Back to:
Tags:
Gateway Motherboard
BIOS Update problem on GP6-450
By Cato - usenet poster
I have a GP6-450 with a Jabil BX Motherboard w/ Integrated Audio R1,
part # 4000434.
I want to update the bios to a later version from what I currently
have, which is 4w4sboxo.15a.0006.p04
The only downloadable bios on the Gateway website for this board is
4W4SB0X0.15A.0019.P14
I've followed the install instructions. The bios update program begins
and gets to 75% complete, to the point where it says something like
loading bios files.
It then stops and I get a message, from within the BIOS update utility,
"the update was unsuccessful".
The old bios still works fine after this. I've tried different
flopppies formatted in various ways (from win98, from DOS) but still no
joy.
I've been leaving the bios jumpers on the board in normal position
since there is no instruction to do otherwise.
Is this bios incompatible with his board? Is there something else I
should try?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 01, 2007
Inappropriate (40)
Hart
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I have exactly the same as your starting bios..15a.0006.p04 etc. My
problem is that the computer wont take any keyboard inputs on the
bios screen..at least not that I can get it to do.
Did u have the same problem? did the new bios cure it? Why did u
upgrade your bios?
Yes I agree about the speed but I unfortunatley only have 128 of ram
in it. Good machine for its age...and quiet...having no CPU fan.
Dale
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on BIOS Update problem on GP6-450:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Mini Me
Rating: 0%, 0 votes
I did full formats of all three of the floppies I tried, either Win98
or DOS based. They all worked well enough when copying files to/from
them, no signs of problems.
This Gateway is a nice machine for its age. With a PII 450 and 384 MB
of RAM running Win2000 its speed is practically indistinguishable from
an Athlon XP1600 WinXP machine with 256MB RAM. This for office apps
and web.
Thank You!
Solution #3
Not Rated (0)
Melissa
Rating: 0%, 0 votes
Whenever I prepare a floppy to use to flash a mobo BIOS, I ALWAYS format it
first, doing a full format. Any bad spots, and the floppy goes in the trash. I
probably have a 1000 floppys here, so one less won't matter. It's not worth the
risk of a possible failed BIOS flash to use questionable diskette media.
... Ben Myers
Thank You!
Solution #4
Not Rated (0)
Beresford
Rating: 0%, 0 votes
Does the WS440BX motherboard have a jumper setting to disallow flash BIOS
updates? It also may have a setting to recover the BIOS, which you do not want
to do. The presence of these jumpers would be consistent with Intel motherboard
designs... Ben Myers
Thank You!
Solution #5
Not Rated (0)
M0nica L
Rating: 0%, 0 votes
OK figured it out. Maybe this will help someone else...
Must have been 3 bad floppies that I was using.
- Booted to A: from Win98 boot disk.
- replaced boot disk with bios floppy
- copied bios files to RAMDRIVE (E:)
- ran IFLASH from RAMDRIVE
- success!
Thank You!
Can you Help with these Motherboards problems?
Motherboards
It is a Asrock Mobo model # P4vm890 Thanks for your help
Motherboards
I have had this in for service and I have been told that...
Loading problems.
Repair Service
Find Motherboard Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
