Question about Kirby Ultimate G Bagged Upright Vacuum
How do you change the off swith in the Kirby ultimate G
Was having problems with my kirby turning on so I narrowed it down to the Off switch how do you change it ? I already found a replacement on line
First Thing to check is, Is it the pedal or the actuall switch.. the main switch is on the motor up under the cover and on the side
it is a pain to get to and even worse to change out.
most of the time it is the pedal that is broken and it is attached the switch by a rod
check that first
WP Vac
wpvac@centurytel.net
Posted on Feb 11, 2009
  • wpvac Feb 11, 2009
    ok if you have narrowed it down to the switch, you will need to take the handle off. then the back cover. the switch is on the side black thin with wires you will need to remember how the wires come off and you will need a flat screwdriver to help you slide the switch out. and it has slots for the new on to slide into.. it is a narrow space and will be tight to work in. but has to go in just right or wont work
    WPVAC
How do I convert a kirby ultimate G from 110V to 220V
You can't. The Kirby draws too many amps for a step down transformer.
Ask Kirby direct if they can convert your head to 220V. click Support - Contact
Kirby Ultimate Vacuum Kirby Models
Nov 10, 2016 | Kirby Vacuums
How do i replace the on and off switch on a gen 3 kirby sweeper
fault will be cable not power switch, phone your local kirby enginere for fixing
Jul 31, 2012 | Kirby Ultimate G Bagged Upright Vacuum
Intemitant power
DO NOT TURN ON THE KIRBY ANYMORE UNTIL YOU GET THIS FIXED!!! (not even to show someone what it sounds like)
Your carbon brushes are worn out and will cause damage to the armature if you run the machine before they are replaced..
You can use my guide for replacing the power switch to break the Kirby down and allow you to get to the carbon brushes to replace them.
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Hope this helps,
Marci
Jun 16, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I NOTICED SPARKS INSIDE THE UNIT WHERE THE HANDLE ATTACHES TO THE MOTOR....NOW IT IS NOT WORKING WHAT CAN THIS BE?
DO NOT TRY TO TURN THE KIRBY ON ANYMORE BEFORE YOU GET THIS REPAIRED!!! Your Kirby needs carbon brushes and if you don't already need a new armature, the worn out brushes will destroy the armature that you have. Here is a guide that will help you get down to the carbon brushes to change them...
It is a guide to replace the power switch, but will give you the step-by-step to get down to the carbon brushes.
Hope this helps,
Marci
Jun 10, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby ultimate power off
Make sure the bag assembly and either the power nozzle, or hose attachment are correctly attached. The kirby has safety swithes that are only engaged when these components are correctly installed. They look like small resessed buttons on the base unit. if they are not engaged the vacuum will not turn on. Keeps curious fingers from getting into the "spinny" parts ;o)
Jul 04, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G will not suck with main brush head attachment
You may need a new belt, it may have stretched enough so it isn't turning the brush roll anymore.
Mar 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G5 vacuum
Here is a link to the help you need,,,
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
The G5 manual is out of print, but the G6 and Ultimate G models are exactly the same and wil work perfectly for your questions.
Marci
Sep 17, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
60 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
