Question about KitchenAid KEYS700LQ Electric Dryer
Dryer will not cycle
KitchenAid front load gas dryer. We have power but when start is pushed nothing happens other than the timer. Ran the diagnostic no problems. Inside there is a small belt which goes around the drum and it is broken. Not sure what this belt does? Door shut tight, moisture sensore working, clean vents, thermostat working.
    President:
  • 1,902 Answers
Replace the belt and all will work fine. The belt spins the drum
Posted on Feb 09, 2009
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
I have model # crgr7900A31 gas dryer front end loading. The dryer will not shut off. It continues to run.
Hi, If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Apr 14, 2010 | Frigidaire FGQ332ES Gas Dryer
Dryer won't start
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 07, 2010 | KitchenAid KGYS700LQ Gas Dryer
My Roper dryer suddenly won't start. Was running
Is it gas or elec?
Have you checked the breakers?
Does the outlet have power?
Model# ?
Try setting timer in a different cycle.
Make sure door is completely closed.
Push door switch in manually does it click?
Please update lat me know what else I can do to help.
Ken
Mar 17, 2010 | Roper Dryers
Push start button but nothing happens but buzzing noise
Is Kenmore a Whirlpool?
  • Here is what happened.
  • Stopped running mid-cycle.
  • Dryer set idle for about two hours Then I pushed start butten again.
  • It ran fine to finish load.
  • Next load it was totall dead and silent and remains that way.
  • The vent hose was unobstructed.
May 04, 2009 | Whirlpool Dryers
Nothing happens when I push the start button on my Gas Dryer
Three things you can check the door switch is it clicking? The thermal fuse you want to make sure there is continuity or worse case would be your motor.
Apr 02, 2009 | Whirlpool LGV4634JQ Gas Dryer
Dry cycle won't start
Commonproblems...blown house fuse, broken belt ( on some models )...door switch...*thermal fuse open (venting needs attention )...broken or burnt wire....timer....motor, in order from mostcommon to least common. * If you find a blown thermal fuse, always clean, change, adjust the ventingsystem and vent hood first, then it is often a good idea to replace the operatingthermostat at the same time. This is a picture of some modernthermal fuses.
Mar 28, 2009 | Whirlpool GEW9200L Electric Dryer
KitchenAid KEYS700LQ Electric Dryer Logo
106 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
