Question about Motorola Mobility S9 Headphones
S9 nvr goes into paring mode
When i trun it on it flashes 3times, then just blinks blue , nvr stays solid blue, how do u reset it to defaults....
  • laurelm97 Feb 09, 2009
    Sweet ty very much it worked.....
Hello,..... when pair the S9 you must press and hold down the power on button till the led flashes blue and red...at this point it will be in pairing mode....
Posted on Feb 09, 2009
  • PETE KELI Aug 20, 2012
    tghank you, it is working great now :-)
How to connect to phone
Pairing the Headset
*You are required to pair the headset with your mobile phone or other device before using it.
1. Ensure the headset is off, then press down the P2 button until the pairing mode (both Blue & Red-LED's are flashing
alternately), then release. This will take about 6 seconds.
2. Initiate pairing process of your mobile phone. Refer to the manual of the mobile phone for the direction. You will see a new
item "BT headset" added in your Bluetooth device list after the searching process.
3. You will be asked to enter a pin code to complete the pairing. Enter 1234 and confirm. (Note: the 1234 is a default pin code
pre-stored in the Headset) The red indication will turn off and the blue indicator will flash slowly after the paring is completed
successfully.
4. Once the pairing is complete, the Red LED will turn off and the Blue LED will begin blinking, (indicating standby mode). If it is
not finished paring within 2 minutes, the headset will go into standby mode, and pairing is unavailable. You will need to restart
and repeat steps 1-3.
MANUAL HERE:
http://www.manualslib.com/manual/251101/Fonegear-976.html#manual
Oct 04, 2012 | foneGEAR (00976) Wireless Headset
How do I put the motorola s9 hd wireless headset in pairing mode for a iPhone 3G ?
Starting with your headset turned off, press and hold the power button for some 6 seconds, until the indicator light flashes alternately in blue and red. It is in pairing mode now. Then, make your phone's bluetooth application search for new devices. After a while the S9 should appear on-screen. Make it connect. If a paring code (or PIN, or passkey) is requested, enter '0000' (four zeros). The indicator light will flash some times and enter stand-by mode.
Hope it works for you.
Regards, Carlos
Sep 01, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
How do I put a Plantronics Explorer 232 in paring mode so I can connect it o a cell phone
Hold it in for three seconds or more to flash purple and enter discovery mode.
Once it's paired it will flash blue.
Default code is 0000.
Feb 22, 2010 | Plantronics Explorer 220 Bluetooth Headset...
How do you get the motorola 350 into pairing mode?
press and hold the power/ answer button on the 350 until the blue light comes on and stays on. once it is solid blue its in paring mode.
Feb 13, 2010 | Motorola Mobility H350 Wireless Headset
How do I get my Jabra VBT185Z into pairing mode?
Turn on paring by pressing and holding center (blue button) until LED is solid blue.
Headset goes into pairing mode (unless already paired). Set your phone t "discover Jabra VBT185Z."
Enter PIN, "0000"
Good Luck!
Jan 02, 2010 | Jabra VBT185Z Bluetooth Headset
What does 2 flashing blue light mean on the S9.
Blue (three flashes) powering on/enabling indicator light
Blue (steady) pairing mode
Blue with 10 quick purple flashes
pairing successful
Blue (long flash)
standby (connected but not
on a call or streaming music)
Blue (quick flash)
incoming call
Blue (long pulse)
on a call
these are all the normal blue flashes that the s9 makes
Dec 10, 2009 | Motorola Mobility S9 Headphones
They Won't Charge!
Try to press the power boton in the same time you plug the charger, after this action mine is working and charging perfectly, maybe this is the "reset" solution... Hope this helps you.
Nov 17, 2009 | Motorola Mobility S9 Headphones
How do I connect my IPOD nano to my Motorola S9 HD Headsets
I downloaded the instructions manual for the Motorola S9 HD and implemented them. It worked fine!
Jun 19, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Cannot get S9 to connect to phone or computer
From Falvey86: Hold the headset start button for about 10 to 20 seconds, the lights will start flashing red and blue, then the search for Bluetooth devices from phone and it will appear as: S9. press "connect", a window will appear, place the password "0000", that should do the trick!!!!
Feb 27, 2009 | Motorola Mobility S9 Headphones
My LED never goes solid...??
MINE HAS ALWAYS BLINKED TO BUT IT STILL WORKS MINE HAS NEVER STAYED SOLID
Aug 30, 2008 | Jabra BT160 Wireless Headset
Motorola Mobility S9 Headphones Logo
2,196 people viewed this question
Top Motorola Mobility Audio Players & Recorders Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Unlockingcom
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
