Question about Whirlpool Washing Machines
What size bolt is it to remove the agitator from a whirlpool rope
Yeah im trying remove it so i can take out the gearbox and access the clutch to replace...there is a ton of corrosion on the bolt and cant figure out what size the head is.
    President:
  • Whirlpool Master
  • 2,651 Answers
7/16 bolt holds the agitator onto the shaft of transmission
Posted on Feb 09, 2009
I have read the instructions for removing the agitator, but my machine does not seem to allow me to get to a bolt or nut. I have removed the cap from the agitator, but the barrier cap and seals do not...
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets your needs, ..Thank you.
Jul 17, 2011 | Kenmore 22422 Top Load Washer
Whirlpool washer agitator not working
HI. the internal components that make up the agitator should be inspected for damage.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction. Another issue that might cause this disruption is the Motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
**(((If the motor couple is in good condition, replace the agitator components and clutch assembly as well.)))
AGITATOR REMOVAL GUIDE
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly, which is removable as well. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to preform a combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Dec 13, 2009 | Whirlpool Washing Machines
Agitator
These are called agitator ratchet's and are located beneath the plastic retainer cover which is held in place by a 3/8" bolt. Remove bolt from agitator and remove. You may need to use a flat screwdriver to depress 3 glued tabs within this plastic retainer. From top use hammer lightly tap with screw driver until all 3 are free. Turn agitator over ratchet's are accessible. Order agitator ratchets. Thank you
May 29, 2009 | Whirlpool LSR6334LQ Top Load Washer
Laundry is trapped under the base of the agitator.
Im not very familiar with that type of top loadign washer,,, but on most agitators there is a bolt that runs down the center of the agitator, connecting it to the transmission/gearbox. Usually there is a cap, or softner dispenser that can be pulled off, revealing this bolt.
Mar 13, 2009 | Washing Machines
Removing clutch assembly from agitator
easy bud, take the top off the agitator then you will see a cover. pop that off and you will se a bolt. remove and take off the middle prt of agitator and you can get to the dogs
Feb 16, 2009 | Whirlpool Washing Machines
Washer will not agitate on wash cycle
could be a belt (doubtful) or it could be the connector underneath the. if the bolt isn't tight, it could be sliding along the cutout that makes the agitator work. tip forward and check it from beneath/backside whicheverr has the easiest access to view the connections.
Dec 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Loud grinding noise from agitator. How hard is this to fix.
Removing the agitator will not stop the grinding noise. Usually a bearing/gearbox problem going bad will create a howling grinding noise. You'll definitely hear it in the spin cycle. These are an expensive fix and require special technician tools to disassemble the unit. The gearbox is a sealed unit. Most manufacturers warranty their unit's gearbox for 5 years regardless the warranty you got when you purchased the unit, so check into this before you void your warranty. (The manufacturer requires their factory authorized service technicians to do the replacement) All in all if you do the work yourself it'll be approx $250 for the parts and gearbox transmission. To have the work done is usually much more.
Nov 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool washer won't spin
most likely just clutch ck for oil or water on it if oil most likely top seal gearcase is leaking ..remove agitator cap remove bolt in middle of agitator ..remove console screws remove clips under console holding cabinet on remove cabinet ..lean washer back remove pump then motor remove the 3 bolts holding gearcase in remove gearcase clutch is silver disk on top of gearcase with band inside ..band is actual clutch may try cleaning it but not hopeful about it being a permanet fix
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Remove Agitator Whirlpool style Top Loader
i think that the agatator may have a screw in the side of it nearer the bottom stem if so slacken off and pull ajatator off main shaft
if no screw just pull agatator off
sometimes takes a bit to get off
do not turn machine upside down
Feb 01, 2008 | Washing Machines
Washing Machines Logo
64 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
