Question about Garmin eTrex Vista Cx GPS Receiver
Etrex will not turn on
Last summer my etrex legend just quit working. New batteries did not fix the problem. It simply will not turn on. Not sure if yoy can open the case to look for loose connections or if there is anything I can do other than send it back to Garmin. Thanks for any help you can give me. Hey!!!....this GPS don't turn on. This was working fine, I turn off, then try turn on again and never do it. It wasn't heat, neither water, hit or anything like that. It just have died and is very young to do this!!!!!!
I'm trying to obtain a response from Garmin.
Bye amigos, and good luck!!!I actually have the same problem. My Vista Cx does not turn on, after 2 weeks in rest, with a couple of new lithium batteries. I has tried with a fresh pair of alkaline batteries and remains off.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Almost always, a completely dead unit is indicative that for some reason, the power is not reaching the electronics. While this could be a firmware issue, in most instances, possibilities are:
  • corroded battery terminals, contacts, solder joints;
  • battery that will no longer accept a charge;
  • defective/dirty on/off switch;
  • cut wires;
  • faulty charging circuitry, charging line or charger jack/plug.
Ultimately, if the unit is no longer under warranty, it would require opening. Thereafter, a DVM/VOM could be used to measure resistance, continuity or the absence/presence of voltage at key points. If any of the above hardware components are determined faulty, then it would be a reasonable repair. Anything more and it may no longer be economically reasonable.
Good luck and thank you for using FixYa.
Posted on Feb 09, 2009
  • 19,396 Answers
The unit can be tested and repaired by aa local technician, it is faulty.
Take it at a repair shop , here are disassembly instructions:
Deconstructing the Garmin Etrex Vista
  • Garmin Master
  • 6,487 Answers
Sorry to say but this is already a dead unit and I think if this unit is still under warranty Garmion will have it repair but if its already out of warranty they will just advice you to have the unit replace by a new one...
Can you change a GPS navigation system from street name to postcode
I am not sure what you mean by " post code" but a gps uses maps that are stored on the unit itself. In order to make a change on how it shows locations, it would mean that the maps would have to be edited. Any change like you are suggesting would involve a lot of work with computer programming. Since it is not a standard method of locating, it would not be marketed.
Jan 06, 2017 | GPS
Need replacement batteries
what batteries are in it? when you have identified them try cpc
http://cpc.farnell.com/
Nov 14, 2011 | EMTAC BTGPS II Trine Bluetooth GPS...
How do I turn the Bluetooth on to use with my I phone
Turn on your Nuvi, go to Tools in the next screen you should see Bluetooth..... go to Connections and Add Device
Once added make sure Bluetooth says Enable
Oct 19, 2010 | Garmin nuvi 205W GPS Receiver
How to connect phone bluetooth to tomtom
First enable bluetooth function under the menu options. (if not bluetooth menu button is seen you will need to tap the "show all menu buttons" button in the menu)
once bluetooth is enabled follow the prompts that the One XL gives you to connect device.
Please make sure your device is in discoverable mode (blinking blue and red) during the process.
Oct 16, 2010 | Tomtom One XL GPS Receiver
How do you find the bluetooth option in gps because i cant find and i wamt to turn the bluetooth on
The Nuvi 200W is NOT Bluetooth capable, I'm sorry to say. Therefore, there is no option to find.
Apr 12, 2010 | Garmin nuvi 200W GPS Receiver
Charger/power light will not come on when plugged into usb or car charger
Check the FUSE usually located in the plug if so equipped try owners manual. Also check car fuse for short or overload fuse opens, also bad battery replace it, try Mouser electronics lotta techs are ordering on line no min order.
Apr 16, 2009 | GPS
I have a garmin nuvi and the cable that you put into your cigarette lighter will not work. I changed the fuse and it still will not keep the unit charged. I can charge it on my computer with a usb cable....
Do you see a lightning bolt symbol over the battery bar graph? This indicates that its charging. If it's under warranty, please contact Garmin on their website. www.garmin.com and call them. No need to worry about this if its under warranty. Send them your charger too.
- Jim
Dec 12, 2008 | GPS
Garmin eTrex Vista Cx GPS Receiver Logo
391 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
