Question about iRiver H10 MP3 Player
Ear jack in Iriver h10 doesn't work correctly
Depending on how the earphone is put in you can hear music from only one ear unless you get it positioned just right and then don't move cuz it will be in only one ear at a time
    Problem Solver:
  • 18 Answers
I bought a used unit from ebay with the same problem (discovered later) and had to buy another as-is player, open it up, and replace the defective headphone jack module on the first player.
see this forum for directions to open player: forum
plan b - sell the unit as-is on ebay and put your profits toward a 20gb refurb for $30-60 (from sellers like metromania)
Posted on Apr 03, 2009
Files in Iriver H10 not appearing in music.
try this...
connect your h10 to the pc using the ums trick with the usb connection..
For 20 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Poke the "reset" button with a paperclip.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
download and run EASYh10 software (free playlist maker). It will scan the files in your music folder and build/save a playlist to your h10.
disconnect player and give it a try...
Mar 13, 2009 | iRiver H10 MP3 Player
Every time I turn on my iriver h10 it freezes on the artists and won't go anywhere. How do I fix this ? resetting doesn't help
not sure what's wrong but try this..
hook up your h10 via the ums trick...
The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
The UMS trick will also allow you to use your H10 with virtually any OS.
For 5/6 GB MTP Models
  • Take out the battery, wait a second, and put the battery back in.
  • You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button.
For UMS Models UMS models do not need this trick because they are always in UMS mode!
download and run the free playlist maker software called EASYh10. It will scan the music files on the h10 music folder and save a new playlist to your player.
Mar 03, 2009 | iRiver H10 MP3 Player
Iriver H10 - DB Open Error
one idea...
connect player to your pc using the ums trick
What is the UMS trick on IRiver H10?http://www.zolved.com/synapse/view_content/5942/What_is_the_UMS_trick_on_IRiver_H10
This article tells you how to transfer music to your player The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
always in UMS mode!
---download and run the free playlist maker called easyh10. It will read the music files on your h10, rebuild a playlist and save it to your player.
Feb 03, 2009 | iRiver H10 MP3 Player
Coping files from iriver H10 20 GB to pc
The USM trick allows you totreat your H10 as an external hard drive. Then it is easy to copy the musicback to your PC using explorer.
The details for the USMtrick are taken from mistic river.
http://www.misticriver.net/wiki/index.php/H10_Tips_and_Tricks/UMS_Trick
H10 Tips and Tricks/UMSTrick
From iriver Wiki, yoursource for everything iriver - a part of MisticRiver.
Jump to:navigation, search
Most people agree that theUMS trick is a great thing to know how to do. With it, you can transfer music,OR treat your H10 as a harddrive to put anything you want on. The UMS trickwill also allow you to use your H10 with virtually any OS.
5/6 GB MTP Models
1. Make sure your H10 is turned off anddisconnected from the computer.
2. Take out the battery, wait a second, andput the battery back in.
3. Turn on the hold switch (so that youdon't accidentally turn the H10 on all the way).
4. Plug the H10 into your computer.
5. Turn on the H10 while holding the"O" button.
6. You will see the message "UMSMode" if you have done everything correctly. You can now let go of the"O" button.
20 GB MTP Models
2. Poke the "reset" button with apaperclip.
5.Turn on the H10 while holding the "O" button.
6. You will see the message "EmergencyConnection" if you have done everything correctly. You can now let go ofthe "O" button.
UMS Models
UMS models do not need thistrick because they are always in UMS mode!
Sep 01, 2008 | iRiver H10 MP3 Player
Iriver H10 V's Vista
Just to let everyone know I have the H10 6Gb player and the reason your having problems getting the H10 to work with Vista is because it isn't supported by Vista at all even with updating your firmware...
Dec 23, 2007 | iRiver H10 MP3 Player
H10 volume
Have you tried different earphones or replacing the earphone jack?
Oct 30, 2007 | iRiver H10 MP3 Player
Iriver h10 5gb
Songs are in the wrong format - see my "tips & tricks for more details
Jul 10, 2007 | iRiver H10 MP3 Player
Broken t-10 earphone jack
try another headset to be sure its a problem of the player and not broken headphones. if its the player i hope its still under warranty, else you need to open it whats wrong. hot air soldering machine is an advantage..
Jun 16, 2007 | iRiver T10 MP3 Player
Can't hear music from sansa
Hi. If you have to adjust your earphone (even if you used other earphones) just to get a normal stereo sound, then the problem is with the player's earphone jacks. If that's the case (and assuming the radio feature of the player also manifests the same problem), then you may need to call the tech support guys at SanDisk for advanced troubleshooting, or possibly replacing that player. I found their tech support contact number at their website upon consulting prior issues I had with my player. Here it is: 1-866-726-3475.
May 09, 2007 | SanDisk Sansa e260 MP3 Player
I can't hear any music
Replace - cannot be repaired
Dec 14, 2006 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
82 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
