone, press intercom and dial *710x where x=2 for all calls, 3 for busy, 4 for no answer or 5 for busy/no answer plus the extension of the voice mail plus #. Your FWD light should blink and you have now set FWD to voice mail.
Carl
Mar 12, 2009 | Panasonic KX-T7633 Corded Phone
Trouble obtaining my messages - Model DCT646-3
The DCT646 does not have answering machine so I assume you are using voice mail from your telephone service provider. You would need to contact them to find out why you are getting the busy signal.
Mar 02, 2009 | Uniden Cordless Phone
Panasonic KX-TG6313S 1.9 GHz Trio 1-Line Cordless Phone Logo
105 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
