Question about Lexmark X2500 All-In-One Printer
Error message on Lexmark x5470
My Lexmark x 5470 shows a message "Clear paper jam then press 'the check mark button' ", There is not a paper jam or any paper in it and I have tried (unsuccesfully) to reset it. I have also tried unplugging it, etc. It is not connected to my pc as I only use it to make copes and print pictures.
  • 3,051 Answers
Hi there: we have the same printer and we had the same paper jam problem to correct: this we opened it up as normal and than got a flashlight and looked real closley at it and there was a verry small piece of paper in the side of it folded and caught in it we took a pair of tweezers and removed it and the paperjam was cleared try that ok the smallest piece will give you this error and wont continue untill it is cleared
best of luck mike
Posted on Feb 18, 2009
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
My printer keeps showing the message "Clear paper jam, then press (check mark), there is no jammed paper in the printer.
If I load my paper at the 'proper' height, it will not feed. If I push the paper down too far, I get a 'paper jam' message. What works for me (even though it's a royal pain) is to feed 1 sheet of paper at a time. Put 1 sheet in so it's level with the top of the feed tray, then gently push it down 3/4 of an inch. That works for me. Good luck.
Sep 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 printer displays message "Clear paper jam, then press (check mark). There is no paper jam and it will not print with the message showing. I have cleaned the rollers but it didn't help.
try taking all of the paper out and then just print one sheet.
also make sure that it is new paper, lays flat and that you have fanned it prior to inserting it in the printer.
Jan 08, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 6500 states I have a paper jam, but I don't.
Hooray for McGuyver techniques, but I just shoved a piece of paper in there so it actually had a jam, pulled it out, and it cleared fine!
Sep 22, 2009 | Lexmark X2550 All-In-One Printer
Message shows 'clear paper jam then press check mark....no paper jammed in printer but it will not reset.
message keeps showing print cartridge cradle cannot move, I have check everything, no paper jams nothing under printer, I am turned off printed but keep getting same message.
Sep 17, 2009 | Lexmark X4530 InkJet Printer
How do i clear a paper jam
The Lexmark Printer you are having a very sensitive printer.
Normally this tyoe of Printers are very very slow in Printing job.
Comparing with other laserjet used.
If the Laptop / Printer are under warranrty, the Service engineer
can rectifity the printer jamming.
Solutins :
Make the Printer - Monthly service compulsory.
Use only good quality paper in the Lexmark Printer.
Do not pull the paper through hand, when the print out is coming.
Regards
Jul 15, 2009 | Lexmark X5470 All-In-One InkJet Printer
PAPER JAM ERROR 201.02
if you are gettiing a 201 error without any paper in the printer you will need change the main motor drive if it fails to initialize this is the error that will show up and there is no other way to reset it
Mar 20, 2009 | Lexmark T640 Laser Printer
Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
Hope this helps....
Explanation of the paper jam message
A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
Clearing the jam
To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
Remove any jammed sheets of paper you find and try printing again.
Dec 12, 2008 | Lexmark T640 Laser Printer
Paper jam
There is an end of form sensor in the paper path that is likely stuck or the rollers cannot turn due to some other Jam. The machine will throw that message if those two mechanisms cannot function. Look for debris in the printer - give it a good shake.
Sep 22, 2008 | Lexmark X6570 InkJet Printer
Lexmark, photo printer
Try to pass several sheets of plain paper
Then try the thicker photo paper.
If it is giving trouble send it back
Dec 31, 2007 | Lexmark P450 InkJet Photo Printer
Lexmark X2500 All-In-One Printer Logo
196 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
