Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Installed new ink cartridge/ still saying low color
Printer saying low ink(black and color) after replacing cartridges I'm still getting same warning and will not print anything
  • 3 more comments
  • Anonymous Mar 10, 2009
    Have replaced both cartridges and the printer does not print. Still showing low ink. Goodness, ink runs out FAST! What can I do?
    Thanks
  • doctor6 Mar 11, 2009
    Goodness!
    I just replaced the two cartridges 3 days ago, printed 3 pages and the ink is almost Zero.Its a night mare.Can some one help.They are making money out of us. Dr Goel
  • Anonymous May 19, 2009
    i'm trying to print off a paper that is due.. two weeks ago. and my ink light on my printer keeps blinking... but i JUST replaced the ink literally 7 minutes ago.. why is it being so stupiddd?
  • Anonymous Mar 21, 2014
    the printer seems to be frozen. I can't get it to do anything. Put in a new black ink cartridge and the printer screen is frozen on the ink cartridge levels. I also replaced the color cartridge, it still shows the color cartridge as low, even though it should not have been.
  • Anonymous Mar 24, 2014
    Printer is telling me to replace color cartridge. I am printing in b&w. How can I bypass this?
  • 4 Answers
Try calling 1 800 421 6699 for US.
solution
try to remove inks, then reseat it..
then remove printhead, by pushing the latch on the upper right, then put it back in. be sure that it will snap. close the door with no inks. try to look at the message, if it has the same error, put the inks on it and close the door again.. then if you still have the error message, call the hotline no. and I'm Afraid that you need a Printhead replacement or defective ink issue...
they will replace it for free..
Posted on Feb 10, 2009
My documents will not print the colored part. just Black and white
I would first check to see how low the color cartridge is. If it is out of ink, you will need to replace it.
Your Lexmark has two cartridges, one for colors and one for black.
To check the level of the ink cartridges, go to the Lexmark Solution Center. This is the software that was installed to run you Lexmark printer.
Check the cartridge ink level images that appear on each tab. If a cartridge is low, or if you have received an Ink Low message on the computer screen, install a new cartridge. An empty or low cartridge is marked with an exclamation point ( ! ).
To order print cartridges:
1 }}--> }}-->Open the }}--> }}-->Lexmark Solution Center .
2 }}--> }}-->Click the Contact Information tab.
3 }}--> }}-->Click Ordering Ink and Supplies.
For help installing a cartridge, go to How to install the print cartridge.
Dec 30, 2010 | Lexmark X6150 All-In-One InkJet Printer
I HAVE JUST REFILLED MY LEXMARK X2550 PRINTER COLOR CARTRIDGE NUMBER 35, BUT A MASSEGE ON MY PC SAYS: "Invalid Cartridge". How do l get it to be recognised so that l can use it?
hello
35 is color ink cartridge .. high yield,
A new color print cartridge needs to be installed.
If available, click the Continue button on your computer screen to print using the
black (or photo) print cartridge. (The Continue button is available only at the
beginning of a print job.)
Note: A variable amount of ink remains in the color print cartridge.
Follow these steps to replace the color print cartridge in your printer:
1 Cancel the print job if not already canceled.
2 Replace the color print cartridge with a new cartridge. For more information,
see "Removing a used print cartridge" on page 35 and "Installing print
cartridges" on page 35.
3 Print again.
To order supplies, click Order Ink on your computer screen. You can also see
"Ordering paper and other supplies" on page 40 in this guide.
Troubleshooting 54
manual = http://www.lexmark.com/publications/pdfs/2007/2500/v3708617_en.pdf
Installing print cartridges
1 If you are installing new print cartridges, remove the sticker and tape from the back and bottom of the cartridges.
1 2
Warning-Potential Damage: Do not touch the gold contact area on the back or the metal nozzles on the
Maintaining the printer
35
list of ink cartridge part numbers
http://www.lexmark.ca/lexmark/product/home/455/0,6970,204812589_653399443_1037657543_en,00.html?tabId=7
Dec 23, 2010 | Office Equipment & Supplies
Keeps saying insert colour cartridge when we have just bought a new cartridge of correct spec. Says incorrect colour cartridge installed.Impossible to get past!!!
Hi,The most common reason for missing or incorrect colors is a print cartridge with one of the following problems:
  • One or more of the ink colors is empty. The black ink and all three colors of ink in the tri-color cartridge must be available or colors will be incorrect or missing. Under normal usage, the print cartridge will run low on one color of ink shortly before all ink colors are emptied.
  • The protective tape is not removed from a new cartridge.
  • Contacts on the cartridge are not making proper contact with the print carriage.
  • The cartridge is remanufactured or refilled.
  • The cartridge is defective.
Feb 14, 2010 | HP PSC 950 All-In-One InkJet Printer
Replaced black ink cartridge and printer keeps asking to replace
The message that persists in saying to "replace black cartridge" could be due to a defective cartridge chip. The chip maintains counts and tells the printer when a new cartridge is installed. If you cartridge is remanufactured, they may have neglected to install a new chip.
Regarding the new fuser not working, I'll have to get back to you on that.
Oct 15, 2009 | HP LaserJet 4600dn Color Printer
New black cartridge installed. Won't print. HELP please.
Try
Resetting the Ink Counter When an ink tank is replaced, the ink counter must be reset. The low ink warning is only displayed properly if the ink counter is reset.
Message Prompting Confirmation of Ink Tank Replacement
If an ink tank is removed, the printer will output a message prompting you to confirm replacement of the ink tank at the start of the next print job.
When an ink tank has been replaced, follow the procedure below to reset the ink counter. The low ink warning is only displayed properly if the ink counter is reset.
Important
If infrared communication is performed in Windows XP or Windows 2000, the printer will not output the message asking for confirmation of ink tank replacement.
Reset the ink counter from the printer driver when you replace the ink tank.
1 Check the message, and click Yes.
Note
Mistakenly clicking No instead, will prevent the low ink warning from functioning properly. If this happens, be sure to open the driver's Properties dialog box and manually reset the ink tank counter in the Maintenance tab.
2 Select the replaced ink tank, and click OK.
The dialog box allows you to select the replaced ink tank.
When both black and color ink tanks have been replaced, select both Black and Color.
If you have not replaced the ink tank with a new one, click Cancel.
Resetting the Ink Counter in Printer Properties dialog box
1 Open the Printer Properties dialog box and click the Maintenance tab.
2 Click Ink Counter Reset.
3 Select the newly installed ink tank, then click OK
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
Ink
  1. Buy only genuine Dell replacement cartridges. Dell states their printer cartridges cannot be refilled with ink and that only their cartridges work in the printer.
  2. Bring the cartridge carrier of the printer to the center so you can access the ink cartridges. Open the cover of the printer and the carrier slides to the center. Make sure the printer is turned on.
  3. Remove the old black ink cartridge to use the color cartridge. If you allow the old black cartridge to remain in the printer, you will get error messages that the ink is low. The printer may also keep reverting back to the black ink as the default color when printing.
  4. Open the package of the new color cartridge carefully. Remove any blue packing tape that's on the ink cartridge. Take care not to touch the gold area or you could damage the cartridge. Insert the new color cartridge into the correct slot in the printer, the right side of the cartridge carrier. The ink cartridges aren't interchangeable; they need to be placed in the correct slot.
  5. Close the cover on your printer after installing the color cartridge. Run a print test to make sure the color cartridge is installed correctly. Use the Dell Ink Management System to monitor your printer and all-in-one functions. Thanks Thiru
Jun 15, 2009 | Dell 810 All-In-One InkJet Printer
924 says that black ink cartridge not installed
Hmmm....that sounds to be an issue with the ink cartridges...
You might be using ink cartridges purchased other than Dell or Staples...since these are the two who sell Dell Ink.
If thats not true, then take out both the cartridges in the printer.
Lets isolate the issue
1. Try only Black cartridge on Color slot(right). If you get Install both ink cartridges error, then its an issue with the Black ink cartridges and if you get message that install Black ink cartridge then its an issue with the prrinter.
2. Now install only color cartridge on Black cartridges slot(left), If you get color cartridge missing then its an issue with the Black cartridges which you are using and if you get install both ink cartridges then its an issue with the black slot on printer.
3. If issue found to be with Black ink cartridge then wipe the Nozzles(bottom) of the ink cartridge with lint free cotton cloth from back to front 5-6 times.
4. Also try replacing the ink cartridges purchased only from Dell or from Staples. Purchased from somewhere else or refilled might not work.
5. If issue found to be with printer, then i would suggest you to purchase new printer then.
Hope this fix the issue
Aug 14, 2008 | Dell 924 All-in-One InkJet Printer
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Low warning annoying me
Dell's proprietary grip on its printers causes this message to appear with any non-Dell or refilled cartridge. The messages/ink filled levels will only be reset if you buy a new Dell ink cartridge or have a way to update their encoding strip.
The good news is that you can still use refilled cartridges just minimize the level warnings to the task bar and ignore them when they come up. Everything should still print fine.
Nov 29, 2007 | Dell 924 All-in-One InkJet Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
1,393 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
