Question about Kenmore Washing Machines
Washing macine balance
The washing machine does not stay balanced even when empty. once it reaches max rpm it shakes the whole house.
  • 1,902 Answers
Adjust the legs on the washer that seems to be the problem. Or you could have broken the hinges and springs on the tub itself. The easiest thing to try is the legs first they just twist like a screw
Posted on Feb 09, 2009
Plastic arm with a spring on it flew out of back of macine,spin cycle is erratic
that is the out of balance switch arm, by the sounds of it the suspension assembly is worn and the washer is shaking too much when spinning and has snapped the arm off, be careful if you use it now as theres nothing to stop it walking across the room if it goes out of balance.
Feb 06, 2017 | Washing Machines
I bought a brand new bosch Classsxx 6 washing machine and when it is in the spin cycle it shakes out of control. I have balanced it and it still does it. How can I lower the spin cycle rpm's? Any...
Please do not take this the wrong way but, although you say you have balanced it, I would STRONGLY recommend you try my method to make absolutely certain. It's designed not to shake even at top spin speed and there is no adjustment anyway ;-0)
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly!
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
(but yours is a new machine!)
Good luck,
John C
Mar 19, 2011 | Bosch Classixx WFL 2066 Front Load Washer
My maytag washer shake a end of rinse cycle.
After the rinse cycle, the washer rapidly spins the tub to get as much water out of the clothes as it can. It works basically the same way as a salad spinner. If the weight of the clothes in the washer is not balanced, the washer will shake and maybe even jump around during the spin cycle. This is pretty normal. If all of your jeans end up on one side, and your t-shirts on the other, the jeans will hold more water, their side of the tub will be heavier, and the washer will shake a lot during the spin cycle.
If the washer is shaking too much, open it after the rinse cycle (wait for the tub to stop before reaching in) and spread the clothes out evenly in the tub. Try to balance the weight. Then close the lid/door and let it continue spinning.
Mar 05, 2011 | Maytag Washing Machines
During the lest spin cycle ,the drum spins like its out of balance, with bad knock , viberation. even after making sure the load is balanced in the drum. even without a load or water, (empty) it still...
The machine sounds as if it might be unsteady. If it only happens on the spin it is probably slight. Try levelling it at the feet, using a spirit level helps enormously to get it level.
Dec 09, 2010 | Washing Machines
Spins out of balance even emty
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Washer spins than it gets off balance and shuts
Hi, Washing machines can become unbalanced when the wash load has too much weight in one area of the basket. A machine in good working order can handle most problems through its balancing mechanisms. However, when washing heavy single items such as comforters, the machine's tub can become so lopsided that it damages the washer.
Washing machines that get unbalanced can shake, make banging noises, and even more across the floor. When machines are secured in one place, they can vibrate and bang so much the entire house shakes and things fall off shelves. This is not good for the washer. Bolts can come loose, and parts can break.
When washing heavy items such as pillows or down coats, stay near the washer so you can correct any balance problems as they occur. Some washers have an automatic shut-off feature when they become too far off-balance. If yours does not, stop the spin cycle, open the lid, and redistribute the load. If this is a continuing problem, you may want to wash heavy items at a coin-operated laundry in a heavy-duty machine.
Take care
Jul 14, 2010 | Whirlpool Washing Machines
New LG 80490TP. Shakes vigarously while spinning
your wash load is out of balance you have to open the macine door and adjust your washload more evenly around the tub also check the floor levellers and see that machine is level
Dec 17, 2009 | Washing Machines
Open Questions:
Washing Machines Logo
148 people viewed this question
Sal De
 Brian Main
Brian Main
