Question about Xerox Phaser 8400 Laser Printer
Moving printer across room/print head green flag hasn't raised
Xerox Phaser 8400 printer has been off for a while, but the green "flag" is still in the low position. Did I miss a step in shutdown?
    Scholar:
  • 141 Answers
Did you remove the maintenance kit and waste tray? Sometimes, they hang up. By now, you've probably fired it back up and are running but, in this case, you want to do that quickly so that the ink doesn't have time to harden and stick the maintenance wiper to the printhead surface.
Posted on Aug 04, 2009
Error message 07,010.43:24426
The print head is not moving freely.
The print head wiper may be tacked to the print head, or the print head block may be filled with ink causing the print head not to pivot.
Jan 21, 2010 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400
That is a problem with print head movement. Either side to side or tilt. There is a stainless steel print head block located on the left side of the frame, about 2/3 of the way back and near the bottom, It may be contaminated with ink. Or the print head wiper may be tacked to the print head. If you want info how ot access and repair, let me know.
Jun 04, 2009 | Xerox Phaser 8400 Laser Printer
What is error code 07,010.43:32309
There is s print head block that may be filled up with runoff ink, or the print head wiper blade may be tacked to the print head.
Apr 16, 2009 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400 error
That is a print head tilt error. Either the print head pivot block is contaminated with ink or the wiper blade is tacked to the print head.
Let me know if you want to try to resolve it yourself, I will send you directions.
Feb 17, 2009 | Xerox Phaser 8550DX Laser Printer
Xerox 8400 light printing
No, If one lamp goes out they both will not function. They do not have anything to do with print quality.
You may have a bad maintenance kit. but more than likely you have a bad print head.
Run the cleaning , eliminate stripes and eliminate smears modes. But more than likely the print head is bad. I would say a bad print head is about a 95 percent chance of causing your problem.
The halogen lamps only heat the drum, and if one was bad the machine would fault out with a 15,004 code.
Oct 11, 2008 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400 error code
That code is a jet heater code.The most likely problem is a bad print head, the second most likely bad item is the electronics module that supplies the 40-50 volt source to the print head heater.
Sep 22, 2008 | Xerox Phaser 8400 Laser Printer
Color issue
If you moved it when it was warm, most likely you have spilled ink into the print head.
If it was shut down for more than an hour before moving it. There is a Tek Color correction you and run. You may have to go to the Xerox.com website and download it and run it.
I would also suggest updating the print driver.
But my guess is moving it damaged the print head and it will most likely need to be replaced.
Also if you go into the print driver properties, you can adjust each color intensity and saturation, you may be able to correct it in that way.
But from experience, I really suspect a faulty print head.
Jul 09, 2008 | Xerox Phaser 8400 Laser Printer
Jet substitution
You want to try something different.
1. Go to www.xerox.com
2. Click support and drivers.
3, In the search box type in Phaser 8400.
4. Select Drivers and downloads.
5 Scroll down and find Jetfix snipit, and download that, follow the procedure, maybe more than once.
The price from Xerox is $750 plus labor to replace the print head.
You can also look up service dealers in your area on the xerox website. Most will get you the print head and labor much cheaper. I emphasise the MUCH portion of cheaper...
Jul 08, 2008 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400
The first obvious question is, "Does it have blue ink/wax?" Is it displaying any errors? Have you tried the Xerox support site? They have a fantastic utility that can connect to your printer and diagnose many problems. Here's the URL for the utility: http://www.phasersmart.com/ They also have a wealth of information in their knowledge base. Here's the URL for the support page for the Phaser 8400: http://www.office.xerox.com/printers/color-printers/phaser-8400/sprt-enus.html Did anything happen before the blue quit printing? Have you tried running a cleaning cycle?
Aug 21, 2007 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Laser Printer Logo
99 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
