Question about Bernina Virtuosa 160
Can I loosen the presser foot so knits will not stretch
Knit fabrics look stretched out at the hem. I read on an internet page that the presser foot can be loosed to minimize this. I have a Singer machine. Thanks
  • Anonymous Apr 06, 2009
    I'm trying to replace a zipper on my son's knit parka, but the knit is stretching when I sew. I have a Kenmore.
  • 24 Answers
Pressure on the pressure foot can be adjusted on some machines by turning the knob on the top leftside of the machine directly above the needle assembly. Look for a knob that has fabric types on it and adjust accordingly. Also check your thread tensions.
Posted on Feb 09, 2009
  • 202 Answers
Hi, you would have to remove the side cover (a T20 torx screwdriver) and you will see at the top of the presser bar you can adjust it. But Though I beleive your problem could also be the feeddogs may not be rising to the occasion. More than likely a clean, oil and adjust by a tech is in order.
Posted on Feb 13, 2009
Why is my stitch all wavy on the bottom when i sew knits?
What you are getting is what's called lettuce edging.
How to Sew Lettuce Hem Two Ways
You could unconsciously be holding the fabric back when it is feeding through the machine so you are building in stretch. Or, the presser foot pressure could so high that the presser foot is actually pushing the fabric in front so it is building in stretch. If you have a presser foot pressure adjustment on your machine, you might try loosening it some. It would be helpful to use a roller foot or walking foot (if you have one) that will not impede the movement of the fabric but instead help the fabric move through evenly. Also, lengthen the stitch length and add a zig-zag. That will give the garment some give, but if the fabric does stretch, it will also go back to flat once you remove it from the machine.
How to Sew Knits and Stretch Fabrics with Sewing Machine
Sewing Stretch Fabrics
Sewing with Stretch Knit Fabric Part 2
Oct 26, 2016 | Sewing Machines
My top yarn keep on breaking bussy with hem stretch fabric and a 75/11 schmetz needle please HELP
Try a brand new needle. Some needles are defective out of the package. If there is a harsh spot on the needle, it could cause the thread to break.
Since you are sewing a knit fabric, be certain to use a ball-point or stretch needle. Also, check whether the 75/11 needle's eye is too small for the thread weight you are using. If the thread is shredding at the needle eye, the thread may be too heavy for the needle or the thread is old or bargain bin variety thread. Try a different brand of thread--preferably a good quality.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwjqorDBwObMAhUq4oMKHcd4AI0QFggjMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q
All About Needles
May 18, 2016 | Sewing Machines
Hem knit hems
Use a ball-point needle and a stretch or zig-zag stitch that will allow the fabric to stretch without popping the stitching.
Jan 07, 2016 | Sewing Machines
What is the model number for presser foot for Singer 4830 machine?
Most presser feet are either short shank or long shank. Beyond that, they are pretty much universal. There are many different types of presser feet, such as: buttonhole foot, rolled hem foot, etc.
Jul 12, 2012 | Singer 4830
I have a Singer Quantum model 9240. Whenever I sew hems on jeans and go over the thickest part of the hem (where the vertical seam of the leg meets) the thread jams underneath, making a jumbled mess. I...
The problem happens when the thickness of the fabric being sewn is uneven. You need to raise the rear of the presser foot so it is even with the front of the foot. There is a little tool called a "hump jumper" or "jean-a-ma-jig" that makes it easy to do. When you get to the hump place the tool at the back of the presser foot and sew slowly. The machine should do the rest and the tool will fall away when it's no longer needed.
Jun 01, 2017 | Singer Sewing Machines
My Bernina 180 will not feed when I use a twin needle on knit fabric.
are you using a stretch twin needle; without one you'll get skipped stitches. However, the feed sounds more like a feed dog issue. Have you lowered the feed dogs for any reason? Will it sew on a woven cotton okay? If yes, but not feeding the knit then you could try turning up the presser foot pressure and see if that helps with the feed.
If you look across the needle plate with the presser foot removed and manually turn it through a stitch sequence, can you see the feed dogs coming up above the needle plate??
Jun 13, 2011 | Bernina Artista 180
I have a singer white model 979...everytime I sew stretch fabrics and satin it seems that either my material sort of scruntches or it stretches after I sew the hem. what am I doing wrong and how do I do...
Do you have a walking foot attachment? Also, called an evenfeed foot. You can also try using tissure paper under your fabric as you sew for a quick fix.
Sep 19, 2010 | White Sewing 979
Hemming stretch fabrics
You can use a twin needle if you want the look of top stitching (like t-shirt).
For the blind hem, you need to baste the hem and then the fold so they do not shift as the machine stitches the hem.
I like to test each of these techniques by making a sample with the same fabric and adjusting length when using the twin needle or width and length when doing the blind hem.
Twin needle does limit the stitching to a straight stitch or a very, very narrow zig-zag - this has to be hand walked to be sure neither swing hits the presser foot or needle plate before stitching.
Feb 22, 2010 | Sewing Machines
Sewing Machines Logo
414 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
