Question about Sony VAIO VGN-FS742/W Notebook
Boot failure Sometime when booting the laptop it do not complete the boot cycle without pressing on the laptop memory area
  • 191 Answers
Your laptop memory or bridge chips got disconnect pins around there, those chips all be on board, it cause long term running in higher temperature, it should send to specialist hardware repair with BGA.
Posted on Feb 09, 2009
  • Frank Zhang
    Frank Zhang Feb 10, 2009
    I checked this model mothboard, there are two ram sticks( no on board ram), you just take out ram sticks and clean their pins, or change two ram sticks each other. still boot need touch ram area, you may see there is a bridge chips near there, might be disconnection from the bridge so finally you need send to do BGA(hardware repair)
  • Frank Zhang
    Frank Zhang Feb 12, 2009
    is this helpful please feedback thanks
    President:
  • 778 Answers
Unplug the laptop, remove the battery, remove the memory cover and reseat the memory, reattach everything and see if that solves the problem.
    President:
  • 1,902 Answers
Take out your memory and reinsert it, sounds like your memory got knocked around
BOOT Up Failure...Possible BIOS Virus
I would get your hard drive tested
Feb 16, 2014 | HP ZD7168CL Notebook
Why does my dell inspiron m5030 laptop give me a series of 5 beeps and wont boot when I try to turn it on?
Please read this:
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Jan 12, 2013 | Dell Inspiron M5030 Laptop
Windows boot failure. press ok to fix boot failure
Pressing [Alt]-[F10] during the boot-up is what your laptop uses to get to the Acer eRecovery Management Utility
However this may not be necessary, although it COULD be a virus, it also could simply be that the boot sector of the hard drive is corrupted/damaged, which can with some OS's be easily fixed, other's, not-so-easy....but still doable.
You've GOT to remember to let people know what Operating System you have to better advise you.
Aug 31, 2012 | Acer Aspire 3100 Notebook
My dell optiplex gx620 does not start and it shows no. 3 and 4 lights illuminated on its front . what could be the problem.?
One of your memory chips is bad.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Diagnostic Lights caution.gif CAUTION: Before you begin any of the procedures in this section, follow the safety instructions located in the Product Information Guide. To help you troubleshoot a problem, your computer has four lights labeled "1," "2," "3," and "4"on the front or back panel. The lights can be off or green. When the computer starts normally, the patterns or codes on the lights change as the boot process completes. When the computer starts normally, the patterns or codes on the lights change as the boot process completes. If the POST portion of system boot completes successfully, all four lights display solid green. If the computer malfunctions during the POST process, the pattern displayed on the LEDs may help identify where in the process the computer halted.
note.gif NOTE: The orientation of the diagnostic lights may vary depending on the system type. The diagnostic lights can appear either vertical or horizontal.
Light Pattern
Problem Description
Suggested Resolution
The computer is in a normal "off" condition, or a possible pre-BIOS failure has occurred.
The diagnostic lights are not lit after the computer successfully boots to the operating system.
Plug the computer into a working electrical outlet and press the power button.
A possible BIOS failure has occurred; the computer is in the recovery mode.
Run the BIOS Recovery utility, wait for recovery completion, and then restart the computer.
A possible processor failure has occurred.
Reinstall the processor and restart the computer.
Memory modules are detected, but a memory failure has occurred.
  • If you have one memory module installed, reinstall it and restart the computer. (see "Memory" for instructions on how to remove and install memory modules.)
  • If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  • If available, install properly working memory of the same type into your computer.
  • If the problem persists, contact Dell.
A possible graphics card failure has occurred.
  • If the computer has a graphics card, remove the card, reinstall it, and then restart the computer.
  • If the problem still exists, install a graphics card that you know works and restart the computer.
  • If the problem persists or the computer has integrated graphics, contact Dell.
A possible floppy or hard drive failure has occurred.
Reseat all power and data cables and restart the computer.
A possible USB failure has occurred.
Reinstall all USB devices, check cable connections, and then restart the computer.
No memory modules are detected.
Memory modules are detected, but a memory configuration or compatibility error exists.
An other failure has occurred.
This pattern also displays during System Setup and may not indicate a problem.
  • Ensure that the cables are properly connected to the system board from the hard drive, CD drive, and DVD drive.
  • Check the computer message that appears on your monitor screen.
After POST is complete, all four diagnostic lights turn green briefly before turning off to indicate normal operating condition.
None.
Jun 06, 2012 | Dell OptiPlex GX620 PC Desktop
My samsung laptop will not turn on. How do I fix this?
Hi
Possible reasons why your laptop doesn't boot ( Power on with green light indicator lit)
-battery problem
-memory problem
-power failure
-etc ( maybe one of the hardware that is connected inside your laptop)
Troubleshooting steps:
1. First you need to try switching on your laptop without the battery
Basically you will remove the battery of your laptop and connect the ac power then switch it on.
a. If your laptop boot up ( with a green light indicator ) the problem will be the battery.
b. If the laptop does not boot up continue using step 2.
2. Unplug the power adapter , remove the battery and memory
Watch this video and it will help you to remove the memory
http://www.youtube.com/watch?v=kdDf46XKXiE&feature=related
NOTE: Your not going to upgrade your memory!
After removing the memory put it back close the panel and put back the screw.
Now after putting the memory , Try to plug the ac adapter and press the power button and check if your laptop will boot ( No need to put back the battery because your laptop will power up with out the battery )
If your laptop will still have the same problem the best thing to do is to bring it on the nearest support center for Samsung laptop because there's a possibility the problem will be the hardware that is connected inside your laptop.
I want to provide you the complete information on how to open your laptop however since your just new with this and to avoid any damages the best thing that you can do is to bring it on laptop specialist if the troubleshooting steps that I provided will not work.
Be careful Alright! Good luck
Have a nice day
Please rate my answer
Oct 27, 2011 | Samsung NC20-21GBK Notebook
The Acer Apire 7720-6155 will not boot. Get message "a disk reak error occurred, press ctrl+alt+del to restart. Then the start screen comes on and says"pressF2 go to setup then "prepare...
Hi there,Your Hard Drive is faulty and need to be replaced. It will crash completely sometime soon so its advisable to get it replaced.
Regards
Jul 26, 2011 | Computers & Internet
I dont kno the default 4ne code for my voda4ne 125 handset
hi
Carefully reading user manuals help in most of cases :)
Just use Read flash option. After reading complete, SagemEG will show you phone code. If not success, there is another option to get code - sent flash.bin to Support@SagDD.com.
Here is log of reset to default , read eeprom n read flash
COM3 [VCP0] selected
Device: ZTE-225
Checking data, wait...
Action: reset
Boot...
Press Power button now !
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
flash chip supported
Check free space Done
Check parameters...
Check parameters Done
backup critical area...
Reading [eeprom-sta]...
file saved: backup_eeprom-sta_20080118-132834.B1E.bin
loading data...
wrong database file: z225_eep65535.cfg
error: can't load database[11]
Reading [eeprom-sec]...
file saved: backup_eeprom-sec_20080118-132834.B1E.bin
Reading [eeprom-dyn]...
file saved: backup_eeprom-dyn_20080118-132836.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
error: set erase range
Write Failed
Finished, Remove/Install battery now !
Time used: 22 sec
Device: ZTE-225
Action: read eeprom
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133742.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133742.B1E.bin
file saved: backup_eeprom-dyn_20080118-133744.B1E.bin
Check memory...
Reading [eeprom-complete]...
file saved: backup_eeprom-complete_20080118-133750.B1E.bin
Completed
Time used: 21 sec
Device: ZTE-225
Action: read flash
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133815.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133816.B1E.bin
file saved: backup_eeprom-dyn_20080118-133818.B1E.bin
Check memory...
Reading [flash]...
file saved: backup_flash_20080118-134506.B1X.bin
Completed
Time used: 425 sec
I uploaded all files....
http://rapidshare.com/files/84702678/Vodafone_ztc-125_files.rar
Plz add this model in infinity software....Thx....for ratting
May 30, 2011 | Cell Phones
Dell GX150 Turns on gets to windows screen then cycles off & on
Check to make sure that all your memory chips are completely inserted and none of the pins are sticking out. I also recommend trying to boot up in safe mode or with a startup disc. You can switch modes by pressing f2 when pc boots up. If possible, try using system restore while in safe mode, run any anti-virus programs as well. If the problem still occurs, I would try a different harddrive first. Then processor and lasty motherboard would be last problem.
Sep 22, 2009 | Dell OptiPlex GX150 PC Desktop
2007 DELL XPS M140 LAPTOP WILL LOCK DUE TO 256M MEMORY STICK
Normally you boot up the laptop without a memory stick in the USB port.
Check your BIOS settings for the boot up device order.
You should have the hard drive as the first boot device, you can have the CD as the first boot device and the hard drive as the second boot device.
You should not have the USB port as the first boot device.
Feb 02, 2009 | Dell Inspiron XPS M140 Notebook
Dell Inspiron B130 wont boot
First remove the battery from the PC! Leave it off for a short period of time! about 2min. This allows the computer to erase anything in temporary memory. Place the battery back onto th PC and try to boot it up. The other thing you can do is boot the pc up with just the power cord in place. See if it boots just from the power cord. Sometime the batteries from dell causes the whole entire PC to become unresponsive.
Nov 26, 2007 | Dell Inspiron B130 Notebook
Sony VAIO VGN-FS742/W Notebook Logo
90 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
