Question about Toshiba Satellite A100-S8111TD Notebook
Computer only states load error
When i turn on my lap top the only thing that shows on screen is load error. Press a key to continue. But when i do the same message shows.
  • Anonymous Feb 12, 2009
    Thank you for helping,but it still gave the same message.
    Genius:
  • Toshiba Master
  • 1,102 Answers
Press f8 during restart then choose last known good
if still can't load f8 again then safemode do a disk defrag and then restart
if you still get same error or cannot get on let me know so i can try another solution
don't forget to rate
Posted on Feb 09, 2009
My lap top shut down and would not restart. I called the company and they said I needed to reinstall programs. They sent me two discs, but I cand get them to load.
Step 1:
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
Mar 15, 2013 | Dell inspiron 14r-n4110 laptop intel
I dont know how to use my recovery disk for my toshiba lap top
Here are the steps on how to install operating system using the recovery disc
- power on the computer and insert the disc - once the disc is inserted, turn off the computer - press the power button then after 2 seconds tap F12 repeatedly - select the cd/dvd option or ODD (optical disc drive) use the up and down arrow keys - press enter - once you see "press any key to boot from CD" press enter right away
it will show " Loading Windows"
- then after the next phase will be set of on screen instructions, you just have to select the right option.
Jul 09, 2011 | Computers & Internet
Hi my lap top is vostro 1520 and there is a proble with it that i can not stand by laptop because when request to sleep it shut down or some thing like this (hibernate i don't know).and then when i...
Hi
Go to Control Panel, Power Options,
Then adjust the options there:
  • closing screen behavior,
  • pressing the power button behavior
and, tell us the results.
Good Luck
May 15, 2011 | Dell Vostro 1520 Notebook
Hi i have a vostro 1520 dell laptop there is a problem that some strange 1.my laptop when just full battery is connected to it won't turn on but when i press 20 to 30 sec the turn on key and...
First 2 of your problems are due to the fact that your laptop enters hibernation (or hybrid sleep in windows 7) and windows cannot restore your last saved state. The 3rd problem indicates you have windows problems (bad/not updated drivers, filesystem corruption, application issues). I would suggest you to reinstall windows.
May 14, 2011 | Dell Vostro 1500 Notebook
My problem started out pretty confusing. One day I turned my lap top on and the screen, after about five to ten seconds of being on, went black. I could see things loading up sort of but the screen was too...
Darkened screen as you describe indicates a failing inverter. You can test this easily by plugging the laptop into an external monitor, if this works ok, then the inverter needs replaced, If it does not work, the problem is with the graphics chip / motherboard
Jan 18, 2011 | Dell Inspiron 8000 Notebook
I Log On To My Lap-top It Passes The Loading Screen Then Gose Dark I Try To Run The Diognostics Disc. It Says I Have A IR Problem I Dont No How To Fix This Plz Help Me Steven. Thank You
If you are using Windows XP, insert your Windows CD in the CD/DVD drive and restart your computer, make sure it boots from the CD. After loading a bunch of things, you should see a screen that tells you to press "R" to go to the recovery screen. Press the R key and when that screen loads, press 1 to log onto Windows. If you are asked for a password, just press the enter key. When you get a C:\Windows prompt, type chkdsk /r and press enter. It will take up to 90 minutes for this to run. When it finishes, type exit, press enter and remove the CD from the drive. Hopefully this will fix your problem.
Jul 30, 2009 | Dell Latitude D600 Notebook
Dropped lap top now wont boot up
press the fn key on laptop hold it down and then press the power key on the laptop. once u see any display on the screen you will get some tests running on the screen. The system will show you the error message which u need to note down. else you can do a Flea Power on your laptop. Remove the adapter and the battery and then press the power button and hold it down for 30 seconds then connect the battery and adapter back and try to turn on the laptop. See if the magic works for you
Jul 16, 2009 | Dell Latitude D600 Notebook
Dell Support Center program continually is not loaded
I would recommend you uninstall the Dell Support Software regardless of
version. It's not much more than a resources drain on your system imo.
just go to c panel ..add remove programs ...and uninstall it ...
Apr 07, 2009 | Dell Inspiron 8600 Notebook
Keys not working
You are running a U.S key board
Go to My computer/Help and type in the field- Keyboard change language
Jan 02, 2009 | Computers & Internet
Blue Screen
Use the following steps to replace the missing files when Windows cannot start.
  1. Turn the computer on and place the first recovery disc into the top drive.
  2. After inserting the disc, turn the computer off, wait about ten seconds, and turn the computer on again.
  3. If an HP Recovery screen displays "Press any key to continue...", press the spacebar.
  4. To continue, read the warning screen and click OK.
  5. Click Advanced Options at the top of the screen.
  6. Click Selective Recovery.
  7. Read the Select Files to Restore window that appears.
  8. Type the name of the file. For example, if the error message is MNYUTIL.DLL is linked to missing export MFC42.DLL, type MFC*.DLL.
  9. Click OK. If there is more than one recovery disc, it may be necessary to insert another disc when prompted.
  10. When therecovery process has finished copying files, remove the disc andrestart the computer. If problems, persist it may be necessary toperform a system restore or a non-destructive recovery.
(Note: Click here for information on ordering the recovery CD/DVD sets)
thx.
Oct 08, 2008 | HP Computers & Internet
Toshiba Satellite A100-S8111TD Notebook Logo
63 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
